On Thu, 31 May 2007 22:26:36 -0700, Mutts wrote:
worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ No comment on the Zaonflight PCASs, as I have no experience with them... I have flown a Ryan 9900B TCAD equipped Seneca, and found the bearing display a critical part of the TCAD package. Occasionally the Ryan would only show altitude/distance (no bearing), and it was pretty frustrating to only know there is a guy out there... It is REALLY hard to find a plane only by knowing approximate range and altitude delta. This is especially the case when near the pattern, and there are multiple targets. If I was going to buy a Zaonflight, I would shell out the bigger bucks for the one equipped with Bearing. -Nathan |
A friend of mine has a similar unit as this one (diff mfr) and I used it
on a flight. It annoyed me to no end because of the fact there was no bearing information, just altitude and range.. BFD... I still have to look everywhere for the darn traffic. Also, it's quite annoying on the ground. Chris G. Nathan Young wrote: On Thu, 31 May 2007 22:26:36 -0700, Mutts wrote: worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ No comment on the Zaonflight PCASs, as I have no experience with them... I have flown a Ryan 9900B TCAD equipped Seneca, and found the bearing display a critical part of the TCAD package. Occasionally the Ryan would only show altitude/distance (no bearing), and it was pretty frustrating to only know there is a guy out there... It is REALLY hard to find a plane only by knowing approximate range and altitude delta. This is especially the case when near the pattern, and there are multiple targets. If I was going to buy a Zaonflight, I would shell out the bigger bucks for the one equipped with Bearing. -Nathan |
"Mutts" wrote in message
... worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ Ax over on r.a.soaring - they seem to be more popular over there. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Nathan,
We have a non-bearing unit in our plane. No issue at all. Just look outside when the alert comes and you'll find the target. -- Thomas Borchert (EDDH) |
![]() Crossposting over to soaring... worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ Some have commented that the lack of bearing info is a limitation, others not so much. Anyone with lots of experience using this unit or similar, thoughts? Thanks! On Fri, 1 Jun 2007 19:18:47 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: "Mutts" wrote in message .. . worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ Ax over on r.a.soaring - they seem to be more popular over there. |
On Jun 3, 2:34 pm, Mutts wrote:
Crossposting over to soaring... worth 500 clams?..............http://www.zaonflight.com/content/view/2/13/ Some have commented that the lack of bearing info is a limitation, others not so much. Anyone with lots of experience using this unit or similar, thoughts? Thanks! On Fri, 1 Jun 2007 19:18:47 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: "Mutts" wrote in message .. . worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ Ax over on r.a.soaring - they seem to be more popular over there.- Hide quoted text - - Show quoted text - I have never flown with a TCAS, but I would think that relative altitude and range should be enough help you see and avoid. But I do have a question about these units. Do they work when there is no radar facility nearby, or you are below the radar altitude? |
On Jun 3, 2:41 pm, Andrew Sarangan wrote:
I have never flown with a TCAS, but I would think that relative altitude and range should be enough help you see and avoid. But I do have a question about these units. Do they work when there is no radar facility nearby, or you are below the radar altitude? The unit is passive, so relies on the other aircraft's transponder to be replying to an interrogation. In Colorado, fairly low over the mountains, one will be below radar coverage, so a VFR airplane with transponder will not be interrogated, snd so will not be seen by the MRX. I have a few flights now with one of these and find that it does what it's supposed to do. And that is give me a "heads up" when there is a transponder nearby. At a glider contest, it will be constantly reporting the towplanes as they drop off gliders nearby. Near a busy GA airport, it will likely be the same. It will identify and tell you about each new target within a few miles, so will reinforce your scan. It's not a panacea, but just another tool to help me avoid getting run down by a transponder equipped aircraft that may be flying "heads down". -Tom |
A couple of week ago I heard; Glider-Glider-Glider, this is twin umpt-
upm, descending through 20,000 over the Pinenuts for landing at Carson City.I responded that glider Jay Jay was descending through 10,000 on the west side of the Pinenuts. About 3 minutes later the twin said, Jay Jay, I have you on my TCAS and just got a visual on you about 500 feet below and 1 mile east of me. I responded, Roger that, I have you on my PCAS and just got a visual on you also. We both agreed that this was the way its supposed to work. JJ On Jun 3, 11:34 am, Mutts wrote: Crossposting over to soaring... worth 500 clams?..............http://www.zaonflight.com/content/view/2/13/ Some have commented that the lack of bearing info is a limitation, others not so much. Anyone with lots of experience using this unit or similar, thoughts? Thanks! On Fri, 1 Jun 2007 19:18:47 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: "Mutts" wrote in message .. . worth 500 clams?.............. http://www.zaonflight.com/content/view/2/13/ Ax over on r.a.soaring - they seem to be more popular over there.- Hide quoted text - - Show quoted text - |
In article om,
5Z wrote: On Jun 3, 2:41 pm, Andrew Sarangan wrote: I have never flown with a TCAS, but I would think that relative altitude and range should be enough help you see and avoid. But I do have a question about these units. Do they work when there is no radar facility nearby, or you are below the radar altitude? The unit is passive, so relies on the other aircraft's transponder to be replying to an interrogation. In Colorado, fairly low over the mountains, one will be below radar coverage, so a VFR airplane with transponder will not be interrogated, snd so will not be seen by the MRX. The unit won't see other transponders, unless the other transponder is interrogated by a TCAS-equipped aircraft. -- Bob Noel (goodness, please trim replies!!!) |
PCAS - Portable Collision Avoidance System | [email protected] | Soaring | 13 | October 14th 06 07:21 PM |
Collision Avoidance and ATC | Bubba | Soaring | 5 | September 1st 06 04:31 AM |
Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 10:15 PM |
Collision avoidance equipment | samcapt | Products | 2 | May 13th 05 04:41 PM |
Collision avoidance device | Jim Hendrix | Soaring | 1 | October 19th 04 09:24 AM |
