What's the best auto gas for a/c use in California?
Old September 14th 03, 10:24 PM
Default What's the best auto gas for a/c use in California?
O.K. guys ..
Anybody have any knowledge of which widely available mogas in
California has the least amount of alcohol, MBTE (or whatever?) in it?
Going to be using it in a 2 cycle engine in my motor glider, and
really don't want anything except just plain old gasoline!
Thanks for any input,
D.R. Smith
Old September 15th 03, 07:39 AM
Bruce A. Frank
Nothing wrong with MTBE. Gasoline has, at times, always had some of it
in the formula. From the stand point of burning it in the engine, unlike
alcohol, I know of no detrimental effects. In CA the only choice for the
oxygenation ingredient right now is MTBE or Alcohol. Alcohol in aviation
fuel has been shown to cause problems. Unlike gasoline, and its usual
components, MTBE tends to never stabilize when leaked into the soil.
MTBE continues to travel, is not "detoxified" by bacteria in the soil,
and goes into the water table. Also appears to be a link to contaminated
lakes due to boat motor fuel and also unburned MTBE making it into the
atmosphere to become a component of rain. There is also a strong
investigative link between increased use of MTBE and increased asthma in
children. But as a fuel, gasoline with MTBE is just fine. B^)
Oh, BTW, MTBE was voted out of our gasoline 3 years ago, and Gray Davis,
by executive order has allowed it to remain. There are over 100 towns in
CA that now have ground water supplies that can no longer be used due to
MTBE contamination (a suspected carcinogen) and the state pays for
trucked in water in those areas. For a very minor benefit in possible
air pollution levels the untested, from an environmental standpoint,
MTBE was mandated. The damage to the people and the environment has
proven to be much worse than anything expected if auto fuel had remained
unchanged.
O.K. guys ..
D.R. Smith
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
\(-o-)/ AIRCRAFT PROJECTS CO.
\___/ Manufacturing parts & pieces
/ \ for homebuilt aircraft,
0 0 TIG welding
While trying to find the time to finish mine.
Old September 15th 03, 07:47 AM
COUGARNFW
A couple months ago, after a friend noticed that the sign: "..we no longer use
MTBE..." by Union Oil at Union stations was accompanied by a tiny, tiny sign on
the pumps that "...we might be using alky..", I wrote to Union asking if they
were using alky and how much if so.
I was shocked to get back the message that said this: "we no longer make
gasoline because we sold all our refineries years ago, so we buy fuel from
other makers, and we have no idea what is in the fuel".
Doesn't that give you a warm feeling? Union used to be the best in calif, now
they are just another greedy reseller with no responsibility for their
"product".
In tests we have made using the water shake, we have found that the gases
tested all have about 5 percent alky.
Good luck on finding out anything different. And let us know if you do find
someone but time is running out.
Neal
Old September 15th 03, 02:48 PM
Ben Haas
Hey,, That Gray Davis guy sounds like real smart guy.g. If you ever
did a chemical analysis of gasoline you would freak at all the
substances in it. Refiners still make the simple stock but all the
different resellers add their own additives. It is like food, the
basic stuff is safe in moderation. it is all the preservatives that
will kill ua all.
Ben Haas N801BH
"Bruce A. Frank" wrote in message ...
unchanged.
O.K. guys ..
D.R. Smith
0 0 TIG welding
Old September 15th 03, 10:53 PM
Ron Natalie
"Treetopper" wrote in message ...
I understand no auto gas is safe for use in california (AGL) between Sept
and Feb. due to pumping it full of air or some other oxygenating process.
This tends to cause the engine to run extremely lean beyond managmento
levels in flying 2 stroke engines and some 4 stroke engines. Pistons are not
in themselves all that expensive to replace, its the repair to the landing
gear and airframe and hospital bills that kill you.
How about some facts? The oxygenates aren't "pumping things full of air."
It's a specific additive (reformuation) to the fuel. Currently threre are two
popular ones. MBTE and Ethanol. Ethanol is NOT approved for autogas
STC'd aircraft. There are problems with both corrosiveness and interaction
with rubber to solve. MBTE is fine, but it's disappearing because it's a lot
more toxic and due to he absolutely abysmal status of most underground
gas storage tanks, it's a significant pollution risk.
Old September 16th 03, 07:32 AM
Bruce A. Frank
The really stupid part about all of this is that the oil companies say
that they now have the ability to formulate gasoline that matches the
clean burn levels required without the necessity of adding either MTBE
or alcohol...but the Feds MANDATE alcohol...a deal for the corn lobby
and a backwards step in efficiency.
not
two
lot
The corrosiveness is not due to the alcohol, per se, but due to
alcohol's affinity for water that causes the corrosion. It will soak the
water right out of the air and deposit it in your tank, wher the water
will star the corrosive process.
Old September 16th 03, 04:04 PM
Ron Natalie
The other issue is that one company (Unocal I think) owns the patent
to the most popular reformulated fuel strategy. This may be stiffling
the rest of the industry pushing for requiring (or even allowing) the reformulation.
Old September 16th 03, 06:18 PM
On Tue, 16 Sep 2003 05:32:41 GMT, "Bruce A. Frank"
You can thank Archer Daniel Midland's contributions to the Bush
campaign for the fact that you will soon NOT be able to buy fuel
without their alcohol in it.
I wonder how many repairs, how many people will die in aircraft engine
failure related crashes due to their politics?
STILL have not heard ... Chevron76arcoshell .. or whatever as an
answer to my question ....
---California International Air Show Pics Posted!!!! Tyson Rininger Aerobatics 0 February 23rd 04 12:51 PM
2004 California airshow schedule taking shape! Wings Of Fury Aerobatics 0 December 31st 03 06:32 AM
Salinas California Air Show yesterday BattMeals Aerobatics 0 October 20th 03 05:58 AM
Steen Skybolt pre-purchase, northern California Barnyard BOb -- Home Built 17 August 31st 03 09:21 PM
Barnyard--- Auto engines Jerry Springer Home Built 10 August 8th 03 07:38 PM
