#21
karl gruber wrote:
"Greg Copeland" wrote in message Okay, seems I stand corrected. Just FYI, I looked this morning and diesel fuel is 18% heavier. I had also assumed that they had placed a FADEC setup on the Lyc, thusly greatly improving its effeciency too. Guess not. Many people don't realize that much of the effeciency associated with these engines comes from FADEC rather than diesel in of it self. FADEC won't make an engine run more efficiently. It will make it easier to manage. and thus it will make it run more efficiently than a improperly managed manually controlled engine. regards, Friedrich |
![]() "karl gruber" wrote FADEC won't make an engine run more efficiently. It will make it easier to manage. In a way that is true, but at the same time it is as false as can be. A properly leaned engine at cruise, with well matched injectors, will have all of the cylinders humming happily along at the most efficient setting, and lowest fuel flow. FADEC can not improve on that much, if any. But, and it is a big but, think of the settings we run on takeoff, and landing (in case you have to do a go-around) and of the time you are at idle, or low power on the ground. You are running much richer than need be, and not as lean as FADEC would have things set. On the average, us setting the mixture is wasting fuel, and is inefficient as compared to FADEC. FADEC will reset the mixture many times per second; as often as is needed. That is something we can never begin to think about doing. -- Jim in NC |
landing (in case you have to do a go-around) and of the time you are at idle, or low power on the ground. Most of the time will be spent at cruise (unless you are in the pattern), so I would not expect that to be all that much. Jose -- There are two kinds of people in the world. Those that just want to know what button to push, and those that want to know what happens when they push the button. for Email, make the obvious change in the address. |
#24
On 2007-05-22, Newps wrote:
The real downside was the cost to convert. They wanted $80K which is a price nobody will pay because the break even point is still way too far into the future. So the question is: where is the break even point? If you account for the reduced maintenance costs, and you make your own biodiesel at ~$1/gal., would you say the break even point is acceptable? -- PM instructions: do a C4esar Ciph3r on my address; retain punctuation. |
#25
and IIRC what I read.. you can't field overhaul the diesel, it goes back to
the factory and the limit is about 1100hrs. BT "Greg Copeland" wrote in message oups.com... On May 21, 8:54 pm, Paul kgyy wrote: Anybody know whether the Diamond DA40 is available with diesel power in the U.S.? I checked the website and the only engine is the ancient Lycoming IO360. Hmm. Not sure why you put it that way. The IO360 is well know for being rock solid. Diesel aircraft engines typically cost you useful load because of their weight and the fuel is heavier to boot. A double whammy on useful load isn't exactly exciting. IIRC, the diesels that Diamond have certified don't have a 2000hr TBO either. Didn't they just get it increased from 1200hrs to 1500hr or something like that? On top of all that, the energy density for 100LL is some 20% higher (IIRC; or was it 40%) which means fuel consumption is 20% higher for the same HP rating. Overall, aside from diesel fuel prices, I don't see a big advantage especially once you multiply the diesel fuel price by %120 to compare what it would cost you to travel the same distance via 100LL. Once you add in the engine reserve for a 1500hr (IIRC) engine versus a 2000hr engine and the extra fuel required, one has to wonder if the diesel price per gallon is worth it in the big picture. Are you sure you still want diesel power? Greg |
#26
FADEC is much more than just controlling mixture. that system is measuring,
monitoring and governing a whole lot of parameters. compared to a human operating a few levers, FADEC can set all these parameters in a way so the engine/propeller-combination operates much closer to its optimum. also, today's engines can only be that economic because of the electronic system. as an example, fuel injection varies in injection time and the amount of fuel injected, depending on RPMs, power setting, flow of the mass of air through the manifold (not just the air pressure in there) and probably a few more. you cannot achieve this by mechanical or even maunual solutions. uli Morgans wrote: A properly leaned engine at cruise, with well matched injectors, will have all of the cylinders humming happily along at the most efficient setting, and lowest fuel flow. FADEC can not improve on that much, if any. But, and it is a big but, think of the settings we run on takeoff, and landing (in case you have to do a go-around) and of the time you are at idle, or low power on the ground. You are running much richer than need be, and not as lean as FADEC would have things set. On the average, us setting the mixture is wasting fuel, and is inefficient as compared to FADEC. FADEC will reset the mixture many times per second; as often as is needed. That is something we can never begin to think about doing. |
#27
![]() "Uli" wrote FADEC is much more than just controlling mixture. that system is measuring, monitoring and governing a whole lot of parameters. compared to a human operating a few levers, FADEC can set all these parameters in a way so the engine/propeller-combination operates much closer to its optimum. also, today's engines can only be that economic because of the electronic system. as an example, fuel injection varies in injection time and the amount of fuel injected, depending on RPMs, power setting, flow of the mass of air through the manifold (not just the air pressure in there) and probably a few more. you cannot achieve this by mechanical or even maunual solutions. Of course it does much more, but the mixture is a big part of the equation. One thing you missed mentioning is the timing, on some systems. -- Jim in NC |
#28
("Thomas Borchert" wrote)
Until now, Thielert has sold their engines only in Europe. Actually, they are selling the DA-42 with Thielert engines in the US and have been for some months now. In Minnesota... At Anoka County-Blaine Airport (ANE) there is a DA-42, with Thielert engines. It is owned by a regular poster to rec.aviation, he is also a member of our local EAA Chapter. He's wants to give Young Eagle rides in his DA-42. He used to give Young Eagle rides in his Cessna 310. g I hope I get these numbers right. He said @ 85% power (turbo) he's seeing total fuel burn: 12 gallons/hour ......175kts? 8 gallons /hour .......140kts? Crap, now I'm guessing. PINGING Cary M !!! Montblack |
#29
![]() Jose wrote: But, and it is a big but, think of the settings we run on takeoff, and landing (in case you have to do a go-around) and of the time you are at idle, or low power on the ground. Most of the time will be spent at cruise (unless you are in the pattern), so I would not expect that to be all that much. A FADEC on a plane like a 182 will save on average 2 GPH, that's huge. So saying a FADEC in and of itself is not what makes it more efficient is theoretically true but it is practically true. A human will never be able to operate the engine at its most efficient, for a computer it is simple. |
#30
![]() Justin Gombos wrote: On 2007-05-22, Newps wrote: The real downside was the cost to convert. They wanted $80K which is a price nobody will pay because the break even point is still way too far into the future. So the question is: where is the break even point? If you account for the reduced maintenance costs, Nobody knows that yet. Too many different technologies have come and gone promising lower costs. When the diesel has proven itself to cost less in the field I will believe it. Until then it's pure speculation. and you make your own biodiesel at ~$1/gal., would you say the break even point is acceptable? I don't know. First off putting $80K into a $50K airplane won't happen for that reason alone. Second the guy who has $80K to put into a 182 isn't the kind of guy who homebrews his own biodiesel. Simple fact of the matter is $80K is a deal breaker. Get it down to $40K, about the same as putting a big engine in a 182, and then you've got something. But at $80K you won't have any market penetration at all. And really at $40K look how many 300 HP 550's are in 182's now. I wouldn't call it rare but it's still a fairly small percentage. |
Cost of owning a Diamond DA40, new vs 5-6 years old | [email protected] | Owning | 9 | December 28th 10 05:00 AM |
Diamond DA40 lap belt extender ... ? | Harold | Owning | 2 | July 22nd 06 05:56 PM |
Diamond DA40-180 | lance smith | Piloting | 9 | December 4th 03 04:00 PM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
