I have yet to decide what epoxy to use on my steel fuselage, so I have
no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike |
Michael Horowitz wrote: I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike For steel (or any metal, for that matter), you have to remove all oils/greases. A wipe down with lacquer thinner, MEK, alcohol, etc. will do this. Look for a clean-looking cloth or paper towel. You should also remove any welding scale, which consists of oxides of iron before priming. This process usually involves fine-particulate (glass beads are best) blasting of welded areas to clean the metal. As soon as the metal is clean, apply two-part epoxy primers. Wear appropriate breathing protection, as the stuff is cumulatively toxic and allergenic. |
![]() Wear good quality gloves which are resistant to the chemicals you will be using. I would not use alcohol because it contains water. The water in the alcohol can cause flash rusting. Acetone is a little kinder to the body than MEK. MEK and Acetone are both flammable, so be careful. Orval has given very sound advise. Wear eye protection. |
![]() "Michael Horowitz" wrote in message ... I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike I would suggest a stainless steel rotary brush and a high speed grinder, if you can't bead blast the weld areas. Clean the areas to be brushed thououghy with MEK or acetone before brushing, and clean the brush often in MEK or acetone, to avoid spreading any oil or grease. Change wiping cloths or paper towels often to avoid any build up in your cloth. |
I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike Bare metal. Abrasive then wipe with denatured alcohol, Acetone or MEK depending on if anything is left. They are all in the same family. Alcohol being the mildest and MEK the strongest. Nitrile glove are a must for all phases of the prep. Respirator is a good idea as well. Eye protect is always a good idea. Michelle |
After reading this I have a question for those who have gone through this
process. I have a freshley welded steel tube fuselage with no surface rust at all. Is is necessary to sandblast the whole thing then prime or can I use scuffs and emery with the stainless brush mentioned? Seems like media blasting with sand or glass is a bit harsh for a new fuselage. What do they do at maule? All that needs to be removed is the dark mill scale and epoxy, from what I've heard will stick to almost anything. "Ebby" Hatz Classic s/n37 NY "Michelle P" wrote in message ink.net... Michael Horowitz wrote: I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike Bare metal. Abrasive then wipe with denatured alcohol, Acetone or MEK depending on if anything is left. They are all in the same family. Alcohol being the mildest and MEK the strongest. Nitrile glove are a must for all phases of the prep. Respirator is a good idea as well. Eye protect is always a good idea. Michelle |
"Ebby" wrote: After reading this I have a question for those who have gone through this process. I have a freshley welded steel tube fuselage with no surface rust at all. Is is necessary to sandblast the whole thing then prime or can I use scuffs and emery with the stainless brush mentioned? Seems like media blasting with sand or glass is a bit harsh for a new fuselage. What do they do at maule? All that needs to be removed is the dark mill scale and epoxy, from what I've heard will stick to almost anything. I don't know what they do at Maule, but you need to have metal under the epoxy -- not oxides of iron. Bead blasting the discolored areas around the welds is a good way to remove any extraneous oxides that could crack and attract water. The most important part of the prep is to remove all traces of oils and grease (including those from hands) before priming. An airbrush is a good way to apply primer, as it has a narrow pattern and will not waste too much expensive paint and primer. |
Ebby wrote:
After reading this I have a question for those who have gone through this process. I have a freshley welded steel tube fuselage with no surface rust at all. Is is necessary to sandblast the whole thing then prime or can I use scuffs and emery with the stainless brush mentioned? Seems like media blasting with sand or glass is a bit harsh for a new fuselage. What do they do at maule? All that needs to be removed is the dark mill scale and epoxy, from what I've heard will stick to almost anything. "Ebby" Hatz Classic s/n37 NY "Michelle P" wrote in message ink.net... Michael Horowitz wrote: I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike Bare metal. Abrasive then wipe with denatured alcohol, Acetone or MEK depending on if anything is left. They are all in the same family. Alcohol being the mildest and MEK the strongest. Nitrile glove are a must for all phases of the prep. Respirator is a good idea as well. Eye protect is always a good idea. Michelle I have a powder coated airframe in my Maule. It is my understanding that bright shiny metal is achieved before the coating is applied. Michelle |
In anticipation of your answers I did a major spring clean of the garage
this weekend so I can set up a blasting/paint shop later on this summer. I was just hoping I could get by without chewing into all that new metal. My advisor at my EAA chapter tipped me off about using an airbrush. Hearing it again helps. Thanks for the advice. Ebby "Michelle P" wrote in message link.net... Ebby wrote: After reading this I have a question for those who have gone through this process. I have a freshley welded steel tube fuselage with no surface rust at all. Is is necessary to sandblast the whole thing then prime or can I use scuffs and emery with the stainless brush mentioned? Seems like media blasting with sand or glass is a bit harsh for a new fuselage. What do they do at maule? All that needs to be removed is the dark mill scale and epoxy, from what I've heard will stick to almost anything. "Ebby" Hatz Classic s/n37 NY "Michelle P" wrote in message ink.net... Michael Horowitz wrote: I have yet to decide what epoxy to use on my steel fuselage, so I have no literature on how to prep the metal. Part of my decision making is _where_ to do the work. If I have to use MEK or like solvent, I don't want to do the work in a semi-enclosed area; if a dry wipe-down or alchol is sufficient, then my work-place of choice is OK. Assuming I"ve brought to fuselage back to bare metal and have used emery cloth so there exists a 'tooth' to the metal, does metal prep require the use of MEK or acytone prior to primer application? - Mike Bare metal. Abrasive then wipe with denatured alcohol, Acetone or MEK depending on if anything is left. They are all in the same family. Alcohol being the mildest and MEK the strongest. Nitrile glove are a must for all phases of the prep. Respirator is a good idea as well. Eye protect is always a good idea. Michelle I have a powder coated airframe in my Maule. It is my understanding that bright shiny metal is achieved before the coating is applied. Michelle |
T-88 epoxy | Lou | Home Built | 1 | December 4th 06 11:15 PM |
Epoxy for Fuel Tanks | Doug Palmer | Home Built | 1 | April 12th 06 02:53 AM |
EPOXY GLUES | minot piper e | Restoration | 0 | January 30th 04 01:13 AM |
epoxy aircraft seats? | Lpmcatee356 | Home Built | 26 | December 3rd 03 11:16 PM |
