#51
Newps,
What does it cost the owner at 2400 hours? I seem to recall it's something like 20k for a new engine. -- Thomas Borchert (EDDH) |
#52
Jose,
However, it does seem to be a serious oversight that the engines themselves can't supply their own juice. That will become totally common with FADEC engines. It's just DIFFERENT failure modes we have to be used to - our current old engines have single failure points, too. -- Thomas Borchert (EDDH) |
#53
![]() "C J Campbell" wrote ... According to the article, the battery was so dead that it could not excite the alternator -- the alternator needs some current in order to start. I'm sorry, but the quoted article seems to point more at the main battery as the culprit. Without the buffering effect of the main battery, the current spike of the gear retract was supposedly enough to decrease the voltage on the ECU bus and cause an ECU reset. There is a discussion whether the main battery was connected to the battery bus at all. Judging from the electrical diagram, if the battery is flat there is no way to activate the battery relay to get the main battery connected to the battery bus. If the excitation battery had been the culprit, I guess an alternator warning light would have been very visible. |
#54
Recently, Friedrich Ostertag posted:
Neil Gould wrote: Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. Well said, and I wouldn't disagree. However, the very same potentially deadly failure could occur anytime the battery fails inflight, with no way for the pilot to know about it before he actually hits the button to lower the gear. That alone appears to me to be a major design flaw that would make me pretty uncomfortable, batteries are known to fail suddenly sometimes. I really would expect redundancy in something as critical as the power supply for the fadec to be a requirement for airworthyness. Why have two sets of magnetos on the typical SI-engine? It's just an electrical system, too... Why have a twin engined aircraft? I agree that a failure mode allowing in-flight engine shutdown due to low battery voltage implies that there may be an aspect of the design that needs attention. On the other hand, the dead battery could have been a symptom of a larger problem, and the existing design really is quite reasonable. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. If you are saying that a shut-down is to be expected when the power supply on a fadec controlled engine fails, you are right. No modern engine will continue running without electrical power. Even on a diesel with common rail fuel supply (as the thielert is) without electricity no fuel injection is possible. Right, however, the alternator should be able to supply the electricity needed to keep the engines running. It wouldn't surprise me to find that the a breaker had popped when the landing gear was retracted and the pilot didn't think to reset it. Neil |
#55
![]() "Neil Gould" wrote ... If the alternators weren't excited, wouldn't the pilot be looking at two alternator warning lights prior to take off? According to the AFM there are amber caution lights for alternator failure, so yes. Does the aircraft have an ampmeter? Again according to the AFM, yes, but notably, it is not on the MFD's default engine display page but on the "System" page together with the voltmeters. You need to push a button to see it. However, the checklist requires you to have a look at the "System" page after engine start as well as before take-off, so if the checklist is followed a fault would not go unnoticed. In the other scenario posited by the article, i.e. an unconnected main battery, things become interesting. In this scenario the ammeters would presumably show "normal" values, i.e the instantaneous consumption of the electrical devices. In this case the voltmeter would really be essential . The AFM says about the voltmeters: "Under normal operating conditions the alternator voltage is shown, otherwise it displays the 'main'-battery voltage." So the voltmeters presumably measure the bus voltage, and in this scenario (battery disconnected) they would probably show an abnormal voltage which could alert the pilot. I'm no expert here, but I seem to recall stories of batteries failing in-flight and how that can be seen from the voltmeter. Also, in this case, there seems to be no way of positively checking the actual, pure main battery voltage, because according to the schematic the main battery relay needs power from the battery itself to operate and connect to the battery bus. Or then I'm missing something...... |
#56
Recently, C J Campbell posted:
On 2007-04-23 11:20:24 -0700, "Neil Gould" said: Recently, Karl-Heinz Kuenzel posted: Neil Gould schrieb: I have a somewhat different take on this event. [...] I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. OK Neil. You find it in the article. My Deutsch is far too rusty to find it in the article. ;-) POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. That's fine for starting the engines, but that isn't the only issue, is it? Is there nothing in the POH about the electrically powered items (landing gear, FADEC, etc.)? If there is, it shouldn't require an EE degree to realize that one should be concerned about the condition of the batteries, charging, etc. if one has to "jump start" the engine, or to realize that something critical is in need of attention. Maybe I'm just an overly cautious type. ;-) Neil No, you are not overly cautious. Every pilot should be taught that if the battery is dead and you start the plane with external power, the first thing you check is to see if the alternator(s) is charging. If it isn't, either the alternator is broken or the battery did not excite the alternator. Now, if the excitation system did not excite the alternator, why didn't the remote starting system do it? It should have. I would want a look at the power cart, its cables, and the wiring to the port on the airplane. In fact, especially the latter, as it could provide a clue as to why the excitation battery died in the first place. If the alternators weren't excited, wouldn't the pilot be looking at two alternator warning lights prior to take off? Does the aircraft have an ampmeter? Neil |
#57
Thomas, et al,
I agree about our legacy systems having single points of failure (SPOF); but I would hope the new technology offered by FADEC would begin to eliminate those SPOFs without introducing new ones. It appears to me that we still have all of the legacy SPOFs and have now added new ones. Prior to FADEC we didn't even have to have an electrical system to make an engine run. -- Jim Carter Rogers, Arkansas "Thomas Borchert" wrote in message ... Jose, However, it does seem to be a serious oversight that the engines themselves can't supply their own juice. That will become totally common with FADEC engines. It's just DIFFERENT failure modes we have to be used to - our current old engines have single failure points, too. -- Thomas Borchert (EDDH) |
#58
![]() "C J Campbell" wrote ... Jose said: I don't know the system, so I can't second guess the engineers intellegently about it. However, it does seem to be a serious oversight that the engines themselves can't supply their own juice. They do -- with an alternator on each engine. There is also a generator. How predictable is the failure of two alternators, the batteries, etc? Chris, I do not see the Generator to which you keep refering. Each engine has a Starter Motor and an Alternator. The Airframe has a single Main Battery (10 amphour rated) and a series up Alternator Excitation Battery (1.3 amphour) used "in the event of a main bat failure" (Diamond quote in POH). From the article's diagram the magazine editor marked the excitation battery in RED. I am not good enough with technical German to read the article, maybe another reader can summerize the reason for the red highlight. http://img.edsb.airworkpress.com/red/da42/esys_big.gif http://www.pilotundflugzeug.de/artik...12/DA42_Unfall I am a bit confused how that excitation battery is normally charged and how the battery is monitored. I also note that the Ground Power system is pretty standard looking in the schematic, ie keep the Main Electric Master off and turn one Engine Master on for starting so as not to have the bad battery connected and draw down the Cart while cranking. But then what? You got your backup Battery excited Alternator running your ECU on that engine, but it looks like you need to keep the APU Cart connected because the power to activate the Alt relay can only come from the main bus side. Is this normal for other twins? |
#59
Recently, Snowbird posted:
"Neil Gould" wrote ... Does the aircraft have an ampmeter? Again according to the AFM, yes, but notably, it is not on the MFD's default engine display page but on the "System" page together with the voltmeters. You need to push a button to see it. However, the checklist requires you to have a look at the "System" page after engine start as well as before take-off, so if the checklist is followed a fault would not go unnoticed. I would think that this preflight requirement has implications for this accident. In the other scenario posited by the article, i.e. an unconnected main battery, things become interesting. In this scenario the ammeters would presumably show "normal" values, i.e the instantaneous consumption of the electrical devices. If the alternators are working, the ammeters should show a higher than normal postive value, as the battery is not putting a normal load on the charging system. That, too, would stop me from taking off. In this case the voltmeter would really be essential . The AFM says about the voltmeters: "Under normal operating conditions the alternator voltage is shown, otherwise it displays the 'main'-battery voltage." So the voltmeters presumably measure the bus voltage, and in this scenario (battery disconnected) they would probably show an abnormal voltage which could alert the pilot. I'm no expert here, but I seem to recall stories of batteries failing in-flight and how that can be seen from the voltmeter. Hmm. I'd think the alternator voltage would always be shown unless the engines aren't running, and then the bus voltage is shown. A look at the schematic could reveal which case is correct. Also, in this case, there seems to be no way of positively checking the actual, pure main battery voltage, because according to the schematic the main battery relay needs power from the battery itself to operate and connect to the battery bus. Or then I'm missing something...... I'd think that checking when the engines are not running would show the main battery voltage level. If the battery is dead, of course, the relay wouldn't have power to connect to the bus. Neil |
#60
Recently, Mike Isaksen posted:
"C J Campbell" wrote ... Jose said: I don't know the system, so I can't second guess the engineers intellegently about it. However, it does seem to be a serious oversight that the engines themselves can't supply their own juice. They do -- with an alternator on each engine. There is also a generator. How predictable is the failure of two alternators, the batteries, etc? Chris, I do not see the Generator to which you keep refering. On the schematic you're referencing, the Generators are the circular symbols with the 'G' and labeled as such. However, as the relay in the Generator circuit is labled "Alternator Relay", and there is an excitation circuit I suspect that the terms are being used interchangeably. Not technically correct, but... Each engine has a Starter Motor and an Alternator. The Airframe has a single Main Battery (10 amphour rated) and a series up Alternator Excitation Battery (1.3 amphour) used "in the event of a main bat failure" (Diamond quote in POH). From the article's diagram the magazine editor marked the excitation battery in RED. I am not good enough with technical German to read the article, maybe another reader can summerize the reason for the red highlight. http://img.edsb.airworkpress.com/red/da42/esys_big.gif http://www.pilotundflugzeug.de/artik...12/DA42_Unfall I am a bit confused how that excitation battery is normally charged and how the battery is monitored. The excitation battery has a direct feed from both generators (really alternators). If the fuse isn't blown, either alternator may be able to charge this battery from excitation feedback. There is no indication of how the battery condition would be monitored, but if neither alternator operates, the excitation battery would be highly suspect. Neil |
F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 06:19 PM |
Accident db? | [email protected] | Owning | 3 | July 25th 05 06:22 PM |
C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 06:52 PM |
MU2 accident | Big John | Piloting | 16 | April 13th 04 03:58 AM |
KC-135 accident | Big John | Piloting | 3 | November 19th 03 04:36 PM |
