#31
Subject: More long-range Spitfires and daylight Bomber Command raids,
From: Guy Alcala The question is whether there is room (and shackles) for the If there was "room" (stations) then shackles could be fitted. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
#32
Guy Alcala wrote:
The Revolution Will Not Be Televised wrote: On Mon, 08 Sep 2003 05:47:33 GMT, Guy Alcala wrote: snip or even 2 x Hispanos with 2 x .303 MG's in the inboard cannon position available in the C wing, while stuffing a further 10 gallons or so of fuel in the outboard MG positions, as Pete has pointed out. This would be additional to the Mk VII/VIII wing tanks with their (conservative) 25 gallon capacity which were positioned further inboard of the first cannon mounting. Total here would be for something like 35 gallons in the wings additional to the 85 gallon conventional tankage, 29 gallon rear fuselage tankage and external drop tanks of up to 90 gallons capacity. Seems like it would be a lot easier to boost the forward fuselage capacity of the Mk. V/IX up to 96 gallons by swapping in bigger tanks (we know there's room there), before you add all those other tanks and the associated plumbing. I agree you'd still want the L.E tanks, but let's do the easiest stuff first. The extra 11 gallons in the enlarged forward tanks buys perhaps 10 minutes of cruise coming home: let's be _real_ conservative and call it 30 miles. Then we'll also need to enlarge the oil tank at some point. The outboard tanks you describe are so small that I wonder if they're worth the weight of all the plumbing, plus the extra vulnerability (remember that these tanks feed into the main tanks after room has been made in the latter, so they won't be used in combat - no one's going to transfer fuel while they're fighting). Thinking about it further, I don't think the outboard tanks would pass muster. Where would you route the fuel piping, through the gun bays? I'd think that would be absolutely verboten. It makes more sense to try and enlarge the wing L.E. tanks, by not using the inboard cannon station and move the cannon out one station. Delete the O/B MG on each side if necessary, as weight/moment compensation. We might also want to consider developing a drop tank for Mk. VIIIs/IX with VIII tankage to perhaps 125 Imp. Gallons, roughly the internal capacity, just to boost the endurance a bit. We should still be within MTOW limits with the armament installed, while use of the 170 gal. tanks puts the a/c over gross with armament removed. Regardless, it's unlikely we'll ever be able to get a Spit fighter to Berlin and back from the UK. The PR. XI could do it with 216 Imp. Gal. internal (132 in the leading edges) plus a 90 gal. drop tank, but an armed a/c just doesn't have the room for all the fuel. But no matter, by the time we're ready to go there, the RAF will either have its own Mustangs, or be on the continent. Guy |
#33
Guy Alcala wrote: Compared to the original design wingspan (widely cited as 112 feet) 135 ft. isn't such a stretch. Compared to the Stirling production wingspan of 99 feet, it is ;-) But it sure would be nice to see the predicted performance for a Stirling with a 112 foot span, high aspect ratio wing. That wing would be up in B-24 territory. Oh well, I can dream. The original Stirling wing (mechanical & aerodyanmics), was based pretty heavily on the Sunderland wing. ISTR Shorts had dismantled the Sunderland wings, and when the Lerwick turned out to be a flop in 1941, they had to rebuild the jigs to reopen the line to suppliement lend/lease Catalinas. Could have been a good window for you and AVM Stickney to order 112-foot wings (maybe *common* wings? on Stirlings. |
#34
Guy Alcala writes: Peter Stickney wrote: That yesterday seemed to be my day for being obfuscative. I'm back. I've been examining cutaways & measuring & doing sums like a numerate Dervish, and, while I can't give a definitive answer, I can make the following observations: The Mk Vc wing would certainly be suitable for teh leading edge tanks. I'd go so far as to say that if you were really concerned about volume in that area, ditching on or both of the .303 guns in each wing would open up a bunch of space, withoug compromising much in the way of firepower. I don't think that's necessary, as the exploded view of a Mk. XIV in Price's "Spitfi A Documentary History" shows the L.E. tanks are inboard of the cannon. If tanks could also be installed outboard in place of the MGs, then I'd probably go for it and accept the somewhat greater vulnerability in combat, but just getting standard Mk.VIII tankage (123 Imp. Gal. total) would be fine for a start. The big deal with the Mk V, and volume behind the cockpit, is that hteat's where the radios live. Going with a smaller/lighter set would allow something like teh Mk IX's 29 Imperial Gallon tank. Not sure what you mean here, as the Mk. VCs were given a 29 Imp. Gal. ferry tank for the Gib-Malta ferry flights. The later Mk. IX/XVI had 66 Imp. gal. rear tanks. Ah, sorry. Don't forget that I've lagged a bit here. I was just following up on Gavin's question about squeexzing more fuel into a Mk V. Since the engine's a lot lighter, they don't have as much moment on the Good Side of the CG balance, and there isn't any good space insude a Mk V for a substantial amount of fuel. The 29 Imp. Gallon tank is all that you can get an have an airplane that isn't too dangerous for the 1943 RAF. In irder to geep that influence to a minimum, a medium-sized drop tank would also be necessary, to keep the CG where it ought to be. My point about the radios was that the early Brit TR sets were, when you include their rectifiers * transformers, about 200# of load, and quite a bit of space. If that 200# could be cut in half, that's 15 Imperial Gallons of fuel that yo could squeeze in. Note that on the Mk IX, the only way to keep the CG acceptable with the aft tank was to use it only in conjunction with one of the belly tanks. H'mm, at least with the Mk. XIV, the Cg moves aft when drop tanks are carried, not forward. See http://www.fourthfightergroup.com/ea...41weights.html Yep. Yhe Mk IX's got it nearly on the CG datum, though. I'll get the tracing paper & rulers & see if I can come up with som emore detail. don't really view that as a big deal for an escort fighter, unless you expect to be engaged immediately at the French Coast. The recommended tank sequence would be, after takeoff, to use the aft fuselage tank, then the external tank. (I keep wanting to call that marsupial-looking excrescence the "carbuncle", for some reason) The 29 Imp Gal tank should last somewhere between 15 minutes to 1/2 hour, depending on power settings, so that gets you through form-up, climbout, and pretty much across the Channel. Part of the pilot's notes for the F./F.R. XIV are online, and the FR. XIV flight restrictions contains the following statement: "On F.R. Mk. XIV a/c it is essential, for reasons of stability, that the rear fuselage tank should be emptied before flying at altitudes in excess of 15,000 feet." It also states that the fuel tank sequence for the F.R.14 is t/o on main tanks, switch to rear fuselage tank and empty it, then feed from drop tank. See http://www.geocities.com/spades53.ge...4_notes_13.jpg ISTR that this tank is ca. 33 gallons. Which is about enough to climb about 5,000' with a Griffon Spit. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#35
#36
Guy Alcala wrote in message .. .
Peter Stickney wrote: As for the Stirling, well, actually, fir all its bulk, it doesn't seem that heavy.They really should have taken the fuselage out of hte box before they bolted the wings on, though. The empty weight (46,000 lb. IIRR) has always seemed far higher than was the case with the Lanc or Halifax, and the MTOW (70klb. IIRR) not that much more. It is possible that this is a mistake and isactually the OWE rather than the empty weight losted for the others. Still, its range with a comparable bombload is significantly less than either, and while the wing design undoubtedly plays some part I expect the main factor is the restricted useful load. Shorts' structural methods seem to stem from the flying boats, and appear a bit out of date. From the Stirling file by Michael Bowyer Early Stirling I, Hercules II engines, the first production aircraft N3635 came in at 41,160 pounds tare when under trials, max take off weight 64,000 pounds initially. Stirling III, Hercules VI/XVI tare weight 44,856 pounds, max flying weight 70,000 pounds. The tare weights appear 2 to 3 tons more than the Lancaster and Halifax. The books notes the advantages of the "strongly built" airframe as well as the penalties. Apparently the outboard sections of the wing were watertight. Interestingly the Stirling's wing area was 1,460 square feet, Lancaster 1,297, later Halifaxes 1,275, B-17 1,420, B-24 1,048 and B-29 1,736. The Stirling wingspan was 99 feet 1 inch versus the B-17 103 feet 9 inches, it was also the thickest wing, able to carry bombs in cells within the inner wing. three cells on each side capable of carrying 500 pound bombs at least. Geoffrey Sinclair Remove the nb for email. |
#37
In article , Geoffrey Sinclair
writes Apparently the outboard sections of the wing were watertight. Interestingly the Stirling's wing area was 1,460 square feet, Lancaster 1,297, later Halifaxes 1,275, B-17 1,420, B-24 1,048 and B-29 1,736. I'm not disputing the figures above, but I thought the B-24 had a larger wing area than most contemporary bombers allowing it to fly higher? -- John |
#38
In article , John Halliwell
writes In article , Geoffrey Sinclair writes Apparently the outboard sections of the wing were watertight. Interestingly the Stirling's wing area was 1,460 square feet, Lancaster 1,297, later Halifaxes 1,275, B-17 1,420, B-24 1,048 and B-29 1,736. I'm not disputing the figures above, but I thought the B-24 had a larger wing area than most contemporary bombers allowing it to fly higher? Was it not the thick section Davis wing that gave it the improved lift? Cheers, Dave -- Dave Eadsforth |
#39
On Tue, 9 Sep 2003 15:13:14 +0100, Dave Eadsforth
wrote: In article , John Halliwell writes In article , Geoffrey Sinclair writes Apparently the outboard sections of the wing were watertight. Interestingly the Stirling's wing area was 1,460 square feet, Lancaster 1,297, later Halifaxes 1,275, B-17 1,420, B-24 1,048 and B-29 1,736. I'm not disputing the figures above, but I thought the B-24 had a larger wing area than most contemporary bombers allowing it to fly higher? Was it not the thick section Davis wing that gave it the improved lift? Cheers, Dave The Davis wing was a high aspect ratio wing with a low angle of attack. Al Minyard |
#40
Alan Minyard wrote:
The Davis wing was a high aspect ratio wing with a low angle of attack. Al Minyard Is there something that I'm missing here?...how can a wing's design decide that?...I'd think that only the elevators could control the AOA?. -- -Gord. |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
