I'm trying to have an Ilec TE Probe mounted on my ASW-15. It looks
like one will have to cut a hole behind the rudder to fit the probe from the backside of the fin. If anyone has any information or better yet some pictures or drawings on the best way to install this, it would be a great help. Thank You Bob |
On Apr 22, 7:08 pm, wrote:
I'm trying to have an Ilec TE Probe mounted on my ASW-15. It looks like one will have to cut a hole behind the rudder to fit the probe from the backside of the fin. If anyone has any information or better yet some pictures or drawings on the best way to install this, it would be a great help. Thank You Bob I would try a fuse mounted one. http://www.ssa.org/members/johnson/f...89-1998-04.pdf |
On Apr 22, 9:30 pm, mike wrote:
On Apr 22, 7:08 pm, wrote: I'm trying to have an Ilec TE Probe mounted on my ASW-15. It looks like one will have to cut a hole behind the rudder to fit the probe from the backside of the fin. If anyone has any information or better yet some pictures or drawings on the best way to install this, it would be a great help. Thank You Bob I would try a fuse mounted one. http://www.ssa.org/members/johnson/f...89-1998-04.pdf I made a TE probe per Johnson's plans and installed it on my Cherokee over the winter. It seemed to work very well on my 5:20 flight 2 weeks ago. It is a little sensitive to gusts right now, i think I need to add a constriction in the line to settle it down a little. |
On Apr 22, 10:48 pm, wrote:
On Apr 22, 9:30 pm, mike wrote: On Apr 22, 7:08 pm, wrote: I'm trying to have an Ilec TE Probe mounted on my ASW-15. It looks like one will have to cut a hole behind the rudder to fit the probe from the backside of the fin. If anyone has any information or better yet some pictures or drawings on the best way to install this, it would be a great help. Thank You Bob I would try a fuse mounted one. http://www.ssa.org/members/johnson/f...89-1998-04.pdf I made a TE probe per Johnson's plans and installed it on my Cherokee over the winter. It seemed to work very well on my 5:20 flight 2 weeks ago. It is a little sensitive to gusts right now, i think I need to add a constriction in the line to settle it down a little. We did the same thing with our L-13 Blanik trainer over the winter. We mounted it in the middle of the turtledeck ahead of the radio antenna. We did find that we had to make it longer than the one Francois Pin made for his PW-5 though, in order to get above the turbulence from the canopy at higher alpha. |
On Apr 24, 11:05 am, mattm wrote:
On Apr 22, 10:48 pm, wrote: On Apr 22, 9:30 pm, mike wrote: On Apr 22, 7:08 pm, wrote: I'm trying to have an Ilec TE Probe mounted on my ASW-15. It looks like one will have to cut a hole behind the rudder to fit the probe from the backside of the fin. If anyone has any information or better yet some pictures or drawings on the best way to install this, it would be a great help. Thank You Bob I would try a fuse mounted one. http://www.ssa.org/members/johnson/f...89-1998-04.pdf I made a TE probe per Johnson's plans and installed it on my Cherokee over the winter. It seemed to work very well on my 5:20 flight 2 weeks ago. It is a little sensitive to gusts right now, i think I need to add a constriction in the line to settle it down a little. We did the same thing with our L-13 Blanik trainer over the winter. We mounted it in the middle of the turtledeck ahead of the radio antenna. We did find that we had to make it longer than the one Francois Pin made for his PW-5 though, in order to get above the turbulence from the canopy at higher alpha.- Hide quoted text - - Show quoted text - Thank You for your ideas. I was able to fit the probe in the fin after we made an access hole in the rear of the fin and one along the leading edge. The mount was then fitted through the rear hole and expoxied in place. I would also like to thank Eastern Sailplane for taking time on the phone to explain how they mounted their TE Probe on their ASW-15. Now all we need is some nice weather in the North Eastern US to try it out. Bob |
| Replacement JPI EGT probe | Robert M. Gary | Piloting | 4 | July 16th 05 03:28 AM |
| Multi - probe | KP | Soaring | 1 | March 7th 05 07:03 PM |
| TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 11:52 PM |
| TE probe for SGS2-33 | Rod Pool | Soaring | 1 | May 20th 04 07:08 PM |
| Cleaning a 3-way TE probe | Jack Glendening | Soaring | 37 | November 5th 03 07:45 PM |
