Is your IFR GPS still legal for use?
Old May 26th 07, 01:08 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Is your IFR GPS still legal for use?
"Roy Smith" wrote in message
But it's legal to fly those very same approaches with a 30 year old ADF
which points vaguely in the direction of either 1) the radio beacon, 2)
nearest T-storm, or 3) some other random propagation anomaly, and an
equally ancient DME which is doing good if it's correct to within 1/4
mile.
Gotta love the FAA. A fine example of why getting all the government
you've paid for is a bad thing.
You can't substitute GPS for ADF on an NDB approach.
Old May 26th 07, 02:47 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Peter R." wrote in message
Admittedly I didn't read the entire circular (I have a Garmin GNS430), but
my quick skim of it seemed to indicate that the non-compliant models are
no longer allowed to use GPS in lieu of ADF or DME, where that is
applicable, unless alternate instructions are provided by ATC. This would
imply that for home-grown RNAV approaches these units would still be
legal. Did I interpret incorrectly?
I didn't read the entire AC either, but I don't see how you or AOPA
conclude that use of GPS to substitute for ADF or DME is now limited in all
cases to the cited Garmin units. The subject of AC 90-100A is "U.S.
Terminal and En Route Area Navigation (RNAV) Operations." The AC says it
"applies to operation on U.S. Area Navigation (RNAV) routes (Q-routes and
T-routes), Departure Procedures (Obstacle Departure Procedures and Standard
Instrument Departures), and Standard Terminal Arrivals (STARs)." The AOPA
letter states, "Pilots have removed ADF and DME systems from their aircraft
and they will no longer have access to any conventional approaches that
require them." I can find nothing that suggests the previous approval to
substitute GPS for ADF or DME has been rescinded for IAPs.
Old May 26th 07, 02:54 PM posted to rec.aviation.piloting
Neil Gould
Recently, Steven P. McNicoll posted:
ADF which points vaguely in the direction of either 1) the radio
beacon, 2) the
mile.
Of course not. If one did that kind of thing, they might actually arrive
at their intended destination.
Neil
Old May 26th 07, 05:29 PM posted to rec.aviation.piloting
Jim Burns[_2_]
I "tried" to read that AC... it is the biggest collection of gibberish that
the FAA has published in a long time. If anybody in the group needs a real
big headache, give it a shot, then report back to the group with your
conclusion.
Old May 26th 07, 06:38 PM posted to rec.aviation.piloting
Judah
john smith wrote in news:4656d17a$0$2829
AvWeb has an article in todays issue saying that only the GPS 400/500
series and G1000 are the only IFR certified navigators that are legal to
use.
From the way I am reading it, it sounds like the restriction is only for
certain types of GPS-specific procedures, such as RNAV-STARs, RNAV-SIDs, and
Q-Routes and T-Routes. I'm not sure what a Q-Route or a T-Route is, but I
have heard of RNAV-STARs and RNAV-SIDs. I've never used them up to now, and
it doesn't worry me much that I won't be able to use them with my current
GPS.
Normal routes (even off-airway, which is specifically mentioned) and normal
STARs, SIDs, and other procedures, even GPS approaches, don't seem to be
covered in this AC.
I'm no lawyer, nor even an expert, but that's how I read it...
Did AOPA get wind of a specific paragraph that is more broad than this?
Old May 26th 07, 08:00 PM posted to rec.aviation.piloting
Bob Noel
conclusion.
some things to consider:
1) AC 90-100A only cancels 90-100. It doesn't cancel
AC 20-130A, for example, or any of the AIM.
2) The AC is for RNAV routes. This does not conflict with the
AIM paragraph on using an appropriately certified GPS installation
in lieu of a VOR, DME, or ADF for non-RNAV routes.
3) Historically, the FAA does not update advisory circulars that also
de-certify the airworthiness of existing equipment, including the
authorization to use it. If they did, the various alphabet soups and
aviation companies would NOT participate in developing new
standards, etc.
Bob Noel
(goodness, please trim replies!!!)
Old May 26th 07, 08:21 PM posted to rec.aviation.piloting
Ron Rosenfeld
use.
GPS.
covered in this AC.
A T-Route is a low altitude RNAV route. I believe they can be numbered
from 200-500 (e.g T200).
A Q-Route is a high altitude RNAV route.
So far as the restriction people have been stating having to do with not
being able to use the uncertified GPS units as a substitute for ADF/DME,
that stems from the AIM (1-2-3) (and possibly a change that has not been
published) restricting this type of usage to units that are compliant with
AC90-100.
--ron
  #28
Old May 26th 07, 08:48 PM posted to rec.aviation.piloting
Judah
Ron Rosenfeld wrote in
with AC90-100.
Ahh... Now I get why I didn't see it.
But the AIM is not regulatory, is it?
If it is, it's a stupid rule. One of the ILSs at my home airport actually
requires an ADF. What a pain.
  #29
Old May 26th 07, 08:50 PM posted to rec.aviation.piloting
Chris
"Danny Deger" wrote in message
"john smith" wrote in message
use.
Does anyone know the rationale for why the GPS receivers can not longer be
used as ADF or DME subs? Or is there any rationale stated by the FAA?
Danny Deger
Certainly the case in parts of Europe especially the UK.
  #30
Old May 27th 07, 01:52 AM posted to rec.aviation.piloting
Ron Rosenfeld
with AC90-100.
Yeah, but there isn't any regulation allowing substitution of GPS for other
NAVAID's.
I think the AIM revision was just published today on the FAA web site. I
find it pretty confusing in terms of which units are allowed to do what.
--ron
Legal or not? Jim Macklin Instrument Flight Rules 42 October 5th 06 12:02 AM
non TSO AI for co-pilot legal? Dico Owning 29 July 22nd 06 09:04 PM
Legal Links [email protected] Piloting 0 May 13th 06 05:04 PM
Legal question PMA Home Built 9 January 14th 05 03:52 AM
Decent below MDA, Legal? Roy Smith Instrument Flight Rules 59 October 4th 03 10:04 AM
