Stafford VA?
Old May 9th 07, 10:08 PM posted to rec.aviation.piloting
Marco Leon
Default Stafford VA?
Anyone fly into Stafford on an IFR flight plan? I'm planning on going there
this weekend and I was wondering if there were special procedures
considering it's so close to the ADIZ. Do IFR flights keep their squawk
until touchdown just in case? I'm coming from the NY area. I'd appreciate
any feedback on the cleared route from the northeast. Do they normally route
you around the ADIZ or just around the FRZ?
Thanks,
Marco
Old May 10th 07, 12:59 AM posted to rec.aviation.piloting
BT
There is a handout on the AOPA web site for flying near in and around the DC
ADIZ
http://www.aopa.org/whatsnew/newsite...1403_check.pdf
Also check out the online training program at FAAST
http://faasafety.gov/gslac/ALC/cours...?categoryId=11
BT
"Marco Leon" wrote in message
there this weekend and I was wondering if there were special procedures
route you around the ADIZ or just around the FRZ?
Thanks,
Marco
Old May 10th 07, 02:31 AM posted to rec.aviation.piloting
John T
procedures considering it's so close to the ADIZ. Do IFR flights keep
their squawk until touchdown just in case? I'm coming from the NY
area. I'd appreciate any feedback on the cleared route from the
northeast. Do they normally route you around the ADIZ or just around
the FRZ?
There aren't any special procedures I know of.
First, the ADIZ is transparent to IFR fliers, so you should have little to
worry about there. Depending on how you enter the ADIZ, you'll likely get
the "Grand Western Tour" or the "Eastern Shore Tour" around the FRZ and away
from KBWI/KIAD traffic. I've actually gotten routed directly over KIAD/AML
twice in the last six years, so it is possible.
If you're at all concerned about go-arounds or missed approaches getting you
anywhere near the ADIZ boundaries, just keep your code until you're down or
cancel on the ground.
(Also, as you probably know, flights into ADIZ airports do keep their squawk
until on the ground.)
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old May 10th 07, 05:49 PM posted to rec.aviation.piloting
Marco Leon
"John T" wrote in message:
away from KBWI/KIAD traffic. I've actually gotten routed directly over
KIAD/AML twice in the last six years, so it is possible.
you anywhere near the ADIZ boundaries, just keep your code until you're
down or cancel on the ground.
squawk until on the ground.)
Thanks John. I've flown into airports within the ADIZ already but RMN is a
bit weird in that it butts up right against the ADIZ. I have visions of
having to do an extended pattern or something then inadvertently clipping
the ADIZ. Your recommendation of keeping the squawk code is a good one.
Thanks.
Marco
Old May 11th 07, 04:03 PM posted to rec.aviation.piloting
John T
is a bit weird in that it butts up right against the ADIZ. I have
visions of having to do an extended pattern or something then
inadvertently clipping the ADIZ. Your recommendation of keeping the
squawk code is a good one. Thanks.
FWIW, locals tend to keep the ADIZ squawk for a few miles when leaving the
ADIZ - even if ATC comes confirms we're outside.
John T
Old May 14th 07, 04:40 PM posted to rec.aviation.piloting
Marco Leon
I actually did just that and kept my squawk until I landed. I figured it
can't hurt and only help. As an aside, the routing they gave me to RMN was
changed to a shortcut with a direct-to to Nottingham (OTT). It put me *very*
close to the FRZ. I had my Garmin 496 with the XM-provided TFR data so I had
the equipment to stay clear but I requested a slightly better vector anyhow
to be sure. I also wanted it on record that I was cognizant of the FRZ in
case anything gets screwed up.
Thanks for the tips John.
Marco
Lancair down near Stafford Wiz Piloting 7 February 25th 06 07:30 PM
