Hangar Design
Old May 10th 07, 03:14 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default Hangar Design
Our EAA chapter is perpetually scheming for ways to acquire a hangar for
member aircraft and for chapter activities. Obviously, any reasonably sized
hangar requires a substantial outlay of funds. The cost issue seems to be
the big hold-up right now.
Anyway, we're looking at a variety of pre-engineered metal building options
for a 50x60 (approx) hangar, but would consider a "homebuilt" alternative if
we could come up with a design that would be functional (it would need to
meet code and have decent aesthetics), more affordable than commercially
purchased alternatives, and that could be built by your typical group of
enthusiasts.
Thoughts? Suggestions?
By the way, the hangar would be at a public airport, and we've been directed
by the airport authority that Quonset hut type shelters or bigger versions
of portable garage type buildings will not get their approval. I suspect
that what they really want us to build is a commercially purchased hangar,
but until they rule out other alternatives, we're gonna pursue all viable
options.
Old May 10th 07, 04:04 AM posted to rec.aviation.homebuilt
Lou
Well, there may be a different way, but I can tell you that as a
carpenter
I estimated building my own hanger instead of ordering one. The cost
difference
was minimal. The part that was a money saver was the hanger door.
Instead
of paying the big money for a folding door, I came up (on paper) with
a panel
system very similiar to the glass doors you see at malls that fold up
into a pocket.
The doors would be made of plywood and each one would have a barrel to
set into
the concrete floor. In other words, you will probebly be better off
with a commercial
building.
Lou
Old May 10th 07, 04:14 AM posted to rec.aviation.homebuilt
Kyle Boatright
"Lou" wrote in message
ps.com...
carpenter
difference
Instead
a panel
into a pocket.
set into
with a commercial
building.
Lou
I tend to agree - a metal box on a concrete floor is a pretty basic and
inexpensive structure, when you consider that it gives you something that
should be windproof, waterproof, and should hold up well for a long time if
basic maintenance is done. On the other hand, there is always the chance
that someone has figured out a hangar design is labor intensive but not
capital intensive. That might work for us. So I'm compelled to ask.
KB
Old May 10th 07, 04:44 AM posted to rec.aviation.homebuilt
Michelle P
enthusiasts.
options.
Kyle,
50X60 steel building will cost around $50,000 for the building. Erecting
it would be around $30,000.
check out R&M steel. http://www.rmsteel.com/
We have two of there building and will have a third soon.
Michelle
Old May 10th 07, 04:54 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"Kyle Boatright" wrote
On the other hand, there is always the chance that someone has figured out
a hangar design is labor intensive but not capital intensive. That might
Something way different, seen in these links...
Benifits are strong resistance to wind and earthquake, and different enough
that you will generate some community interest.
http://www.domtec.com/process.html
http://www.greenhomebuilding.com/manufactured_systems.htm
http://www.ysmforbuilding.com/domecrete1.htm
Jim in NC
Old May 10th 07, 06:15 AM posted to rec.aviation.homebuilt
Montblack
("Morgans" wrote)
enough that you will generate some community interest.
Well, that's two and a half hours of sleep I won't be getting tonight.
Thanks a lot Jim in NC!!!!
Montblack
Must stop reading....
Must sleep....!
Old May 10th 07, 08:36 AM posted to rec.aviation.homebuilt
KyleOn May 9, 7:14�pm, "Kyle Boatright"
member aircraft and for chapter activities. *Obviously, any reasonably sized
enthusiasts.
of portable garage type buildings will not get their approval. *I suspect
options.
Kyle -
Our chapter (www.eaa32.org) went through the same drama several years
ago. While we were debating the budget vs. construction type issue,
one of our members got a lead on an existing 40' X 100' metal building
that was scheduled to be torn down for new highway construction. In
fact, it had been the State DOT's field office for the project, and
was on land owned by a local hotel chain. Being organized as a 501(c)3
not-for-profit corporation that made it possible for them to donate
the building to us and take a tax right off.
When we got the green light from the hotel firm, we put out the call
for all able bodied members to come out to disassemble the building,
and stuff the salvagable material into some rented trailers, and
hauled them up to our county airport location. One member fortunately
had access to a mobil crane which was needed to disassemble the metal
frame and load onto a flatbed. Incredibly, we accomplished all this in
less than three weeks with a bunch of part-timers. At this point
everyone thought we were almost (in our) home. Reality set in when we
discovered that before ground breaking, we had to:
1. Negotiate a favorable long term lease for the land with the county.
2. Hire a professional engineering firm to design a new foundation.
3. Make new plans for the interior.
4. Buy a fold-up door (included engineering modification to building
frame)
5. Get plans approved by eight agencies, including FEMA because it is
located in a flood plain.
Because we decided to rebuild it ourselves, it took about two years to
go through the above, and then about four years of Saturdays to get to
where we could lock the door (like a homebuilt, we can't say it's
really complete, but it's usable). Most of the building process is
documented on our website under "ARC" which officially stands for
Aviation Resource Center, but some wags opine that being in a flood
plain suggests something else. One important caveat as part of the
negotiation with the airport is that the ARC was not to be used of
long term storage of airplanes. This turned out not to be an issue b/c
we basically need all the available space for meetings and short term
aircraft use at critical completion points.
We learned a lot, many of us had to readjust our saturdays after the
construction was complete, and in spite of the occasional ruffled
feather, I would say that most found it an enjoyable experience. And,
after years of yakking about it, we finally have a home.
If any chapter wants to do anything like what I've described here, I
will be glad to pass on our experience in the form of what to do, or
not do, as the case may be based on our experience. BTW, if you can't
find a friendly building donor, there are some buiding component
companies around I can steer you to to get the lowest starting cost if
you want to do it with "sweat equity" like we did. We ended up going
to them for many components because some stuff just wasn't reusable.
Doug Killebrew
Construction Manager, EAA 32, (Ret)
Old May 10th 07, 12:04 PM posted to rec.aviation.homebuilt
Dick[_1_]
To second item #1 below..
An insufficiently long enough term lease bit our chapter badly at a city
airport. Even though totally financing/constructing our
shop/hanger/building, after 25 years we "lost" it to the city. Our rent went
from $0 to almost $300/ month. Be aware that city airport commissions can
change easily from GA/experimental friendly to not. We lost every
discussion over the last 4 years and now spend most of our time chasing
revenue to cover our expenses....As I understand, the land was leased for 20
years at no rent and our building became theirs afterwards for us to rent
like other hangers on the field. ie: no "break" to EAA chapter.
KyleOn May 9, 7:14?pm, "Kyle Boatright"
sized
options
if
enthusiasts.
directed
options.
Kyle -
frame)
Doug Killebrew
Old May 10th 07, 01:20 PM posted to rec.aviation.homebuilt
Denny
The biggest hurdle that do it yourselfers I have that tendency will
face is that most airport authorities will insist upon a stamped
engineering report designating snow load, wind rating, earthquake
rating, and fire rating..
That pretty much eliminates any homebuilt wood hangars, etc..
My current business venture requires a clear span 60 x 125 foot
building with 30 X 16 door openings at each end... Burning the
midnight oil heavily and getting multiple quotes on everything from
wood truss and I even calculated out for a stick building done by
myself with undocumented workers to slip formed concrete, it came
down to a steel building as the most economical...
denny
Old May 10th 07, 05:11 PM posted to rec.aviation.homebuilt
Al G[_2_]
"Michelle P" wrote in message
ink.net...
sized hangar requires a substantial outlay of funds. The cost issue seems
to be the big hold-up right now.
options for a 50x60 (approx) hangar, but would consider a "homebuilt"
alternative if we could come up with a design that would be functional
(it would need to meet code and have decent aesthetics), more affordable
than commercially purchased alternatives, and that could be built by your
typical group of enthusiasts.
directed by the airport authority that Quonset hut type shelters or
bigger versions of portable garage type buildings will not get their
approval. I suspect that what they really want us to build is a
commercially purchased hangar, but until they rule out other
alternatives, we're gonna pursue all viable options.
Kyle,
Michelle
I'm helping a local EAA partnership put one of these up in RBG. It is an
80' X 80' and the receipt was for $47,500, delivered(I think we are getting
the door from someone else). It is going together like a big erector set,
and things fit very well. I've built pole barns before, and this is a piece
of cake.
Al G
3D design island life Rotorcraft 4 October 23rd 05 01:31 AM
DR-107 One Design [email protected] Aerobatics 0 October 12th 05 09:45 PM
3D design island life Rotorcraft 0 September 13th 05 02:36 PM
old gyrocopter design? E. Glaser Rotorcraft 1 August 9th 05 03:52 AM
Strop design Edward Weaver Soaring 3 July 20th 05 06:03 PM
