Hi.
Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. Karl |
Interesting! I have been a vocal proponent of the diesel movement for
years, but I'm also troubled by the real lack of technical discussion and analysis of the Thielert and SMA products available here (USA). This past Tues and Wed at Sun N Fun, I made several trips back and forth between the Miami based Thielert retrofitters (near the SAAB tent) and the Superior tent, hoping to chat with the Thielert technical expert. Each time I was told that he (the only expert there) was at the other tent. I was hoping to get the details of what problems they were experiencing with the 1.7 block; to make them retool to the 2.0 block with no performance increase. Left to my own imagination, I would not want to be flying behind the 1.7 at this point forward. Also, the Thielert boys seem to have committed to very modern electronic control systems to manage their engine (lots of MB three pointed star emblems on the electrical connectors). I asked last year at the AOPA Tampa show if the engine had a Limp Home Mode for a major electrical system failure. I got a quizical look and a promise of a call to my cell number once "the only expert at that show" returned to the booth,... still waiting. Too bad,... looks to me like they have a good product, but if they keep hiding from the flying public they'll lose the trust factor fast. Lastly, to speak to this DA-42 problem directly, I recall reading in the early (post certification) period of the 1.7 in the euro version DA-40, they experienced two documented in-flight electric control module failures which resulted in engine shutdowns with unsuccesful restart. Just speculating he Looks like if the battery was dead and the LG motor surge was too much for the alternators..., well, lets not speculate.... "Karl-Heinz Kuenzel" wrote ... Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. |
"Mike Isaksen" wrote in message news HRWh.10911$bZ2.2688@trndny01...: Interesting! I have been a vocal proponent of the diesel movement for : years, but I'm also troubled by the real lack of technical discussion and : analysis of the Thielert and SMA products available here (USA). This past : Tues and Wed at Sun N Fun, I made several trips back and forth between the : Miami based Thielert retrofitters (near the SAAB tent) and the Superior : tent, hoping to chat with the Thielert technical expert. Each time I was : told that he (the only expert there) was at the other tent. I was hoping to : get the details of what problems they were experiencing with the 1.7 block; : to make them retool to the 2.0 block with no performance increase. Left to : my own imagination, I would not want to be flying behind the 1.7 at this : point forward. : : Doesn't the 1.7 have a throw away TBO-like limitation that is very low? |
Karl-Heinz Kuenzel wrote:
Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. regards, Friedrich |
Friedrich Ostertag schrieb:
Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. regards, Friedrich Friedrich, I did not believe it either. Maybe I am getting to old. For me a diesel would run forever until you cut the fuel. What those people did. They just started #1 and #2 (which was NOT ok) on external power. And everything looked ok. Until they retracted the landing gear.... I posted that story in our German newsgroup and nobody seemed to be interested in that issue. I was just curious, if someone here is interested. regards Karl |
On Apr 23, 12:51 pm, "Neil Gould" wrote:
Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) |
Neil Gould schrieb:
Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil OK Neil. You find it in the article. POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. Karl |
Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil |
Recently, Karl-Heinz Kuenzel posted:
Neil Gould schrieb: I have a somewhat different take on this event. [...] I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. OK Neil. You find it in the article. My Deutsch is far too rusty to find it in the article. ;-) POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. That's fine for starting the engines, but that isn't the only issue, is it? Is there nothing in the POH about the electrically powered items (landing gear, FADEC, etc.)? If there is, it shouldn't require an EE degree to realize that one should be concerned about the condition of the batteries, charging, etc. if one has to "jump start" the engine, or to realize that something critical is in need of attention. Maybe I'm just an overly cautious type. ;-) Neil |
Recently, Cary posted:
I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) The actual wording of that email would be interesting. I'd think that the FADEC keeps the fuel flow and props configured, and that the current draw of the landing gear motor(s) probably shut the FADEC down due to low voltage. While that could be addressed with a different power configuration (a separate battery for the FADEC, for example), it may also introduce more failure modes and more factors to take into consideration during pre-flight. Neil (NOT a DA42 owner) |
| Thread Tools | |
| Display Modes | |
| F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 07:19 PM |
| Accident db? | [email protected] | Owning | 3 | July 25th 05 07:22 PM |
| C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 07:52 PM |
| MU2 accident | Big John | Piloting | 16 | April 13th 04 04:58 AM |
| KC-135 accident | Big John | Piloting | 3 | November 19th 03 05:36 PM |
