BD-5 crash in Australia
Old May 24th 07, 12:32 AM posted to rec.aviation.homebuilt
ChuckSlusarczyk
Default BD-5 crash in Australia
In article , Morgans says...
"ChuckSlusarczyk" wrote
Think of prayer like chicken soup when you have a cold.It might not help
but
maybe it won't hurt either :-)As atheists you may not think praying has
any
validity but just consider it our way of offering someone our very best
wishes
for good luck and in this case a speedy recovery.
More than that, I think.
I have seen things happen that either are the most improbable collections of
coincidence, or put another way, a miracle of sorts. An atheist looks at it
as the improbable happening, and others look at it as a touch of The
Almighty.
A religious person prays for a person to recover well, and believes that his
God can make it happen. Who is to say that it will not?
In Christianity, the believers are told to love their enemy, (not that the
atheist is an enemy) and pray for non believers. That is what they are
doing.
So, in short, I hope that some combination of happenings combine to
contribute to a fast and full recovery. How I make that wish is a personal
thing, and no less meaningful, no matter who it is for, and no matter how
that hope is expressed.
well said
Chuck S
  #32
Old May 24th 07, 04:28 AM posted to rec.aviation.homebuilt
cavelamb himself
Morgans wrote:
"Stealth Pilot" wrote
maybe the hotdog method of achieving liftoff then maintaing low level
horizontal flight and accelerating like hell before climb out is a
better way of flying them.
interesting.
You may have finally made a positive point for hot-dogging. Anyone think of
a down side?
Not a one.
Richard
  #33
Old May 24th 07, 09:58 AM posted to rec.aviation.homebuilt
Barnyard BOb
On Thu, 24 May 2007 03:28:10 GMT, cavelamb himself
interesting.
a down side?
Not a one.
Richard
Yes, and I'm surprised there is no rebuttal.
If it was better, it wouldn't be called 'hot-dogging.' ;-)
For openers...
The FAA is not known to support 'hot-dogging'.
Neither do legit aircraft manufacturers, AFAIK.
Why?
Like has been said...
It's just hot-dogging.
hot-dogging;
1. to perform in a recklessly or flamboyantly skillful manner,
show off.
2. intended or done to draw attention; showy or sensational.
Although speed can be traded for altitude,
you won't get as much with this technique
or as much opportunity to pick a crash site.
Blast away.
Nomex union suit - ON.
- Barnyard BOb -
  #34
Old May 24th 07, 12:04 PM posted to rec.aviation.homebuilt
Dan Nafe
"Dave" wrote:
"Morgans" wrote in message
doing.
Funny, I've noticed over the years that for the most part the more a person
or group calls on God, the more they love their enemy dead.
True for some religions, but not all.
Frank Tallman said that the P.O.H. and the Bible are two books that are
routinely ignored.
You cannot get "we want you dead" out of either book.
....and don't wait until after a crash to start reading either book!
  #35
Old May 24th 07, 02:22 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 24 May 2007 03:58:41 -0500, Barnyard BOb
For openers...
Why?
hot-dogging;
show off.
Barnyard, the boy and I discussed this technique tonight.
he is of the opinion that it may be the desired way to effect a
takeoff in the BD5.
He said that it is surprising but the wheels should be
raised/retracted as soon as possible after liftoff. The BD5 sees an
immediate jump in speed of 20 knots when the wheels come up.
holding the aircraft low to the ground and accelerating in level
flight does two things.
it gets you to a safer climbout speed faster.
if the engine does quit you avoid the spine destroying thump into the
ground.
most of us have been flying what I'll call FAR23 type aircraft all our
lives. The BD5 is quite a different handling aircraft and needs to
approached with techniques evolved from flying the actual aircraft not
from past FAR23 experience.
Pete has a number of wood strakes along the underside which are an
inch high by half inch wide. he has accidently landed the BD5 with
wheels up and in the slide along the runway the inboard end of the
flaps got ground away and the strakes became half inch by half inch
where they took the rubbing on the bitumen. there was no other damage
and he didnt feel any jolts to the spine.
if he had been low to the ground he might have worn away the strakes
and the lower skin but he would have been spared the spinal injury.
I called it hot dogging because we would all know what I meant but it
may just be the safest way to takeoff in a BD5.
btw his fuel injection is a single point injector not a per cylinder
injection system. he says it usually works well and it solved the
surging problems experienced with the marvel schleber carby he tried
previously.
Stealth Pilot
  #36
Old May 24th 07, 03:46 PM posted to rec.aviation.homebuilt
Peter Dohm
"Barnyard BOb" wrote in message
interesting.
think of
a down side?
Not a one.
Richard
For openers...
Why?
hot-dogging;
show off.
Blast away.
- Barnyard BOb -
Ok, but this is not enough to require Nomex--much less a real, industrial
strength, asbestos suit over it. ;-)
My disagreement is only with calling it Hot Dogging. What Stealth Pilot
suggested, and called Hot Dogging, was really just a soft field take off
without the soft field. Accelerate in ground effect, retract the wheels as
appropriate, and begin climbing at the normal climb speed. I have read that
the proceedure was strongly advised for some low powered retractables, such
as the early Swifts, to reduce the risks during the early part of the
climb--although that had to do with maintaining a usefull climb angle over
obstacles, rather than a possible loss of power.
FWIW, there may be some additional lessons regarding regarding a formation
take off, especially using dissimilar aircraft--which I will leave to those
with the required experience.
Peter
  #37
Old May 24th 07, 07:13 PM posted to rec.aviation.homebuilt
Richard Isakson
"Stealth Pilot" wrote ...
ground.
That wouldn't help on the BD-5. The BD-5 is a very poorly designed airplane
and your friend had the quintessential BD-5 accident. There have been
several accidents and deaths along these lines. These usually happen early
in the testing program. The pilot is new to the airplane and the airplane
has an engine cooling problem. That's inherent in the design and the
designer never solved the problem. The pilot taxis out to the runway as the
engine compartment overheats causing a new problem in the fuel system. Once
on the runway, the pilot applies power pouring more heat into the
compartment. The engine lasts long enough to get in the air and the engine
quits. On the BD-5 all the big weights are down low. The fuel is on the
bottom of the airplane, the pilots center of gravity is low and the engine
is fairly low. That makes the airplane center of gravity low but the thrust
line is up at that top of the airplane. The high thrust line wants to push
the nose down so the pilot has to compensate with aft stick. Now the engine
stops. The clutch disengages the engine and the prop and the prop sits out
there windmilling. A windmilling prop is like a parachute, now trying to
pull the nose up. The airplane controls are commanding nose up already so,
between the controls and the prop, up the nose goes. If the pilot's not
spring loaded to shove the nose down, it won't go down. It will pitch up
violently and the g-loading will go up. This causes the wing skins to
wrinkle and that destroys the wing aerodynamics. The airplane does a high
speed stall and, without altitude to recover, it slams into the runway. If
the pilot's lucky. If not, the airplane stalls asymmetrically and
half-snaps to the inverted position and slams into the runway with generally
fatal results. Your friend was lucky.
Rich
  #38
Old May 25th 07, 07:29 AM posted to rec.aviation.homebuilt
Barnyard BOb
Peter
Peter,
If what was meant by Stealth is as you describe...... establishing
NORMAL climb speed similar to a soft field T.O., I'm with you.
However, if climb out is NOT established at NORMAL
climb speed as soon as practical....
I gotta stick by my original guns. :-)
P.S. All this discussion is rather moot for me,
after reading Rich Isakson's comments.
Barnyard BOb - the devil's in the details
  #39
Old May 25th 07, 07:53 AM posted to rec.aviation.homebuilt
Barnyard BOb
You've just met the wrong people.
Yeah, and there's a helluva lot of 'em to meet!!!
P.S.
Only takes one to kill ya...
or 20 to kill over 3000 in NYC on Sept 11.
- Barnyard BOb -
  #40
Old May 25th 07, 05:41 PM posted to rec.aviation.homebuilt
Peter Dohm
Peter,
I have always thought that the BD5 was a "very cool looking" little
airplane, and it is certainly interesting on how it might have turned out if
the original engineering team had been much more lucky, or possibly
insightfull, in troubleshooting their drive line problems. I also really
think that much of the behavior to which Rich Isakson alludes is more
related to pilot expectation and the relationship between the center of
trust and center of drag than it is to the relationship between the center
of thrust and the center of gravity.
However, in a practical sense, these are really semantic arguments. They
would make a great discussion over a keg of beer; but in the end, I would
never atempt to fly that airplane equipped as described--because I don't
know how to balance it within the weight that the wing can really handle
and, combined with the change in pitching moment from power on to power off,
the damned thing would attempt to kill me.
The bottom line is that we all agree.
Peter
vampire or venom crash pic - wx904 crash.jpg (1/1) [email protected] Aviation Photos 4 January 1st 07 06:30 PM
vampire or venom crash pic - wx904 crash.jpg (0/1) [email protected] Aviation Photos 0 December 30th 06 04:57 PM
Anyone from Sydney Australia here? John Doe Piloting 1 March 14th 06 12:52 AM
Anyone from Sydney Australia here? John Doe Owning 1 March 14th 06 12:52 AM
Australia Badwater Bill Home Built 18 January 3rd 05 03:57 AM
