#21
Blueskies wrote:
"buttman" wrote in message oups.com... Today I was doing some touch and go's in a C152 with one of my students to prepare for his first solo. It was a very hot day (35C), but density altitude was only 2500 or so. I'm surprised no one mentioned gross weight... he didnt say mx was in it. ;~/ |
oups.com... Today I was doing some touch and go's in a C152 with one of my students to prepare for his first solo. It was a very hot day (35C), but density altitude was only 2500 or so. I noticed as we were climbing upwind, the plane was climbing very slowly, even right at Vy. The runway is very long (11,800 ft), but when we reached the opposite threshold, we were only about 500 AGL. Normally at the end of the threshold we are between 900 and 1000 AGL, and thats with switching to cruise climb after 500 AGL... Then when we got to downwind, my student pulled the power back to 2300 RPM (cruise) and we were only able to hold about about 70 knots (90 knots is normal). ... How did it fly later in the day after the pastic bag fell off the landing gear? :-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Apr 30, 3:54 pm, Jose wrote:
The magnet causes eddy currents in a bit of aluminum which causes the aluminum to have a magnetic field... Thanks. ![]() Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. The magnet spins inside an aluminum cup, and the cup drives the neele. No pulses generated, just a rotating current in the cup that generates an opposing field that drags the cup around against a small spring. Dan |
#24
On Apr 30, 10:47 am, "ManhattanMan" wrote:
ktbr wrote: carb ice... 150's can be very susceptable. Did you try to apply carb heat? @ 35º C ? Yes, at 35°C, though it won't be heavy icing. See this chart: http://www.carneyaviation.com/images/carbice.gif It all depends on the relative humidty (dewpoint for pilots). We've seen carb icing here on the dry prairies on summer mornings. And we often hear of accidents caused by carb ice because students aren't getting taught much about it and don't recognize it, nor do they think it's possible at high ambient temps. Ignorance kills way too many PPLs. Dan |
#25
ManhattanMan wrote:
ktbr wrote: carb ice... 150's can be very susceptable. Did you try to apply carb heat? @ 35º C ? The only time my old Lycoming ever iced up was on a beautiful summer day. Margy |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
Cessna 150 with 150hp engine performance | The Ponderosa | Owning | 0 | September 18th 04 06:14 AM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
High Performance Single Engine Choices | O. Sami Saydjari | Owning | 82 | January 6th 04 07:32 PM |
Hi-performance endorsment with a experimental engine | Paul Lee | Home Built | 15 | September 11th 03 12:00 AM |
