Several pilots found themselves in a debate at our field yesterday. The
issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? |
"Doug Palmer" wrote in message ink.net... Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? There is potential for damage to a vacuum pump if turned backward. |
Doug Palmer wrote:
The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. It doesn't "disarm" it, it just won't fire. This means than the engine is less likely to start if the mags are hot (since the impulse coupling aids in the starting). However, NEVER trust a propeller. Even turning them backwards can generate a spark and even if the engine doesn't start it can kick the prop over enough to do damage. The argument against it is that people claim it hurts the vacuum pump. While some dry pumps are designed to only turn one way, that's at operating speed. The vanes are in there loose enough when it's not spinning to not be a problem. Except when absolutely necessary (like to get the tow bar connected) you shouldn't be turning the prop at all. There's no good reason to justify the dangers. |
Except when absolutely necessary (like to get the tow bar connected) you shouldn't be turning the prop at all. There's no good reason to justify the dangers. Partly, just to be a smart-ass, and also looking at the geometry, that could be one of the worst times to turn the prop... In reality, as already pointed out, that is one of the times when it could be necessary. At the very least, I would verify that all controls (especially throttle and mixture) are all the way back and that all appropriate switches are off--and then try to stay out of the prop arc while working. That should minimize the personal danger and (hopefully) eliminate the possibility of one of those "Voracious Airplane Eats Tractor" type accidents that circulate forever on the internet. Peter |
"Doug Palmer" wrote in message ink.net... Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? This is one issue where you don't want to get bogged down in the technicalities involving vacuum pumps and impulse couplings. The bottom line on this issue is that you should NEVER.....EVER...... trust a propeller not to kill you if you turn it by hand IN EITHER DIRECTION while it's attached to the airplane. Dudley Henriques |
Ron Natalie wrote:
The argument against it is that people claim it hurts the vacuum pump. That was what I was taught many moons ago. I have never confirmed it, but my brain tells me that the engine is designed to turn in one direction, so don't turn it in the other. No real proof (I'm not an A&P and have never played one on TV), but just my own logic. Except when absolutely necessary (like to get the tow bar connected) you shouldn't be turning the prop at all. There's no good reason to justify the dangers. If the engine is properly shutdown (boost pump off, throttle slightly above idle, and mixture to cut off) the chances are greatly reduced than if you just kill the engine by turn off the mags. Additionally, some people recommend checking your mags before shutdown to make sure you don't have a broken P lead which would also help. A flying club I used to belong to had a "policy" (not a rule, just a suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. Obviously the safest way to prevent an accidental fire while hand turning the prop is to not do it. When I do turn a prob by hand, I try to do it in the direction it turns while running, turn slowly to minimize any compression (don't know if that is true either, just what I was taught), and only use the palms of my hand on the face of the prop to minimize the possibility of the prop smacking the back of my hand should it fire. YMMV. -m -- ## Mark T. Dame ## CP-ASEL, AGI ## insert tail number here ## KHAO, KISZ "A programmer and his mind are soon parted." |
The magneto cannot generate a spark when turned slowly backward, and it's not just because the impulse coupling doesn't work backwards. The magnet could generate a flow in the primary winding, but the points are closing rather than opening at the right time and the arresting of the flow, a requirement for spark, isn't there. Further, the distributor is geared to send a spark to a cylinder based on a particular direction, and turning some reversible mags backward can generate a spark but it happens when the distributor finger is in the wrong place. Besides, the mag has to be turning at a good clip to make any spark without the impulse coupling. Worn-out vacuum pumps could indeed fail if turned backward, but they don't belong on the airplane anyway. We use the pumps with the wear inspection ports so that they never get to that vulnerable stage. A good pump can be turned backward without fear of breaking anything. So we teach our students to turn the prop backward, but that it must be done with great caution as a matter of course. Most of them don't understand magnetos or engines or anything else and might someday turn the thing in the wrong direction, and you have to make such rules so that they learn that props can kill and so they will keep their friends from fooling with it. We never lose a vacuum pump, have never had an inadvertent firing. The most dangerous time is right after the engine is shut down, when hot carbon in the cylinder head could fire any vapors still present. We also check the mag grounding at idle just before mixture cutoff. Dan |
suggestion that it would be nice if you did it) of turning the prop vertical after parking it to keep the birds from sitting on it and pooing on the plane. We turn the prop vertical in the winter to prevent water from pooling inside the spinner and then freezing into a block of ice. This happened to me once, and the vibration it caused was impressive. We shut down, pulled the plane into a heated hangar, turned the prop vertical, and waited for the ice to melt and drain out. |
"Dudley Henriques" wrote: "Doug Palmer" wrote in message ink.net... Several pilots found themselves in a debate at our field yesterday. The issue is weather it is safer to move the propeller on a (parked) aircraft in the direction of usual engine rotation, or opposite usual rotation. This is assuming that the propeller needs to move for some reason. The reasonings ranged from "you should not turn an engine backwards" to "turning the engine backwards disarms the impulse coupling", to several issues in between. Any thoughts from the groups collective wisdom? This is one issue where you don't want to get bogged down in the technicalities involving vacuum pumps and impulse couplings. The bottom line on this issue is that you should NEVER.....EVER...... trust a propeller not to kill you if you turn it by hand IN EITHER DIRECTION while it's attached to the airplane. Dudley Henriques Some engines (I'm thinking Rotax in particular) are highly allergic to turning the prop backwards. On a Rotax, it introduces air into the oil galleys, which can result in premature engine failure. I subscribe to the following precautions: 1. Check mag grounding prior to shutdown. 2. shut down with idle cutoff and throttle at idle. 3. If you turn the prop, do so in a way that it will not strike either you or anything (or anyone else) if it kicks off. I actually had a prop hit me from residual compression (no ignition) one time. |
Barry wrote:
We turn the prop vertical in the winter to prevent water from pooling inside the spinner and then freezing into a block of ice. This happened to me once, and the vibration it caused was impressive. We shut down, pulled the plane into a heated hangar, turned the prop vertical, and waited for the ice to melt and drain out. As do we. Same name, same reason. G |
| Thread Tools | |
| Display Modes | |
| I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 07:39 PM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
