Anybody know whether the Diamond DA40 is available with diesel power
in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. |
On May 21, 8:54 pm, Paul kgyy wrote:
Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. IIRC, the diesels that Diamond have certified don't have a 2000hr TBO either. Didn't they just get it increased from 1200hrs to 1500hr or something like that? On top of all that, the energy density for 100LL is some 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. Overall, aside from diesel fuel prices, I don't see a big advantage especially once you multiply the diesel fuel price by %120 to compare what it would cost you to travel the same distance via 100LL. Once you add in the engine reserve for a 1500hr (IIRC) engine versus a 2000hr engine and the extra fuel required, one has to wonder if the diesel price per gallon is worth it in the big picture. Are you sure you still want diesel power? Greg |
![]() "Greg Copeland" wrote On top of all that, the energy density for 100LL is some 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. I think you have that backwards. Diesel fuel has a higher energy density than 100LL. You burn less fuel per HP produced. -- Jim in NC |
Greg Copeland schrieb:
On May 21, 8:54 pm, Paul kgyy wrote: Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. IIRC, the diesels that Diamond have certified don't have a 2000hr TBO either. Didn't they just get it increased from 1200hrs to 1500hr or something like that? On top of all that, the energy density for 100LL is some 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. Overall, aside from diesel fuel prices, I don't see a big advantage especially once you multiply the diesel fuel price by %120 to compare what it would cost you to travel the same distance via 100LL. Once you add in the engine reserve for a 1500hr (IIRC) engine versus a 2000hr engine and the extra fuel required, one has to wonder if the diesel price per gallon is worth it in the big picture. Are you sure you still want diesel power? Greg Ups, I guess you have never seen a modern diesel. You are comparing a 1940 avgas dino vs. a 2000 diesel. For comparison take a look at http://de.wikipedia.org/wiki/Diamond_DA40 (Soory, it´s german) The diesel has 30 kg more weight and thus 30 kg less pay load. But it takes only about 15 liters per hour vs. 27 liter per hour for the avgas dino. This means for a 3 hour trip or more you have more usable payload in the diesel powererd DA40. Michael |
![]() Greg Copeland wrote: On May 21, 8:54 pm, Paul kgyy wrote: Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. I'm don't know how the weight of the diesel for the Diamond compares, but you are wrong on the the fuel weight issue. Well it is heavier per gallon, but you can go much further on a lbs of diesel than you can on a lbs of gas. If you fill the tanks to the top you will have less useful load but if put in the amount of diesel that it would take to go the same distance you could on gas, there would be fewer lbs of fuel in the tank. Which also means if you need the extra range, going diesel is like adding larger tanks. You are right that there is more energy per lbs of gas, however, diesel engines more than make up for that because they are more efficient than gas engines. The way I see it the only disadvantage to diesel, and it is a huge disadvantage, is the lack of proven engines to pick from. -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
On 22 May, 05:37, Greg Copeland wrote:
On May 21, 8:54 pm, Paul kgyy wrote: Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. IIRC, On top of all that, the energy density for 100LL is some 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. It seems that you do not recall correctly. Quite a lot of people disagree with these numbers. Chevron for example seem to think that the difference in enengy density between kerosene and aviation gasoline is rather smaller than either of your figures. The inherent efficiency of the diesel at part throttle does the rest. http://hypertextbook.com/facts/2003/EvelynGofman.shtml Everyone else that I have read on the subject (other than yourself) seems to reach the opposite conclusion regarding range/payload. |
Paul,
Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? As far I know, it's not. Best to call Diamond, though. They might have changed their policy with the introduction of the DA-42. -- Thomas Borchert (EDDH) |
Greg,
Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. But it's still ancient. ;-) Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. The fuel contains more energy, too, so you need less. In all, we're talking about a few pounds. In the case of the DA-40, look at the specs. IIRC, the diesels that Diamond have certified don't have a 2000hr TBO either. Nope, they are scheduled for a 2400 hours TBR (replacement). Granted, at the moment they are certified to something in the 1000s, but Thielert/Diamond will prorate the replacement cost as if it were 2400 hours. Going in, you know exactly what that engine is going to cost you. No extras for surprise to overhauls or anything like that. And 2400 hours seems REALLY decent to me. On top of all that, the energy density for 100LL is some 20% higher It's the other way around. Diesel has a higher energy density. It's much less than 20 percent, though. Overall, aside from diesel fuel prices, I don't see a big advantage especially once you multiply the diesel fuel price by %120 to compare what it would cost you to travel the same distance via 100LL. Again, you got that wrong. Also, the fuel consumption of that modern, electronically controlled engine is WAY lower than with the ancient Lyc. Once you add in the engine reserve for a 1500hr (IIRC) engine versus a 2000hr engine and the extra fuel required, As described above, that's wrong. Are you sure you still want diesel power? Are YOU still sure you want a Lycosaurus? ;-) -- Thomas Borchert (EDDH) |
On 2007-05-22, Greg Copeland wrote:
Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. The Thielert diesel burns about half the fuel of an IO360 with very little performance loss. I think that's exciting. So you get MORE useful load because you need vastly less fuel. 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. I'm really curious - where did you get these numbers from? The diesel burns about 50% of the fuel of an O-320, let alone an IO-360. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
On May 22, 3:50 am, Dylan Smith wrote:
On 2007-05-22, Greg Copeland wrote: Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. The Thielert diesel burns about half the fuel of an IO360 with very little performance loss. I think that's exciting. So you get MORE useful load because you need vastly less fuel. 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. I'm really curious - where did you get these numbers from? The diesel burns about 50% of the fuel of an O-320, let alone an IO-360. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute:http://oolite-linux.berlios.de Okay, seems I stand corrected. Just FYI, I looked this morning and diesel fuel is 18% heavier. I had also assumed that they had placed a FADEC setup on the Lyc, thusly greatly improving its effeciency too. Guess not. Many people don't realize that much of the effeciency associated with these engines comes from FADEC rather than diesel in of it self. Greg |
Cost of owning a Diamond DA40, new vs 5-6 years old | [email protected] | Owning | 9 | December 28th 10 05:00 AM |
Diamond DA40 lap belt extender ... ? | Harold | Owning | 2 | July 22nd 06 05:56 PM |
Diamond DA40-180 | lance smith | Piloting | 9 | December 4th 03 04:00 PM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
