Diesel for Diamond DA40?
Old May 22nd 07, 02:54 AM posted to rec.aviation.piloting
Paul kgyy
Default Diesel for Diamond DA40?
Anybody know whether the Diamond DA40 is available with diesel power
in the U.S.? I checked the website and the only engine is the ancient
Lycoming IO360.
Old May 22nd 07, 05:37 AM posted to rec.aviation.piloting
Greg Copeland
Lycoming IO360.
Hmm. Not sure why you put it that way. The IO360 is well know for
being rock solid. Diesel aircraft engines typically cost you useful
load because of their weight and the fuel is heavier to boot. A
double whammy on useful load isn't exactly exciting. IIRC, the
diesels that Diamond have certified don't have a 2000hr TBO either.
Didn't they just get it increased from 1200hrs to 1500hr or something
like that? On top of all that, the energy density for 100LL is some
20% higher (IIRC; or was it 40%) which means fuel consumption is 20%
higher for the same HP rating.
Overall, aside from diesel fuel prices, I don't see a big advantage
especially once you multiply the diesel fuel price by %120 to compare
what it would cost you to travel the same distance via 100LL. Once
you add in the engine reserve for a 1500hr (IIRC) engine versus a
2000hr engine and the extra fuel required, one has to wonder if the
diesel price per gallon is worth it in the big picture.
Are you sure you still want diesel power?
Greg
Old May 22nd 07, 06:53 AM posted to rec.aviation.piloting
Morgans[_2_]
I think you have that backwards. Diesel fuel has a higher energy density
than 100LL. You burn less fuel per HP produced.
Jim in NC
Old May 22nd 07, 08:41 AM posted to rec.aviation.piloting
Michael[_4_]
Lycoming IO360.
Greg
Ups, I guess you have never seen a modern diesel. You are comparing a
1940 avgas dino vs. a 2000 diesel. For comparison take a look at
http://de.wikipedia.org/wiki/Diamond_DA40 (Soory, it´s german)
The diesel has 30 kg more weight and thus 30 kg less pay load. But it
takes only about 15 liters per hour vs. 27 liter per hour for the avgas
dino. This means for a 3 hour trip or more you have more usable payload
in the diesel powererd DA40.
Michael
Old May 22nd 07, 08:55 AM posted to rec.aviation.piloting
Chris W
Lycoming IO360.
I'm don't know how the weight of the diesel for the Diamond compares,
but you are wrong on the the fuel weight issue. Well it is heavier per
gallon, but you can go much further on a lbs of diesel than you can on a
lbs of gas. If you fill the tanks to the top you will have less useful
load but if put in the amount of diesel that it would take to go the
same distance you could on gas, there would be fewer lbs of fuel in the
tank. Which also means if you need the extra range, going diesel is
like adding larger tanks. You are right that there is more energy per
lbs of gas, however, diesel engines more than make up for that because
they are more efficient than gas engines.
The way I see it the only disadvantage to diesel, and it is a huge
disadvantage, is the lack of proven engines to pick from.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old May 22nd 07, 08:56 AM posted to rec.aviation.piloting
Lycoming IO360.
It seems that you do not recall correctly.
Quite a lot of people disagree with these numbers.
Chevron for example seem to think that the
difference in enengy density between kerosene and
aviation gasoline is rather smaller than either of
your figures. The inherent efficiency of the
diesel at part throttle does the rest.
http://hypertextbook.com/facts/2003/EvelynGofman.shtml
Everyone else that I have read on the subject
(other than yourself) seems to reach the
opposite conclusion regarding range/payload.
Old May 22nd 07, 09:28 AM posted to rec.aviation.piloting
Thomas Borchert
Paul,
in the U.S.?
As far I know, it's not. Best to call Diamond, though. They might have
changed their policy with the introduction of the DA-42.
Thomas Borchert (EDDH)
Thomas Borchert
Greg,
being rock solid.
But it's still ancient. ;-)
The fuel contains more energy, too, so you need less. In all, we're talking about a few pounds. In
the case of the DA-40, look at the specs.
IIRC, the
Nope, they are scheduled for a 2400 hours TBR (replacement). Granted, at the moment they are
certified to something in the 1000s, but Thielert/Diamond will prorate the replacement cost as if it
were 2400 hours. Going in, you know exactly what that engine is going to cost you. No extras for
surprise to overhauls or anything like that. And 2400 hours seems REALLY decent to me.
20% higher
It's the other way around. Diesel has a higher energy density. It's much less than 20 percent,
though.
Again, you got that wrong. Also, the fuel consumption of that modern, electronically controlled
engine is WAY lower than with the ancient Lyc.
Once
As described above, that's wrong.
Are YOU still sure you want a Lycosaurus? ;-)
Old May 22nd 07, 09:50 AM posted to rec.aviation.piloting
Dylan Smith
The Thielert diesel burns about half the fuel of an IO360 with very
little performance loss. I think that's exciting. So you get MORE useful
load because you need vastly less fuel.
I'm really curious - where did you get these numbers from? The diesel
burns about 50% of the fuel of an O-320, let alone an IO-360.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old May 22nd 07, 02:07 PM posted to rec.aviation.piloting
Greg Copeland
Oolite-Linux: an Elite tribute:http://oolite-linux.berlios.de
Okay, seems I stand corrected. Just FYI, I looked this morning and
diesel fuel is 18% heavier. I had also assumed that they had placed a
FADEC setup on the Lyc, thusly greatly improving its effeciency too.
Guess not. Many people don't realize that much of the effeciency
associated with these engines comes from FADEC rather than diesel in
of it self.
Greg
Cost of owning a Diamond DA40, new vs 5-6 years old [email protected] Owning 9 December 28th 10 05:00 AM
Diamond DA40 lap belt extender ... ? Harold Owning 2 July 22nd 06 05:56 PM
Diamond DA40-180 lance smith Piloting 9 December 4th 03 04:00 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
