Bad pilots, bad maintenance ruining general aviation
Old June 6th 07, 12:55 PM posted to rec.aviation.piloting
Default Bad pilots, bad maintenance ruining general aviation
On Jun 6, 2:06 am, Mxsmanic wrote:
Look for leaks. A leak will manifest by an excess of water at some point on
the lawn.
This dork actually posted this.
  #62
Old June 6th 07, 03:44 PM posted to rec.aviation.piloting
Maxwell
"Mxsmanic" wrote in message
United 232 was faulty maintenance. There was a crack in the engine that
had
gone undetected, even though it had been inspected. If it had been
properly
maintained, there would have been no crash.
You really are clueless. How, specifically, did mantenance fail 232?
  #63
Old June 6th 07, 03:47 PM posted to rec.aviation.piloting
Maxwell
Viperdoc writes:
Now how would you know if my airplanes are half broken, or that I fly
recklessly?
If you have an accident, that's prima facie evidence of one or the other.
If
you're an excellent pilot in a properly maintained aircraft, you won't
have an
accident.
If life is that simple, why do you confine yourself to a basement and
simulator?
It sounds like you're envious of the fact that while many of us actually
fly
real airplanes, you'll never have the experience of flying anything other
than a chair.
Pilots like to think that everyone envies them. More generally, most
people
who like a particular activity like to think that everyone else not
engaged in
that activity envies them. Of course, this is all wishful thinking.
You're the best example of wishful thinking around here, on most any topic.
  #64
Old June 6th 07, 03:49 PM posted to rec.aviation.piloting
Maxwell
Skylune writes:
Since you are expert in everything, I am having a problem with low
pressure in one of the zones on my lawn sprinkler system. Could you
provide some advice on how to diagnose the problem and then fix it?
on
the lawn.
Take your meds.
  #65
Old June 6th 07, 04:13 PM posted to rec.aviation.piloting
On Jun 6, 12:02 am, Mxsmanic wrote:
tom418 writes:
Too bad you weren't aboard United 232 back in 1989. I'm sure you could have
averted the disaster.
United 232 was faulty maintenance. There was a crack in the engine that had
gone undetected, even though it had been inspected. If it had been properly
Bull****! The crack in the engine had absolutely nothing to do with
maintenance. It was a flaw that existed when the turbine blade was
fabricated. It was not detected in initial inspections of the parts
by the manufacturer, and there was no way that maintenance could have
ever detected it until it failed due to its microscopic nature. If
the manufacturer couldn't see it, what makes you think that Joe
mechanic should have tools that would allow him to see it?
  #66
Old June 6th 07, 06:11 PM posted to rec.aviation.piloting
Jim Stewart
Mxsmanic wrote:
Bertie the Bunyip writes:
Could be worse, you could be flying, or trying to.
I'm actually almost pathologically safety-conscious in vehicles, and I would
be an extraordinarily safe pilot.
Doesn't matter how safety-conscious you are if
you're having an anxiety attack and loosing
bowel control on final....
  #67
Old June 6th 07, 07:30 PM posted to rec.aviation.piloting
Mxsmanic
Maxwell writes:
They performed multiple FPIs on the failed fan disk (proved by the presence of
traces of the dye on the part that failed) without actually noticing that the
results indicated a problem.
See NTSB/AAR-90/06 for details.
  #69
Old June 6th 07, 07:40 PM posted to rec.aviation.piloting
Mxsmanic
Maxwell writes:
simulator?
I don't.
  #70
Old June 6th 07, 10:02 PM posted to rec.aviation.piloting
Skylune
On Jun 6, 1:49 am, Mxsmanic wrote:
Skylune writes:
What mistake? Did you obtain gainful employment?
I guess it was an ironic coincidence, then.
Best not to criticize others for a perceived lack of research unless one does
at least as much research oneself.
Listen fool: Some of the pilots here with whom I have quarreled with
in the past even acknowledged that I attached references to studies on
things like the FAA funding formula, etc.
You on the other hand just spew trash about anything and everything.
FA: 1-Day-Left: 2 Books: POWERPLANT & GENERAL - ASA AVIATION MAINTENANCE TECHNICIAN SERIES Adam Aviation Marketplace 0 June 24th 06 11:48 AM
FA: 2 Books: POWERPLANT & GENERAL - ASA AVIATION MAINTENANCE TECHNICIAN SERIES Brian Aviation Marketplace 0 June 19th 06 03:04 AM
For those in General Aviation. Darren Piloting 2 October 7th 05 04:36 PM
For those in General Aviation. Darren Products 0 October 7th 05 04:42 AM
ENHANCED AVIATION SECURITY PACKAGE ANNOUNCED (All "General Aviation Pilots" to Pay $200.00 every two years!) www.agacf.org Piloting 4 December 21st 03 09:08 PM
