Diesel for Diamond DA40?
Old May 24th 07, 01:20 AM posted to rec.aviation.piloting
Justin Gombos
Default Converting to diesel - where is the break even point?
On 2007-05-23, Newps wrote:
and you make your own biodiesel at ~$1/gal., would you say the
break even point is acceptable?
I don't know. First off putting $80K into a $50K airplane won't
happen for that reason alone.
I used to fly a c172 trainer that was upgraded from the stock engine
to 180HP. Granted it had to be cheaper than a change in engines that
burn different fuels, but how much different?
Here's the breakdown on the diesel upgrade:
parts: $29k
labor: $46-51k
More of the cost is labor. What's the cost of going from say 160HP to
180HP (both burning the same type of fuel)?
I don't expect to see many folks making a lateral change to diesel for
the sake of economy or range, but if someone wants an upgrade in power
anyway, it may be viable to spend a little more and make it a diesel.
The $80k is not exactly a toss-away investment either, because they
can expect to sell the plane for more as well.
Second the guy who has $80K to put into a 182 isn't the kind of guy
who homebrews his own biodiesel.
Perhaps that's the case with doctors and lawyers who are private
pilots. However, imagine a full-time flight school owner/CFI, who
might often be stuck at the airport 1-2 hours between student
sessions. It's not worth it to go home during this idle time, so they
might as well use the time to make more biodiesel. They would still
charge the same wet fee as they would for gasoline trainers, but the
diesel savings would directly increase profits. At $3-4/gal in
savings, the school would get $30-40/hr more profit on each flight.
And that's assuming fuel costs don't go up, and doesn't account for
the saving inherent in a diesel reguardless of type of diesel. So how
long does it take a busy school to put ~2200 hours on a plane? Unless
I made some gross error, I'd say in ~2-3 years the engine upgrade
would pay for itself.
The school could even gain some business by offering students
discounts for doing the grunt work of making the fuel, thus gain some
business for those who can't quite budget enough to pay regular
prices.
PM instructions: do a C4esar Ciph3r on my address; retain punctuation.
  #32
Old May 24th 07, 04:50 AM posted to rec.aviation.piloting
Newps
Huge. An O-360 doesn't cost that much more new than the 320 it
replaces. Get yourself a field overhauled one and there really isn't
much difference. Those conversions can be done two ways, with a fixed
pitch and with a constant speed. Even going constant speed that's about
a $3K difference.
parts: $29k
labor: $46-51k
Hardly anything. The engine bolts right up. You'll have some labor
installing the prop cable but that's trivial.
The diesel conversion is still a 230 HP aircraft albeit now
turbocharged. The value will certainly rise but not $80K worth. Not
even close.
First off it isn't legal. You got an STC for that biodiesel? Didn't
think so. That mom and pop flight school/FBO located at that nice
quaint airport doesn't sell jet fuel. A very common situation. Now what?
  #33
Old May 24th 07, 10:37 PM posted to rec.aviation.piloting
Justin Gombos
On 2007-05-24, Newps wrote:
You got an STC for that biodiesel? Didn't think so.
This was brought up earlier here, and someone said biodiesel doesn't
need to go through any process to get FAA approval. Supposedly the
fuel only needs to meet the standards required by the manufacturer.
I'm not sure what an STC is.
  #34
Old May 24th 07, 11:19 PM posted to rec.aviation.piloting
Newps
The engine is certified for jet fuel so that fuel is OK. Now you want
to use a different fuel. You have to prove to the FAA that the fuel you
propose to use meets the engine makers requirement. That alone will
take thousands of dollars and years to accomplish. Now you're going to
tell the FAA your going to be homebrewing this concoction in your own
big vat? No way, no how.
Cost of owning a Diamond DA40, new vs 5-6 years old [email protected] Owning 9 December 28th 10 05:00 AM
Diamond DA40 lap belt extender ... ? Harold Owning 2 July 22nd 06 05:56 PM
Diamond DA40-180 lance smith Piloting 9 December 4th 03 04:00 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
