#31
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Ken Finney wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Ken Finney wrote: IF I ever get a plane, all these silly fuel issues would be a real irritant. I haven't been paying much attention to the new diesel aircraft engines becoming available. Since I should be making my own biodiesel by the end of this Summer (for something less than 45 cents a gallon), are any of the new diesels in the O-200/Rotax 912 class? You'll never get an STC to put it in a certified aircraft. Better start thinking experimental. I already am, but there an STC for diesels in 172s. Diesels and diesels running Freedom Fry grease are going to require two very different STCs. Robert posted a link to a outfit with a Biodiesel STC but I couldn't get the link to work. As much of the diesel fuel sold today as some biodiesel mixed with it, I'd hope that the engines being sold are certified for petrodiesel, biodiesel, and any combination thereof. "Freedom Fry grease" (aka WVO = waste vegetable oil or SVO = straight vegetable oil) is a different animal than biodiesel. |
#32
![]() "Al G" wrote in message ... "Ken Finney" wrote in message ... "Al G" wrote in message ... "Ken Finney" wrote in message ... clare at snyder.on.ca wrote in message ... On Thu, 31 May 2007 05:11:27 GMT, tony roberts wrote: Is it true that there is no longer any requirement to label gasoline contaminated with alcohol? Worse. I read that, starting in 2007, in some places, California and some Canadian Provinces included, it is regulated that all gasoline sold must contain at least 5% alcohol/ethanol. Tony Here in Ontario I was told not all gasoline must have 5% alky, but 5% of all fuel sold must be alky - so 50% of all fuel sold being E10 satisfies the requirement. In practice, virtually all 87 octane will be e10. Premium 91 will (from some companies, at least) be E0, making the blended 89 E5. Since significantly over half the gasoline sold in Ontario is 87 octane, this would excede the requirements. - Just from what I've been told, but you can never trust the elected idiots, or worse yet the beurocrats IF I ever get a plane, all these silly fuel issues would be a real irritant. I haven't been paying much attention to the new diesel aircraft engines becoming available. Since I should be making my own biodiesel by the end of this Summer (for something less than 45 cents a gallon), are any of the new diesels in the O-200/Rotax 912 class? What do you grow to make biodiesel? Relatives that own restuarants and have to pay to dispose of waste fryer oil! You grow relatives? Well, somebody planted the seed and they tend to grow on their own. I just fertilize them now and then! |
#33
![]() "B A R R Y" wrote in message t... mike regish wrote: I'm pretty sure Mass. is already there. I don't know if there's a minimum, but we've got 10% ethanol everywhere now. Same in CT. I think most, if not all, of the Northeastern states sell the same blend, no longer labeling the pumps for the 10% alchohol content. And that means that all of us using gasohol are getting worse gas mileage than we would get with straight gasoline. If the fuel is 10% ethanol that is 10% less gasoline being pumped while the price has gone up double in the last two years. Energy bill of 2005, eh????? |
#34
![]() "Ron Wanttaja" wrote in message ... On Thu, 31 May 2007 12:08:45 GMT, "Dick" wrote: How is the add water to gas test made ? Thanks See Page 4 of http://www.eaa26.org/apr06.pdf Ron Wanttaja Yup, works real well. A test tube with a 10% level line on it. Fill with water to the 10% line, fill remainder with fuel under test. Shake it up, and if the separation line is higher up the tube that the original water separation line, the water absorbed the alcohol adding to its volume. Works right now basically no waiting... I have not tried Jays Alka Seltzer method.... |
#35
The mower shops are booked up 3 months out cleaning the gook out of carbs.
-Robert Must be why mine was running rough last weekend, it operates maybe twice a month for about 15 minutes or less and it has not been serviced in 10 years. B |
#36
"Blueskies" wrote: "Ron Wanttaja" wrote in message ... On Thu, 31 May 2007 12:08:45 GMT, "Dick" wrote: How is the add water to gas test made ? Thanks See Page 4 of http://www.eaa26.org/apr06.pdf Ron Wanttaja Yup, works real well. A test tube with a 10% level line on it. Fill with water to the 10% line, fill remainder with fuel under test. Shake it up, and if the separation line is higher up the tube that the original water separation line, the water absorbed the alcohol adding to its volume. Works right now basically no waiting... I have not tried Jays Alka Seltzer method.... I tried the Alka Seltzer trick on some denatured alcohol -- no result. It did not fizz! |
#37
![]() And that means that all of us using gasohol are getting worse gas mileage than we would get with straight gasoline. If the fuel is 10% ethanol that is 10% less gasoline being pumped while the price has gone up double in the last two years. Energy bill of 2005, eh????? The oil companies recently blamed the Bush Administration's emphasis on converting to bio fuels as the cause for the price increase in gasoline. Their statement: If they (bush) would support gasoline, then the oil companies would spend money on additional refineries to meet the demand and price could stay low. But with the emphasis on conversion to bio fuels and alternative energy, the oil companies have no incentives to rebuild/repair/build new refineries to meet the increasing consumption demand. So they say as they pocket record profits. BT |
#38
It did not fizz!- Hide quoted text - You talking about "rubbing alcohol"? We tested it with that, and it worked for us. Fizzing, that is... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#39
All of New England has 10% gasohol at the auto pump...
However, it isn't blended in until it gets to this regon... so many aero clubs can still get batches of straight gas Greg Dwinell "mike regish" wrote in message . .. I'm pretty sure Mass. is already there. I don't know if there's a minimum, but we've got 10% ethanol everywhere now. mike "tony roberts" wrote in message news:indiacharlieecho-9E437A.22120430052007@shawnews... Is it true that there is no longer any requirement to label gasoline contaminated with alcohol? Worse. I read that, starting in 2007, in some places, California and some Canadian Provinces included, it is regulated that all gasoline sold must contain at least 5% alcohol/ethanol. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
#40
"orange" wrote in message
news:x6N7i.4362$aW5.2739@trndny09... All of New England has 10% gasohol at the auto pump... However, it isn't blended in until it gets to this regon... so many aero clubs can still get batches of straight gas Greg Dwinell I just saw this on the EAA site: ETHANOL-FREE AUTOFUEL TO BE AVAILABLE AT THREE NEW ENGLAND AIRPORTS STARTING IN JUNE http://www.eaa.org/communications/ea..._autofuel.html |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
