Diesel for Diamond DA40?
Old May 22nd 07, 09:06 PM posted to rec.aviation.piloting
Friedrich Ostertag
Default Diesel for Diamond DA40?
karl gruber wrote:
"Greg Copeland" wrote in message Okay, seems
I stand corrected. Just FYI, I looked this morning and
diesel fuel is 18% heavier. I had also assumed that they had placed
a FADEC setup on the Lyc, thusly greatly improving its effeciency
too. Guess not. Many people don't realize that much of the
effeciency associated with these engines comes from FADEC rather
than diesel in of it self.
FADEC won't make an engine run more efficiently. It will make it
easier to manage.
and thus it will make it run more efficiently than a improperly managed
manually controlled engine.
regards,
Friedrich
Old May 22nd 07, 10:32 PM posted to rec.aviation.piloting
Morgans[_2_]
"karl gruber" wrote
FADEC won't make an engine run more efficiently. It will make it easier to
manage.
In a way that is true, but at the same time it is as false as can be.
A properly leaned engine at cruise, with well matched injectors, will have
all of the cylinders humming happily along at the most efficient setting,
and lowest fuel flow. FADEC can not improve on that much, if any.
But, and it is a big but, think of the settings we run on takeoff, and
landing (in case you have to do a go-around) and of the time you are at
idle, or low power on the ground. You are running much richer than need be,
and not as lean as FADEC would have things set. On the average, us setting
the mixture is wasting fuel, and is inefficient as compared to FADEC. FADEC
will reset the mixture many times per second; as often as is needed. That
is something we can never begin to think about doing.
Jim in NC
Old May 22nd 07, 11:12 PM posted to rec.aviation.piloting
Jose
Most of the time will be spent at cruise (unless you are in the
pattern), so I would not expect that to be all that much.
Jose
There are two kinds of people in the world. Those that just want to
know what button to push, and those that want to know what happens when
they push the button.
Old May 23rd 07, 01:11 AM posted to rec.aviation.piloting
Justin Gombos
Default Converting to diesel - where is the break even point?
On 2007-05-22, Newps wrote:
The real downside was the cost to convert. They wanted $80K which
is a price nobody will pay because the break even point is still way
too far into the future.
So the question is: where is the break even point? If you account for
the reduced maintenance costs, and you make your own biodiesel at
~$1/gal., would you say the break even point is acceptable?
PM instructions: do a C4esar Ciph3r on my address; retain punctuation.
Old May 23rd 07, 02:33 AM posted to rec.aviation.piloting
BT
and IIRC what I read.. you can't field overhaul the diesel, it goes back to
the factory and the limit is about 1100hrs.
BT
On May 21, 8:54 pm, Paul kgyy wrote:
Anybody know whether the Diamond DA40 is available with diesel power
in the U.S.? I checked the website and the only engine is the ancient
Lycoming IO360.
Hmm. Not sure why you put it that way. The IO360 is well know for
being rock solid. Diesel aircraft engines typically cost you useful
load because of their weight and the fuel is heavier to boot. A
double whammy on useful load isn't exactly exciting. IIRC, the
diesels that Diamond have certified don't have a 2000hr TBO either.
Didn't they just get it increased from 1200hrs to 1500hr or something
like that? On top of all that, the energy density for 100LL is some
20% higher (IIRC; or was it 40%) which means fuel consumption is 20%
higher for the same HP rating.
Overall, aside from diesel fuel prices, I don't see a big advantage
especially once you multiply the diesel fuel price by %120 to compare
what it would cost you to travel the same distance via 100LL. Once
you add in the engine reserve for a 1500hr (IIRC) engine versus a
2000hr engine and the extra fuel required, one has to wonder if the
diesel price per gallon is worth it in the big picture.
Are you sure you still want diesel power?
Greg
Old May 23rd 07, 08:38 AM posted to rec.aviation.piloting
Uli
FADEC is much more than just controlling mixture. that system is measuring,
monitoring and governing a whole lot of parameters. compared to a human
operating a few levers, FADEC can set all these parameters in a way so the
engine/propeller-combination operates much closer to its optimum.
also, today's engines can only be that economic because of the electronic
system. as an example, fuel injection varies in injection time and the
amount of fuel injected, depending on RPMs, power setting, flow of the mass
of air through the manifold (not just the air pressure in there) and
probably a few more. you cannot achieve this by mechanical or even maunual
solutions.
uli
be,
setting
FADEC
Old May 23rd 07, 11:27 AM posted to rec.aviation.piloting
Morgans[_2_]
measuring,
mass
solutions.
Of course it does much more, but the mixture is a big part of the equation.
One thing you missed mentioning is the timing, on some systems.
Jim in NC
  #28
Old May 23rd 07, 04:00 PM posted to rec.aviation.piloting
Montblack
("Thomas Borchert" wrote)
Until now, Thielert has sold their engines only in Europe.
Actually, they are selling the DA-42 with Thielert engines in the US and
have been for some months now.
In Minnesota...
At Anoka County-Blaine Airport (ANE) there is a DA-42, with Thielert
engines. It is owned by a regular poster to rec.aviation, he is also a
member of our local EAA Chapter. He's wants to give Young Eagle rides in his
DA-42. He used to give Young Eagle rides in his Cessna 310. g
I hope I get these numbers right.
He said @ 85% power (turbo) he's seeing total fuel burn:
12 gallons/hour ......175kts?
8 gallons /hour .......140kts?
Crap, now I'm guessing. PINGING Cary M !!!
Montblack
  #29
Old May 23rd 07, 04:36 PM posted to rec.aviation.piloting
Newps
at idle, or low power on the ground.
A FADEC on a plane like a 182 will save on average 2 GPH, that's huge.
So saying a FADEC in and of itself is not what makes it more efficient
is theoretically true but it is practically true. A human will never be
able to operate the engine at its most efficient, for a computer it is
simple.
  #30
Old May 23rd 07, 04:42 PM posted to rec.aviation.piloting
Newps
Nobody knows that yet. Too many different technologies have come and
gone promising lower costs. When the diesel has proven itself to cost
less in the field I will believe it. Until then it's pure speculation.
I don't know. First off putting $80K into a $50K airplane won't happen
for that reason alone. Second the guy who has $80K to put into a 182
isn't the kind of guy who homebrews his own biodiesel. Simple fact of
the matter is $80K is a deal breaker. Get it down to $40K, about the
same as putting a big engine in a 182, and then you've got something.
But at $80K you won't have any market penetration at all. And really at
$40K look how many 300 HP 550's are in 182's now. I wouldn't call it
rare but it's still a fairly small percentage.
Cost of owning a Diamond DA40, new vs 5-6 years old [email protected] Owning 9 December 28th 10 05:00 AM
Diamond DA40 lap belt extender ... ? Harold Owning 2 July 22nd 06 05:56 PM
Diamond DA40-180 lance smith Piloting 9 December 4th 03 04:00 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
