On Fri, 22 Aug 2003 20:48:02 GMT, "Ed Majden"
wrote: As a test pilot at Edwards he stated that some of the aircraft he tested in the past out perform today's modern fighters. The F-104 was one of the examples. At the eurofighter website http://www.eurofighter.starstreak.ne...tech.html#eval there is a model for comparative evaluation of the Eurofighter and 8 current fighters using 13 factors: Twin Seat Thrust to Weight Twin Engines Air to Ground Combat Stealth Air to Air Combat Range Agility Electronic Warfare STOL capability CostMaintanence Weapon selection Supercruise My guess is anyone making a statement favoring the F 104 would give high weight to only three factors: Air Combat, Agility, and Thrust. When applied to the Eurofighter model, the F 22 beats the rest, including the Eurofighter, F15, F16, F18, plane rating Typhoon-89% F22 - 100% JSF - 70% Rafale- 83% Su35 - 80% F15 - 73% Gripen- 71% F16 - 63% F18 - 68% Adjusting for advances in avionics and engine technology AND eliminating differences resulting from today's tendency to want multi-purpose platforms with the result that unfortunate compromises are necessary--would the basic Starfighter platform result in a superior weapon? I cannot believe it would succeed based on its lack of agility resulting from its extreme wingloading. Using John Boyd's criteria for an effective fighter, the flying prostitute would not even come close. John Bailey http://home.rochester.rr.com/jbxroads/mailto.html |
"Les Matheson" wrote:
Snipped I found an interesting statistic the other day in researching a presentation to a group about my book. In Operation Iraqi Freedom, one fixed wing US aircraft was lost for 18,190 fixed wing sorties flown. JUST ONE!! For Desert Storm, we lost 37 fixed wing aircraft on 116,000 sorties for a rate of one loss per 3135 sorties. During Rolling Thunder, the F-105 was losing one aircraft per 65 sorties during 1966. Snipped Ed, We lose more airplanes than that in a bad week at Red Flag. Comparing the DS II rates to DS I or VietNam is apples to oranges. They hardly shot back. Even in DS I the air defense wasn't as robust as around Hanoi, because we were allowed to kill it. All your statistics show is that a decent program of SEAD works to prevent losses. Says nothing about the capabilities of the F-15E, F-16C, or the A-10. It does say a lot about the AGM-88 and smart weaponry over the last 12 years of SEAD in Iraq. I don't agree with the "apples to oranges" characterization. Iraq boasted a concentrated Soviet-built integrated air defense system with a load of radars, wide array of SAM systems and a lot of guns. While clearly localized and probably badly mismanaged, those night-scope videos of the fire over Baghdad were pretty impressive to this tired Weasel-wingman's eyes. While the IADS had developed over the years, so too had the counter-measures, offensive weaponry and tactics. That along with a political structure that was willing to let the pros do the job was the key. Which, of course, all goes back to the original purpose which was to debunk the statements of Burt Rutan regarding the torpor of the American military aviation industry. We've done quite well over the years. Ed Rasimus Fighter Pilot (ret) ***"When Thunder Rolled: *** An F-105 Pilot Over N. Vietnam" *** from Smithsonian Books ISBN: 1588341038 |
![]() "Ed Rasimus" wrote in message ... "Dudley Henriques" wrote: Remember that there are TWO Rutans--Dick is the designer and Burt the guinea pig in the cockpit usually. The innovation and creativeness that gave us the Varieze, Voyager and a raft of other creations came from Dick. Dick's the one that usually shows up at River Rats reunions as well--seems to have a bit of Phantom in his background..... Price of old age I guess. I'm always getting the two of them mixed up. Bede's a lot easier. He looks like Pavarotti :-))) Dudley |
Ed Rasimus wrote
Snipped While the IADS had developed over the years, so too had the counter-measures, offensive weaponry and tactics. That along with a political structure that was willing to let the pros do the job was the key. Snipped Exactley my point. We fought a different war against a less organized opponent and did better. Only comparison possible on a meaningful level is to say, let the military do what is designed to do, "Break things". -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) |
![]() "Ed Rasimus" wrote in message ... Remember that there are TWO Rutans--Dick is the designer and Burt the guinea pig in the cockpit usually. The innovation and creativeness that gave us the Varieze, Voyager and a raft of other creations came from Dick. Dick's the one that usually shows up at River Rats reunions as well--seems to have a bit of Phantom in his background..... Ed Rasimus Sorry Charlie, It is just the opposite. Burt is the designer. Dick is the test pilot. Tex Houston |
On Sat, 23 Aug 2003 14:39:48 -0400, av8r
wrote: Hi The wing loading on the Canadair-built F-104G (MAP) was 148 pounds per square foot. And for the F22 it is 65 lb/sq ft. ref:http://www.airtoaircombat.com/compare.asp also: http://www.fighter-planes.com/ (337 kg/m^2) vs 643 kg/m^2 for the F104 The F22 has about a 2 to 1 advantage over the F104 in wing loading, which translates into maneuverability/agility--in spite of its horrible weight: 36308 kg vs 13170 kg for the Starfighter. (My F86 only weighed 6123 kg.) John Bailey http://home.rochester.rr.com/jbxroads/mailto.html |
Ed Rasimus wrote: Remember that there are TWO Rutans--Dick is the designer and Burt the guinea pig in the cockpit usually. Ed, it's the other way around. Burt is the designer in the family, Dick is the test pilot and used-to-be Phantom driver. Dick flew the Voyager around the world with Jeana Yeager, Burt designed and built it. The innovation and creativeness that gave us the Varieze, Voyager and a raft of other creations came from Dick. Dick's the one that usually shows up at River Rats reunions as well--seems to have a bit of Phantom in his background..... He also flew 325 missions in Vietnam, IIRC flying mostly F-100. |
Certainly the F-104 was an aeronautical marvel. It was an incredible
achievement. But give me an F-22 (or for that matter, an F-15, or -16) and I'll promise to mort the Zipper long before the merge--even before he knows there is going to be a merge. This reminds me of my good friend who was flying F-15's at the time out of Eglin. He was thinking of applying for an exchange tour with the Italians to fly F-104s, which we both agree is about one of the coolest things built. I was encouraging him to go for it but then he brought up a good point...he goes "John, I would kill to fly a -104, but I sure as hell wouldn't want to take one into combat these days!" -John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
"Only" 88 psf (BTW, that sounds suspiciously low) versus the Phantom's 76.
There's a lot more too it than wing loading. The F-104 had superior specific excess power than the Phantom at one G, inferior at five, significantly inferior at seven. The F-4 was not noted as an agile machine, but it was superior to the 104 (and that's based on perhaps limited but nevertheless real world personal experience). Based on your method of comparison, many highly maneuverable aircraft would appear to be less capable than they are. R / John |
![]() "Ditch" wrote in message ... Certainly the F-104 was an aeronautical marvel. It was an incredible achievement. But give me an F-22 (or for that matter, an F-15, or -16) and I'll promise to mort the Zipper long before the merge--even before he knows there is going to be a merge. This reminds me of my good friend who was flying F-15's at the time out of Eglin. He was thinking of applying for an exchange tour with the Italians to fly F-104s, which we both agree is about one of the coolest things built. I was encouraging him to go for it but then he brought up a good point...he goes "John, I would kill to fly a -104, but I sure as hell wouldn't want to take one into combat these days!" It's the equivilent to bringing a knife to a gunfight. |
X-Prize is currently live on Discovery Science Channel | Roger Halstead | Home Built | 50 | October 10th 04 11:49 AM |
Letter from Jess Meyers | Badwater Bill | Home Built | 142 | July 21st 04 02:17 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Aeronautical Engineering Help needed | Marc A. Lefebvre US-775 | Home Built | 94 | January 11th 04 12:33 PM |
Burt Rutan | Tarver Engineering | Home Built | 0 | August 28th 03 04:15 PM |
