Skyhawk vs. Mooney
Old May 8th 07, 06:03 PM posted to rec.aviation.owning
Grant[_2_]
Default Skyhawk vs. Mooney
I was simply wondering if someone could break down the cost difference
of a 172 and M20. Obviously maintenance on a mooney is going to be a
little more and the fuel burn is a gallon or so more, so just some
thoughts.
Old May 8th 07, 06:51 PM posted to rec.aviation.owning
Robert M. Gary
thoughts.
Depends on the Mooney. The M20C has about the same full burn as the
Skyhawk (8 gal/hr) but does 150 knots vs. the 172's 100ish knots on
that fuel. The M20C also sells for about the same price as the 172.
However, a M20C is more maintenance than a 172 and requires an A&P
that has more specialized knowledge (all A&Ps know how to work on
172s). Also, insurance could be a big difference. The retractable gear
will cost you somewhere between $500 to $2000 per year additional
depending on the amount of retract time you have.
A couple things to check for in a Mooney...
1) Fuel leaks. Mooneys have no fuel tanks, just sealant on the skin to
hold fuel in. Every so many years an owner is well advised to go into
the tanks and freshen up the sealent. If you are very rich you may pay
someone to totally replace the sealant but that is rarely required.
2) Gear actuator. If the Mooney you are looking at has electric gear
make sure the AD has been complied with the check the actuator gear.
Technically this is a recurrent AD but if the gears aren't chewed up
the first time you look, chances are you didn't get the bad lot and
will be good forever.
3) Also, if you fly more than 100 hours a year, you will end up having
to do an annual every 100 hours. There is an AD that requires all
flight control connections and gear sections to be lubed every 100
hours. There is really no way to do this without totally taking the
plane apart (figure 10 hours of your time to remove all the panels
unless you have a one-piece belly). By the time you pull all the
panels off to lube you've basically set up for an annual anyway. Some
A&Ps consider this unnecessary and will sign off the 100hr ADs for 3
hours of labor, but there is no way they are actually meeting the
strict requirements of the AD in that time. However, know that there
are many Mooney owners out there that haven't properly lubed their
plane in 10 years and are flying all the time so you aren't going to
fall from the sky.
-Robert, CFII (and Mooney instructor)
Old May 8th 07, 07:41 PM posted to rec.aviation.owning
Al G[_2_]
thoughts.
fall from the sky.
The M20C also has a wooden wing doesn't it?
Al G, Mooney record holder
Old May 8th 07, 08:00 PM posted to rec.aviation.owning
Dave Butler
hours.
What AD is that? I'm not aware of that. Is it model-specific?
The only ones on my list a
inspection of fuel injector fuel lines required by AD 2002-26-01
inspection of Bendix magneto ignition switch required by AD 76-07-12
inspection of Bendix magneto impulse coupling required by AD 96-12-07
Dave
Old May 8th 07, 08:05 PM posted to rec.aviation.owning
flynrider via AviationKB.com
Nope. The M20Cs are all metal. I think the last wood-winged version was
the M20A in 1960.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200705/1
Old May 8th 07, 08:48 PM posted to rec.aviation.owning
Tri-Pacer
Default fuel burn was Skyhawk vs. Mooney
" Depends on the Mooney. The M20C has about the same full burn as the
How many of you guys really see 8 GPH with your O-320s.
I'd like to know your secrets.
Cheers:
Paul
N1431A.
Old May 8th 07, 10:57 PM posted to rec.aviation.owning
Ken Reed
The M20C has about the same full burn as the Skyhawk (8 gal/hr).
The Mooney M20C has an O-360 and I saw 8.5 GPH at 147 KTAS regularly
with the one I owned.
Ken Reed
M20M, N9124X
Old May 8th 07, 10:58 PM posted to rec.aviation.owning
Ken Reed
Ken Reed
M20M, N9124X
Old May 9th 07, 03:03 AM posted to rec.aviation.owning
Jay Somerset
Cheers:
Paul
N1431A.
Easy -- I learned how and when to lean the mixture, and on cross-countries,
to fly at higher altitudes. C172P (1981 w/ O-320).
Jay.
(remove dashes for legal email address)
Old May 9th 07, 03:07 AM posted to rec.aviation.owning
Steven Barnes
The little red knob...
"Tri-Pacer" wrote in message
Cheers:
Paul
N1431A.
A4-B Skyhawk Dave Kearton Aviation Photos 0 March 2nd 07 01:04 AM
Photos of 1:48 TA-4K Skyhawk [email protected] General Aviation 12 February 17th 05 03:39 PM
Photos of 1:48 TA-4K Skyhawk [email protected] Restoration 12 February 17th 05 03:39 PM
A-4 Skyhawk is 50 today José Herculano Naval Aviation 7 June 27th 04 04:28 AM
Skyhawk A4-K Weapons fit? Ian Military Aviation 0 February 18th 04 02:44 AM
