On 10 May 2007 20:44:03 -0700, chris wrote:
That sounds a bit different - mixture rich for a hot start?? Is this because it's a IO520??? I am using a IO360 in an Arrow, if that makes any difference.. It makes all the difference in the world. You have Bendix/RSA fuel injection that does NOT have a constant displacement engine driven fuel pump and that does NOT have a return line to the fuel tank. "Classic" Continental fuel injection is a different... BTW, it's easier to add a little more full if you need to than it is to clear a flooded engine. Sounds like you've got it figured out. TC |
My Lycoming method is full rich, full throttle, pump till indication, ICO,
throttle cracked, and crank. Hot or cold makes no difference (AEIO-540) Continental- full throttle, full rich, pump on, throttle cracked at full rich, and crank. However, I have had difficulty with hot starts with the Continentals- any suggestions there? Why are they different? |
On Sat, 12 May 2007 06:37:18 -0500, "Viperdoc"
wrote: My Lycoming method is full rich, full throttle, pump till indication, ICO, throttle cracked, and crank. Hot or cold makes no difference (AEIO-540) Continental- full throttle, full rich, pump on, throttle cracked at full rich, and crank. However, I have had difficulty with hot starts with the Continentals- any suggestions there? Why are they different? On quite a few Lycoming installations, trying to restart within 5-30 minutes using your method tends to flood the engine. On these installations, leaving the mixture at ICO when cranking works better. The typical procedure for hot-starting the TCM system is throttle full, mixture ICO, boost pump on low (if a 2-speed pump install) for 4-5 seconds to "purge" the engine-driven pump. Advance the mixture to full, look for positive fuel flow indication, mixture to ICO. Bring throttle back to slightly above idle (like where it is for 1000-1200 rpm). Crank and when the engine fires, accelerates, and starts to lean out, advance the mixture. I use this method for cold-starts also, varying the amount of time the mixture is at full depending on the OAT. Lower OAT-more "prime", higher OAT-less. The TCM system is quite a bit different from the RSA/Bendix system that Lycoming uses. The primary difference is the engine-driven fuel pump. On the Bendix system, the engine-driven pump is merely a source of fuel pressure/flow. The first sign of a failing Lycoming pump is typically reduced indicated fuel flow at TO/climb power. The pump is not producing enough volume to generate the needed fuel pressure/flow to the nozzles. On the TCM system, the engine-driven pump is an integral part of the fuel injection system. It is a constant-displacement pump, one pump revolution always moves the same volume of fuel. Depending on engine demand, the fuel exceeding what the engine needs is returned to the fuel tank via a return line. Full rich, less fuel back to the tank, leaned in cruise, more fuel returned to the tank. The hot-start theory is that when the engine/fuel pump is heat-soaked, the fuel in the pump "boils" making fuel delivery from the pump hit or miss. Running the boost pump with the mixture at ICO circulates fuel from the tank, through the pump, and back to the tank. This ensures that the pump with "pump" properly during engine start. For many years, the TCM system allowed zero fuel to the cylinders with the mixture in ICO. About 10 years ago, some of the systems specs changed, allowing a slight amount of fuel to bypass into the cylinders (obviously not enough for the engine to idle, or it would never shut down). It has been a few years since I've worked on them, so I cannot be sure what the current specs are. Limiting the "boost pump on, mixture at ICO" purge time to 4-5 seconds will keep the engine from flooding if the installed system is indeed supplying fuel to the engine in ICO. One very important aspect of the TCM fuel injection system that is often not covered well in training is use of the electric boost pump. The TO fuel pressure and the idle fuel pressure are mechanically adjusted on the engine-driven pump itself, following specific procedures with the engine (and the engine-driven pump) running. The electric boost pump is SUPPOSED to provide pressure and volume similiar to the engine-driven pump, in theory allowing these same mechanical adjustments to provide close to the same fuel pressures. In reality, if the engine-driven pump fails (which doesn't happen very often) the mixture and possibly the throttle may require drastic changes to keep the engine producing power. If the boost pump is operated (on high on a 2-speed install) along with the engine-driven pump, the increase in combined delivered pressure and volume will render the mechanical settings pretty much useless, flooding the engine with fuel. This is usually pointed out during training and in checklists/manuals. Hope some of this is helpful; TC |
"chris" wrote in message ups.com... Hi peoples.. Hopefully this is an easy one for you experts out there... Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. The POH for the Arrow II (Lycoming IO-360-CIC) states for "Starting Engine When Hot" 1. Open the throttle approx 1/2 inch 2. Turn the master switch ON 3. Turn the electric fuel pump on. * -- hand-written footnote says "Will probably flood" 4. Put the mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and move the throttle to desired setting. That doesn't make any sense; it floods. I have better luck starting it flooded, though, so I end up using the next section, "Starting Engine When Flooded" 1. Open the throttle full 2. Turn the master switch ON 3. Turn the electric fuel pump OFF 4. Put mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and [then] retard the throttle. That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. -c |
"gatt" wrote in message ... "chris" wrote in message ups.com... Hi peoples.. Hopefully this is an easy one for you experts out there... Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. The POH for the Arrow II (Lycoming IO-360-CIC) states for "Starting Engine When Hot" 1. Open the throttle approx 1/2 inch 2. Turn the master switch ON 3. Turn the electric fuel pump on. * -- hand-written footnote says "Will probably flood" 4. Put the mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and move the throttle to desired setting. That doesn't make any sense; it floods. I have better luck starting it flooded, though, so I end up using the next section, "Starting Engine When Flooded" 1. Open the throttle full 2. Turn the master switch ON 3. Turn the electric fuel pump OFF 4. Put mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and [then] retard the throttle. That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. -c This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. |
"Allen" wrote in message ... That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. That's unfortunate. I wonder how much of an insurance hit he/we will take for something like that. The very first item in the "STARTING ENGINE" checklist in the POH is: 1. Set Parking Brakes ON. Managing the throttle and mixture while simultaneously applying toe brakes and making sure you're not rolling forward would make me nervous. I amended my run-up checklist to say "Verify no movement" immediately after setting the throttle to 2000 RPM 'cause the last thing I'd want to do while verifying mag drops and engine instruments is to look up and realize I'm moving. -c |
On May 18, 5:05 am, "gatt" wrote:
"Allen" wrote in message ... That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedo*wn-row BS", but I finally got the hang of making it work. This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. That's unfortunate. I wonder how much of an insurance hit he/we will take for something like that. The very first item in the "STARTING ENGINE" checklist in the POH is: 1. Set Parking Brakes ON. Managing the throttle and mixture while simultaneously applying toe brakes and making sure you're not rolling forward would make me nervous. I amended my run-up checklist to say "Verify no movement" immediately after setting the throttle to 2000 RPM 'cause the last thing I'd want to do while verifying mag drops and engine instruments is to look up and realize I'm moving. -c That sounds good, but I would rather use my toe brakes when starting and doing a runup. Why?? At least twice while doing a runup in an Archer the park brake has mysteriously unlocked itself, leaving the aircraft with the meat grinder spinning at 2000rpm to lurch forward while I leap on the brakes ![]() I used to use park brake but it just makes me nervous - at least with leaning hard on the toe brakes I am sure it ain't going anywhere! |
"Allen" wrote They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. Whoa, there, back up! That sounds like the "big fish" story. It gets bigger every time it is told. A half mile is way too far to be believable, if the prop is thrown from ground altitude. Two, three hundred yards, maybe. You would need to show me some documentation for me to believe much more than that. -- Jim in NC |
I saw the pictures of that. 100 yards, maybe.
Morgans wrote: "Allen" wrote They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. Whoa, there, back up! That sounds like the "big fish" story. It gets bigger every time it is told. A half mile is way too far to be believable, if the prop is thrown from ground altitude. Two, three hundred yards, maybe. You would need to show me some documentation for me to believe much more than that. |
| Going IFR from the start | Dylan Smith | Piloting | 9 | May 24th 05 12:47 AM |
| Hopefully not the start of a new trend ... | Cockpit Colin | Piloting | 4 | February 5th 05 07:11 AM |
| Cold Start Question | Andy Shane | Piloting | 7 | January 12th 05 02:35 PM |
| I want to start | Carlos Estopier | Owning | 16 | May 12th 04 08:09 PM |
