The time has arrived to start posting flights.
I am using SeeYou version 3.7 to download EW files from my Model D and convert them to IGC format. My attempts to post an April 20 flight have all failed to validated. The flight is scored; however, there is an error message that states "Security code in file does not match computed value." I have attempted post the flight using the SeeYou utility to connect and upload the file; the "Direct Claim (IGC-file)"; and, the "Prepared Claim (OLC-file)" options. However, all yield the same unsatisfactory results. Last year the EW Model D - SeeYou - OLC flow worked flawlessly. Have other EW Model D users been having a similar problem making claims to OLC-2007? Any assistance in resolving this problem will be greatly appreciated. Wayne HP-14 "6F" http://www.soaridaho.com/ |
On Apr 22, 4:10 pm, "Wayne Paul" wrote:
The time has arrived to start posting flights. I am using SeeYou version 3.7 to download EW files from my Model D and convert them to IGC format. My attempts to post an April 20 flight have all failed to validated. The flight is scored; however, there is an error message that states "Security code in file does not match computed value." I have attempted post the flight using the SeeYou utility to connect and upload the file; the "Direct Claim (IGC-file)"; and, the "Prepared Claim (OLC-file)" options. However, all yield the same unsatisfactory results. Last year the EW Model D - SeeYou - OLC flow worked flawlessly. Have other EW Model D users been having a similar problem making claims to OLC-2007? Any assistance in resolving this problem will be greatly appreciated. Wayne HP-14 "6F"http://www.soaridaho.com/ Hi Wayne; I've had no problems with uploading to OLC lately. I just go directly to OLC and claim the flight. It seems to go faster than going through SeeYou. It's really easy now. Hope that helps, Dan Rihn |
My attempts to post an April 20 flight have all failed to validated. Last year the EW Model D - SeeYou - OLC flow worked flawlessly. Welcome to the club! Jim |
But seriously Wayne,
Try again (including transferring files from the logger). And again until it works. Something may have got corrupted in between. Took me 11 tries with WinPilot and 302 files last night and this morning, but it may have worked. Jim |
"JS" wrote in message ps.com... But seriously Wayne, Try again (including transferring files from the logger). And again until it works. Something may have got corrupted in between. Took me 11 tries with WinPilot and 302 files last night and this morning, but it may have worked. Jim So what you are telling me is that I need to download the file from my recorder then make an OLC declariation. If it doesn't pass verification, delete it and then repeat the process until it passes. Is that correct? Wayne HP-14 "6F" http://www.soaridaho.com/ |
In addition to the OLC-2007 failures I have been experience with files
transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Has anyone had success making an OLC-2007 flight claim of a flight recorded on an EW Model D? If so, send me an email describing the process you are using. I have emailed describing my problems and am waiting for their reply. Thank you, Wayne HP-14 "6F" http://www.soaridaho.com/ "Wayne Paul" wrote in message ... "JS" wrote in message ps.com... But seriously Wayne, Try again (including transferring files from the logger). And again until it works. Something may have got corrupted in between. Took me 11 tries with WinPilot and 302 files last night and this morning, but it may have worked. Jim So what you are telling me is that I need to download the file from my recorder then make an OLC declariation. If it doesn't pass verification, delete it and then repeat the process until it passes. Is that correct? Wayne HP-14 "6F" http://www.soaridaho.com/ |
On Apr 23, 9:04 am, "Wayne Paul" wrote:
In addition to the OLC-2007 failures I have been experience with files transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Wayne, after downloading your flight, does it pass the VALI-xxx.exe check? If so, then the error is being introduced during the upload to OLC. If not, then there is a problem with downloading from the FR to your computer. The impression I have based on the above comment is that the problem is during transfer from the FR to your computer. If that is indeed the case, then you must fix that problem before submitting to the OLC unless you just want to set a placeholder for the flight prior to the Tuesday deadline. Then the transfer issue must be resolved and finally you can upload the valid file. -Tom |
"5Z" wrote in message oups.com... On Apr 23, 9:04 am, "Wayne Paul" wrote: In addition to the OLC-2007 failures I have been experience with files transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Wayne, after downloading your flight, does it pass the VALI-xxx.exe check? If so, then the error is being introduced during the upload to OLC. If not, then there is a problem with downloading from the FR to your computer. The impression I have based on the above comment is that the problem is during transfer from the FR to your computer. If that is indeed the case, then you must fix that problem before submitting to the OLC unless you just want to set a placeholder for the flight prior to the Tuesday deadline. Then the transfer issue must be resolved and finally you can upload the valid file. Tom, Thank you for your suggestion; however, to the best of my knowledge a separate VALI-xxx.exe program no longer exists for the EW Model D. My last attempt was using the EW Windows Uploader found on the FAI site. (http://www.fai.org/gliding/gnss/freeware.asp) This program produces an IGC file which requires the download and conversion of the EW data file. It would be a shame if this manufacture's product skips the validation process. The process runs smoothly without any indication of a problem. Again, thank you for taking the time to assist me. Wayne |
Hi,
The Upload program for transferring files from the EW model 'B' and 'D', is available under software on www.ewavionics.com. Graham der Pilot Network wrote: ---------------------------------------------------------- Newsgroup: rec.aviation.soaring Subject: OLC posting of EW Model D files Author: Wayne Paul Date/Time: 16:40 23 April 2007 ------------------------------------------------------------ "5Z" wrote in message roups.com... On Apr 23, 9:04 am, "Wayne Paul" wrote: In addition to the OLC-2007 failures I have been experience with files transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Wayne, after downloading your flight, does it pass the VALI-xxx.exe check? If so, then the error is being introduced during the upload to OLC. If not, then there is a problem with downloading from the FR to your computer. The impression I have based on the above comment is that the problem is during transfer from the FR to your computer. If that is indeed the case, then you must fix that problem before submitting to the OLC unless you just want to set a placeholder for the flight prior to the Tuesday deadline. Then the transfer issue must be resolved and finally you can upload the valid file. Tom, Thank you for your suggestion; however, to the best of my knowledge a separate VALI-xxx.exe program no longer exists for the EW Model D. My last attempt was using the EW Windows Uploader found on the FAI site. (http://www.fai.org/gliding/gnss/freeware.asp) This program produces an IGC file which requires the download and conversion of the EW data file. It would be a shame if this manufacture's product skips the validation process. The process runs smoothly without any indication of a problem. Again, thank you for taking the time to assist me. Wayne ------------------------------------------------------------ -- |
Graham,
The software on the FAI site is the EW provided EW Windows Uploader. I uninstalled it and installed the version on the EW site that is optimized for use with an USB to serial converter. My 20 April flight file was transferred from my EW to my laptop and a OLC claim was completed using the "Direct Claim (IGC - file)" process. The IGC security record still doesn't match the OLC computed value. So the mystery continues. Thank you for your assistance. Wayne HP-14 "6F" http://www.soaridaho.com/ "Graham Paul" wrote in message ... Hi, The Upload program for transferring files from the EW model 'B' and 'D', is available under software on www.ewavionics.com. Graham der Pilot Network wrote: ---------------------------------------------------------- Newsgroup: rec.aviation.soaring Subject: OLC posting of EW Model D files Author: Wayne Paul Date/Time: 16:40 23 April 2007 ------------------------------------------------------------ "5Z" wrote in message groups.com... On Apr 23, 9:04 am, "Wayne Paul" wrote: In addition to the OLC-2007 failures I have been experience with files transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Wayne, after downloading your flight, does it pass the VALI-xxx.exe check? If so, then the error is being introduced during the upload to OLC. If not, then there is a problem with downloading from the FR to your computer. The impression I have based on the above comment is that the problem is during transfer from the FR to your computer. If that is indeed the case, then you must fix that problem before submitting to the OLC unless you just want to set a placeholder for the flight prior to the Tuesday deadline. Then the transfer issue must be resolved and finally you can upload the valid file. Tom, Thank you for your suggestion; however, to the best of my knowledge a separate VALI-xxx.exe program no longer exists for the EW Model D. My last attempt was using the EW Windows Uploader found on the FAI site. (http://www.fai.org/gliding/gnss/freeware.asp) This program produces an IGC file which requires the download and conversion of the EW data file. It would be a shame if this manufacture's product skips the validation process. The process runs smoothly without any indication of a problem. Again, thank you for taking the time to assist me. Wayne ------------------------------------------------------------ -- |
| Posting Trouble | Cody Dawg | Piloting | 3 | November 29th 06 09:06 PM |
| OLC Posting Problem | jcarlyle | Soaring | 4 | September 28th 06 03:45 AM |
| and, since I am posting.... | Dave | Piloting | 9 | November 21st 05 02:36 AM |
| Ad posting help | Newps | Aviation Marketplace | 0 | August 16th 05 05:07 PM |
| Import/export AeroFly Pro models from/to other standard 3d model files such as *.3ds, *.x, *.lwo,... etc | Simulators | 0 | March 27th 05 09:30 AM | |
