Fuel prices-BTU's per Gal.
Old May 30th 07, 04:10 PM posted to rec.aviation.homebuilt
jerry wass
Default Fuel prices-BTU's per Gal.
Don't like to beat a dead horse, but--
As C.S. Nixon said--"let me make myself perfectly clear"
I agree that a gallon of Mogas has more btu's than a gallon of Avgas
The main reason being--1 gal mogas= 7.422 lbs.
1 gal avgas= 6.978 lbs.
Q.E.D.
Old May 30th 07, 08:58 PM posted to rec.aviation.homebuilt
GeorgeB
On Wed, 30 May 2007 15:10:29 GMT, Jerry Wass
Q.E.D.
Per Wikipedia, and my friends who do weight/balance calcs, the avgasd
number above is alittle, like 18%, off ...
Avgas has a density of 6.02 lb/US gallon at 15 °C, or 0.72 kg/l, and
this density is commonly used for weight and balance computation.
Density increases to 6.40 lb/US gallon at -40 °C, and decreases by
about 0.5% per 5 °C increase in temperature.[3]
[3] is # ^ MacDonald, Sandy A. F.; Isabel L. Peppler [1941] (2004).
"Chapter 10. Airmanship", From The Ground Up, Millennium Edition,
Ottawa, Ontario, Canada: Aviation Publishers Co. Limited, pp. 265,
261. ISBN 0-9680390-5-7.
AirBP says "AVGAS 100LL: Aviation Gasoline for Reciprocating Engines
with lower maximum lead content. Color: Blue. Flash point: Below 0
degrees F. API gravity: 64-7. Relative density: .6582-.7238".
Water is likely the density of 1.000, and is about 8.34 lb/gal
suggesting the 6 lb/gal is a pretty good number.
I'd like to know the source for your 6.978 ...
Old May 30th 07, 10:37 PM posted to rec.aviation.homebuilt
Barnyard BOb
Q.E.D.
Jerry,
Your pet horse may be dead...
but, the autopsy is not yet complete.
Check out the posts after yours.
P.S.
You made yourself perfectly clear while absorbed
in computing one error after another. G
I simply choose to cut to the chase,
posting what the experts established,
probably, a half century ago.
HOW it's done, matters not to me.
I could have presented the math here,
if required, and had your ambition.
Kudos for your efforts and more importantly...
your willingness to admit mistakes. Takes a
real man to do that.
Be well.
- Barnyard BOb -
Old May 31st 07, 01:25 AM posted to rec.aviation.homebuilt
jerry wass
Q.E.D.
My Sources a a 5 gal can of Avgas bought for break-in purposes on my
rebuilt engine--about two weeks ago, and kept in a S.Steel can of the
variety used for holding Coke/Pepsi syrup at vending booths.--air tight.
good for 125 psi(has to hold the CO2 pressure)
a 5 gal jug of Mogas bought a week ago for my lawnmower.
a 250 CC graduated Lab-type beaker, & a metric balance type scale
accurate to 0.1 gm.
The Avgas weighed 168.3 gms/250cc---The Mogas weighed 179.0gm/250cc----
Please let me know If I made any mistakes in the conversion----If not,
I'll re-weigh two more samples tomorrow..
Old May 31st 07, 01:45 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Thu, 31 May 2007 00:25:09 GMT, Jerry Wass
Q.E.D.
accurate to 0.1 gm.
Sounds right to me. SG has an effect on the energy content, but it is
NOT an indicator of octane. MoGas has a higher energy density than
AvGas (generally).
Posted via a free Usenet account from http://www.teranews.com
Old May 31st 07, 06:23 AM posted to rec.aviation.homebuilt
Barnyard BOb
Q.E.D.
Not true, Jerry.
Ready Reference Files
Weight of One Gallon (U.S.) of Water, Gasoline, and Ethanol
1 gallon of water equals 8.33 lbs.
1 gallon of gasoline equals 5.8 to 6.5 lbs.
1 gallon of ethanol equals 6.59 lbs.
Source: U.S. Dept. of Energy. Fuel From Farms: a Guide to Small Scale
Ethanol Production. May 1980. Page D-3.
Verified by: JT, 9/98
Disclaimer:
While the Library has verified the information presented in these
files in what it considers to be reliable and authoritative sources,
it cannot take responsibility for nor guarantee the accuracy of the
information presented.
Avgas
From Wikipedia, the free encyclopedia
Properties
Old May 31st 07, 02:16 PM posted to rec.aviation.homebuilt
GeorgeB
Plugging your avgas numbers into my conversion software, I get 0.371
lb / 0.066 gal for your measurements ... which my calculator gives as
5.62 lb.gal. I didn't run the mogas.
One of us has bad conversion data, maybe both of us.
George
Old May 31st 07, 02:49 PM posted to rec.aviation.homebuilt
jerry wass
George
Doing the simplest conversion---168.3/250.0--= sp.gr.of 0.6732..
0.6732X 8.34(#/gal for h2o)= 5.614 #/gal for Avgas--agreeing with
you--but isn't right---I'm gonna weigh things again--might have been off
on my tare weight. Jerry
Old May 31st 07, 04:56 PM posted to rec.aviation.homebuilt
Barnyard BOb
I don't keep avgas at my house. However....
Weighing 250 cc of 60 degree F. mogas = 190 grams
Specific gravity = 190/250cc = 0.76
0.76 x 8.34 = 6.3384....
MOGAS = 6.3384 lb/gal @ 60 degrees F.
More than close enough for GW Bush gov't work!
Barnyard BOb - definitely beating YOUR dead horse 8-)
Old June 1st 07, 02:25 PM posted to rec.aviation.homebuilt
jerry wass
Q.E.D.
Not true, Jerry.
Disclaimer:
Avgas
Properties
Yes, I'm beginning to doubt my measurements, haven't had time to repeat
them yet. Jerry
Fuel prices--BTU's per gal. George Home Built 3 May 30th 07 09:25 PM
Fuel prices--BTU's per gal. Jerry Wass Home Built 18 May 30th 07 11:15 AM
Fuel Prices Ross Richardson Owning 60 September 30th 05 02:06 AM
Fuel Prices ~R Rotorcraft 0 September 10th 05 03:56 PM
Fuel Prices S Green Piloting 0 May 9th 04 09:47 PM
