Prop sync and noise in twins
Old May 22nd 07, 09:43 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Prop sync and noise in twins
Erik wrote in
Mxsmanic wrote:
John Theune writes:
If you type in prop synch multi-engine planes into the google search
window the first hit you will see is this
The AVSIM Forums - Viewing topic #736 - Prop sync
Out of synch propellers will not be as obvious or as annoying in a
simulator as in a real plane. In most aircraft with prop synch, you
first manually ...
forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736
&mode
=full - 56k - Cached - Similar pages
Go there , read it and you will know all you want to know.
Thanks. I guess people in the AVSIM forums actually answer questions
rather than just point people to Google.
To be fair, Google is the place to start.
Interesting question, though.
BTW, exactly who was it said this **** was a master troll?
Bwawhahwhahhwhahwhahwhahwhhahwhahwhahwhhahwhahwhah hwhahwhahwhahhwhahwhah
hwh!
Bertie
Bertie
  #32
Old May 22nd 07, 10:45 PM posted to rec.aviation.piloting
Morgans[_2_]
rather
So go there and ask you questions, and leave us alone. It should be clear
that you are not welcome by most of the people here.
  #33
Old May 22nd 07, 10:55 PM posted to rec.aviation.piloting
chris[_1_]
On May 22, 4:47 pm, Mxsmanic wrote:
John Theune writes:
first manually ...
forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full
Thanks. I guess people in the AVSIM forums actually answer questions rather
Well **** off there and leave us alone then. You love to tell us how
unhelpful we are then you keep coming back!!! Sounds a lot like a
serious personality disorder right there
  #34
Old May 22nd 07, 11:51 PM posted to rec.aviation.piloting
Dave[_3_]
Same here Dudley..
I have a "few " hours in a 310... I just set them manually, they
stayed in sync very well
I have 2500 hrs on the boat, no auto sync, although they make them.
You engage it once the vessel is moving fwd in gear, then use one
throttle (usually the Starboard) and the Port engine tracks the
master..
The 1st sign of engine trouble is the engines going out of sync
without any aparent reason...
Cheers!
Dave
On Mon, 21 May 2007 22:46:39 -0400, "Dudley Henriques"
"Dave" wrote in message
Yes... it can be REALLY irritating..
I have a twin engine boat, same issue... VERY annoying.. to me, and
many others..
Some don't seem to mind.. (?)
Not only the noise, but the vibrations , when out of sync, can be very
annoying as well...
Dave
We had a Cessna 337 on our line for charter use at one time. It had a sync
gauge. Strangely enough, whenever I had occasion to fly this bird I always
ended up syncing the props by ear. You could easily feel if one of them was
out even by a small amount of RPM.
Dudley Henriques
  #35
Old May 23rd 07, 02:12 AM posted to alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk,alt.disasters.aviation,rec.aviation.piloting
EatMe
On May 22, 3:43 pm, Bertie the Bunyip wrote:
Erik wrote :
Mxsmanic wrote:
John Theune writes:
first manually ...
&mode
hwh!
Bertie
Bertie
Same folks who claimed you weren't evidently.
"That Bertie! He's such a sly one!"
  #36
Old May 23rd 07, 02:13 AM posted to rec.aviation.piloting
EatMe
On May 22, 9:30 am, Bertie the Bunyip wrote:
buttman wrote groups.com:
On May 21, 9:50 pm, Mxsmanic wrote:
Dudley Henriques writes:
a sync gauge. Strangely enough, whenever I had occasion to fly this
bird I always ended up syncing the props by ear. You could easily
feel if one of them was out even by a small amount of RPM.
Logically the smallest differences would also be the most annoying,
since they would result in such slow variations. And in theory you
should be able to eliminate them by adjusting RPM manually. But
since the Baron has a prop sync switch it occurred to me that perhaps
the RPM levers aren't precise enough to make it easy to sync the
props (?).
I'm still not clear on whether or not this switch actually moves the
prop levers or what. If it does, it sounds expensive, since it needs
an actuator or servo in the cockpit or along the linkage. If it
doesn't, it means that some of the engine control positions might not
accurately reflect the actual engine settings and that engine
settings might not obey the control movements if prop sync is
operating.
In the baron I got my multi in, you had to first get the props sync'd
up to within 50 rpm. Then you press the sync button and it fine tunes
the prop governors to get them exact. At least thats how I remember
it, it's been a while. Get a POH, it'll have detailed descriptions of
the system. IIRC Beechcraft POH's are pretty expensive (over $100)
Wow, the modern CFI, waht a mrvel he is.
Bertie
Well I'll bet he can spell-check, fjucktard.
When I get senile dementia, I want to be just like Bertie Butnip!
  #37
Old May 23rd 07, 02:14 AM posted to rec.aviation.piloting
EatMe
On May 22, 3:38 pm, Bertie the Bunyip wrote:
Erik wrote in news:1356fnpjo8uc810
@corp.supernews.com:
Bertie
You are one small and unhappy person. Find a hobby.
Cheer yourself up. Life can be better, you know.
oow I have a remora!
kewl!
Bertie
Don't flatter yourself skippy.
You are the hemorrhoid of Usenet.
But we love you anyway. Without you life has no meaning or rhyme.
Like notes to a song out of time.
  #38
Old May 23rd 07, 02:15 AM posted to rec.aviation.piloting
EatMe
You're an idiot.
Bertie
And you are the wind beneath our buns. So?
  #39
Old May 23rd 07, 02:17 AM posted to alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk,alt.disasters.aviation,rec.aviation.piloting
EatMe
On May 22, 3:41 pm, Bertie the Bunyip wrote:
Erik wrote :
Bertie the Bunyip spewed:
You realy aren';t too bright, are you?
Bertie
Hmmmm...your command of 'English' speaks for itself.
But your sense of humor is enjoyable. Such irony.
  #40
Old May 23rd 07, 02:21 AM posted to rec.aviation.piloting
EatMe
On May 22, 9:31 am, Bertie the Bunyip wrote:
Mxsmanic wrote :
I note that the Baron (and presumably other twins) has a prop sync
switch that somehow synchronizes the prop speeds on both engines.
From recordings I've heard of the interior noise of the aircraft, it
does sound as though props that are just slightly out of sync can
produce a very irritating intermittent noise as they move in and out
of phase.
If you want to simulate that accurately, just talk while your's jerking off
with your sim
Berti e
Perhaps you could drill a hole in your "English As A Third Language"
textbook and hump the snot out of it.
Leave it open so you might learn something in that 5 second interval
betwixt engage-disengage-ment as you peer out the airport hotel window
for a little (OH!) plane spotting.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
CompaqAero1530 sync question Stewart Kissel Soaring 0 February 21st 05 03:15 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
