Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Dutch Roll?
Old May 18th 07, 11:17 PM posted to rec.aviation.misc
Ron Hardin
Default Dutch Roll?
Do modern jet airliners still have a noticeable dutch roll? I haven't
flown in anything for a couple decades, and was wondering if it's been
damped out to zero by modern control theory, or still exists.
I first noticed it trying to take solar sights with an elaborate
protractor and bubble level setup on trans-Pacific flights, in
DC-6's and later 707's (something to do). It was a few degrees
in roll magnitude, quite noticeable. You'd think today it would
be gone completely, though, but I don't know.
It came to mind because my bicycle seems to do the same thing under
heavy baggage load. No doubt from a different cause.
Ron Hardin
On the internet, nobody knows you're a jerk.
Old May 19th 07, 04:38 AM posted to rec.aviation.misc
Scott Skylane
Default Dutch Roll?
Hmmmm, Dutch Roll in a DC-6? My understanding has always been that
Dutch Roll is a by-product of a swept-back wing. While the leading edge
of the big Dougs does angle back from the lateral plane, the wing as a
whole, is straight. Any lateral occilations you observed were probably
due to the crudeness of the autopilot.
As for the 707, I would guess that the Dutch roll characteristics you
observed where properties of a first generation jetliner yaw damper, ie:
less than perfect dampening.
In regards to transport category aircraft, anything of a newer
generation has, in my observation, perfectly eliminated any Dutch roll
tendencies.
Happy Flying!
Scott Skylane
Old May 20th 07, 03:58 PM posted to rec.aviation.misc
Ron Hardin
Default Dutch Roll?
tendencies.
Happy Flying!
Scott Skylane
Actually it's from a mismatch of roll recovery time and yaw recovery time.
Plain ordinary dihedral, which a DC-6 has plenty of, is said to produce it.
Its presence certainly points to the autopilot, but only as having failed to
take it completely away. It develops naturally, and then grows to the granularity
of the autopilot, and then remains there, I think.
It can't be an instability in the autopilot, or it would grow bigger, which it
fails to do.
Ron Hardin
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Dutch rolls Chris Mark Military Aviation 11 May 16th 04 07:37 AM
Dutch roll coordination technique Matthew Jurotich Piloting 8 January 5th 04 02:17 PM
