#11
Jim Carter wrote:
C'mon Matt - power mowers are the way to go, but when they break it sure is nice to still be in shape to use the slingblade if we have to. That was my whole point. Our next EAA meeting is going to be on the old pilotage. Then in a couple of weeks, we will be given a short route to fly that is not over VORS, etc. Honor system not to turn on the GPS. Time and fuel burn will be recorded (by refilling at the destination). The destination is lunch and compare results. We will not know the route until that day. Should be fun. -- Regards, Ross C-172F 180HP KSWI |
(Paul Tomblin) writes: [...] I'm going to be taking the Dakota - and unlike the Lance, the Dakota has a Garmin 530W in it. Now normally, I'd pull out the route I have on my PDA in CoPilot, plot it on a couple of low altitude enroute charts, and file a flight plan on those airways. But with the GPS, I'm not sure how to proceed. [...] Why not do the exact same thing - follow the airways and make controllers' lives probably a little bit easier? - FChE |
"Jim Carter" wrote in message . .. C'mon Matt - power mowers are the way to go, but when they break it sure is nice to still be in shape to use the slingblade if we have to. That was my whole point. I would hope that making the "when the damn things quit" point would be rhetorical, just like when the engine quits, the radio quits, the vacuum punp pukes, the NAV radio goes "boink"... I can't see a G-V pilot keeping a sectional at their side :~) BTW, what is the MTBF of a ADHARS versus a vacuum pump? :~) Maybe our complaceny is more a matter of orders-of-magnitude better reliability they provide, than the copious amounts of data they give us. Call me careless/reckless, but if my system goes kablooie, I'd call ATC on the handheld I always carry, declare a loss of navigation instrumentation, and ask for vectors. I'm probably a bit testy, but I get tired of hearing the neo-Luddite alarms. Since there is no known instance in NTSB records of an accident after a nav system failure, it's likely our attention should be more on losing control when things ARE going well, such as CFIT, the (much) bigger source of accidents. Jim, I certainly hope you cut your grass with a slingblade. Oh, BTW, when I mowed my grass for the firs time this year, the mower pickup up a small rock and took out the glass in our sliding glass door for the patio. :~( -- Matt Barrow Performace Homes, LLC. Colorado Springs, CO |
"Frank Ch. Eigler" wrote in message ... (Paul Tomblin) writes: [...] I'm going to be taking the Dakota - and unlike the Lance, the Dakota has a Garmin 530W in it. Now normally, I'd pull out the route I have on my PDA in CoPilot, plot it on a couple of low altitude enroute charts, and file a flight plan on those airways. But with the GPS, I'm not sure how to proceed. [...] Why not do the exact same thing - follow the airways and make controllers' lives probably a little bit easier? Because that would NOT make their lives easier (due to congestion on the airways)? |
"Matt Barrow" writes: Why not do the exact same thing - follow the airways and make controllers' lives probably a little bit easier? Because that would NOT make their lives easier (due to congestion on the airways)? Where did you hear that this was a serious problem (for spam cans)? And just in case it were a problem any given day, a controller who sees a /G can issue a direct clearance as a "decongestant". - FChE |
Funny you should mention the G-V and sectional scenario Matt.
I had a couple of Cadets up in our CAP 182 this past February after we had been talking about VFR charts before the flight. We had nice weather so we were doing the KROG KFSM KROG seat change routine. After checking in with Approach and getting sequenced behind a BeechJet we heard our kerosene burning brethren call out "Hey Approach - what is that big river down there off our port wing?" to which Approach replied "According to my sectional, that's the Arkansas River". Utter silence... until some wanko keyed a mic and we could all hear laughing in the background. I used that as an abject lesson in always knowing where you are if for no other reason than not looking stupid. -- Jim Carter Rogers, Arkansas "Matt Barrow" wrote in message ... "Jim Carter" wrote in message . .. .... I can't see a G-V pilot keeping a sectional at their side :~) |
Ross wrote in
: Our next EAA meeting is going to be on the old pilotage. Then in a couple of weeks, we will be given a short route to fly that is not over VORS, etc. Honor system not to turn on the GPS. Time and fuel burn will be recorded (by refilling at the destination). The destination is lunch and compare results. We will not know the route until that day. Should be fun. Unless someone cheats by leaning. ![]() |
Back in the '70s when the colleges and universities all had flight schools
we used to have an annual competition on just this sort of precision flying and planning. Leaning for proper speed and power was essential because it was not unusual for the difference between first and second place to be measured in seconds deviation from planned time enroute and tenths of gallons of deviation from planned fuel burn. We also used to have spot landing contests which were usually won by the pilot that hit the exact spot the most times out of three or six or how many ever it took to separate first and second place. Those damn chalk lines were only about 3" wide - we used a baseline marker to lay them on the runway. The two lines were 3 or 4 inches apart and the trick was to miss the first line and hit the second so the target spot was only about 6 or 7 inches wide. -- Jim Carter Rogers, Arkansas "Judah" wrote in message . .. .... Unless someone cheats by leaning. |
Matt Barrow wrote:
I would hope that making the "when the damn things quit" point would be rhetorical, just like when the engine quits, the radio quits, the vacuum punp pukes, the NAV radio goes "boink"... Rhetorical? I've had every one of your scenarios happen to me more than once. They do happen, maybe to you. Lightning doesn't always strike the other guy. Bottom line: don't put all your eggs in one basket if you can help it. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
"Jim Carter" wrote in message ... Funny you should mention the G-V and sectional scenario Matt. I had a couple of Cadets up in our CAP 182 this past February after we had been talking about VFR charts before the flight. We had nice weather so we were doing the KROG KFSM KROG seat change routine. After checking in with Approach and getting sequenced behind a BeechJet we heard our kerosene burning brethren call out "Hey Approach - what is that big river down there off our port wing?" to which Approach replied "According to my sectional, that's the Arkansas River". Utter silence... until some wanko keyed a mic and we could all hear laughing in the background. I used that as an abject lesson in always knowing where you are if for no other reason than not looking stupid. Was he lost...or just curious? -- Jim Carter Rogers, Arkansas "Matt Barrow" wrote in message ... "Jim Carter" wrote in message . .. ... I can't see a G-V pilot keeping a sectional at their side :~) |
| Thread Tools | |
| Display Modes | |
| OSH flight plan | Dan Luke | Piloting | 3 | July 23rd 05 04:33 AM |
| Flight plan hell, Tales of filing an ADIZ flight plan | Michelle P | Piloting | 30 | July 15th 05 07:28 AM |
| IFR Flight plan | Hankal | Instrument Flight Rules | 9 | September 16th 04 06:39 AM |
| Flight Plan and Flight Log excel spreadsheet. | Marco Rispoli | Piloting | 2 | January 14th 04 10:12 PM |
| Flight plan | Hankal | Instrument Flight Rules | 15 | October 11th 03 09:03 AM |
