Garmin 396 24-volt power?
Old May 10th 07, 04:37 AM posted to rec.aviation.piloting
Dan[_1_]
Default Garmin 396 24-volt power?
Does anyone know if the cigarette lighter plug that comes with the
Garmin 396 can be used on a 24-volt system (assuming it would
physically fit) The manual is vague on this.
--Dan
Old May 10th 07, 05:42 AM posted to rec.aviation.piloting
BT
Is the 24Volt system stepped down to 12Volt for the Cig lighter?
Check the auto/aircraft manual for that one.
There are not too many appliances that are ready to plug into 24Volt
systems.
Could always "smoke check" with a cheaper appliance.
BT
"Dan" wrote in message
--Dan
Old May 10th 07, 05:46 AM posted to rec.aviation.piloting
Aluckyguess
Yes it can.
--Dan
Old May 10th 07, 05:57 AM posted to rec.aviation.piloting
karl gruber[_1_]
What is vague about "Power source: 11-35 VDC"
Karl
--Dan
Old May 10th 07, 04:54 PM posted to rec.aviation.piloting
Jon Woellhaf
In my 28 volt plane the cigar lighter jack was wired in series with a low
ohmage power resistor. This was undoubtedly to allow the use of a standard
car-type 12 volt heater element in the lighter. With a GPS plugged into the
jack, I got 28 volts.
"BT" wrote in message
Old May 12th 07, 05:45 AM posted to rec.aviation.piloting
Dan[_1_]
That is for the unit. Garmin calls the cigarette lighter adaptor the
"12-volt" adaptor. Sounds like it should be called the "11-35V
adaptor". Perhaps ambigous would be a better word than vague.
--Dan
Karl
--Dan- Hide quoted text -
- Show quoted text -
Old September 30th 10, 01:42 PM
hlprises hlprises is offline
Junior Member
First recorded activity by AviationBanter: Sep 2010
systems.
BT
--Dan
The Garmin 296, 396, and 496's are between 12 and 30 volts you don't have to step that down at all. just plug it in. Some cell phones and pdas you might burn up without a step down resister but for the most part there are a lot of items out there that will used more than 12 volts.
Volt/Ammeter ccwillwerth Home Built 0 January 19th 06 02:38 AM
WTB: Power or cigarette lighter cable for Garmin GPS195 Larry Rachman Aviation Marketplace 1 December 22nd 04 08:47 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
5 volt DC power converters John Ferguson Soaring 6 February 28th 04 07:15 AM
24/12 volt DC converter Victor J. Osborne, Jr. Products 1 February 18th 04 02:11 PM
