Head orientation in turns--how is it taught for aviation?
Old June 11th 07, 05:21 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Head orientation in turns--how is it taught for aviation?
"Maxwell" wrote in
.130...
"Maxwell" wrote in
A 1g barrel roll can be done, but the required trajectory of the
aircraft is not going to be one that is necessarily eye pleasing for
ground demonstration purposes.
Nope. the only thing you can do at 1 G is straight and level flight.
You can keep positive G around a barrel roll, but not 1 G
If you enter nose high (enough), and exit nose low (enough), you
should be able to maintain close to one g. But then would it still be
called a barrel roll.
mmm, nope. Not even close., If you fly it really accurately you might be
able to keep the entry end exit under two g, but I doubt it. If you fly
it very slack, you'll go, at best, Zero G over the top and probably
negative.
To keep positive G you need well over tow at entry and exit, to keep a
little over one as you pass 90deg, then you can probably keep a bit over
a half a G over the top and then pretty much the same down the other
side.
I'll have to admit, I've never specifically watched the g meter while
doing so, but if you are sloppy enough, it seems prettly close.
I have watched it. Quite a lot, in fact. I've been hearing this story
since I've been flying, It was wrong back then and it's wrong now. Even
if you dump the nose as you suggest on the way down, you're stil going
to have to pay for it eventually...... And on the way up, no way.
Bertie
  #92
Old June 11th 07, 06:08 AM posted to rec.aviation.piloting
Dudley Henriques
On 2007-06-11 00:21:38 -0400, Bertie the Bunyip said:
"Maxwell" wrote in
.130...
"Maxwell" wrote in
negative.
side.
Bertie
Bertie is correct. Barrel Rolls are perhaps the most misquoted and
misunderstood maneuver done in an airplane.
Basically, you can do a barrel roll as loosely or as tight as the
airplane's flight envelope will allow. You can also enter a BR from
many different flight conditions involving many different g loadings.
The main thing to remember about barrel rolls is that they are a 3
dimensional maneuver through 3 dimensional space and that the common
denominator in a barrel roll regardless of the g used is that it will
remain POSITIVE all the way around. The one exception to this would be
after the pull and roll application, you can unload the airplane over
the top and drop the g to +1 if you like to loosen the roll rate, but
that g must be regained during the recovery.
Basically, you will be somewhere over +1g in the entry as you raise the
nose, then at some positive +g throughout the roll ranging from as
unloaded as you want to loosen up the airplane or as high a positive g
and tight a roll as the envelope will allow. As long as the airplane
transverses 3 dimensions through the roll, it's a barrel roll.
I've done them as loose as a 90 degree change of direction at the top
apex in a P51,the F8F, and several jets including the T38, and as
tight as a corkscrew in a Pitts S1Sl which was highly loaded with +g
and extremely tight.
Bob Hoover's rather famous Iced tea stunt in the Shrike is probably
responsible for much of the misconception about barrel rolls. He does
them fairly loose and with just enough positive g on the airplane to
keep the glass from spilling without stressing the airplane. The
"secret" to Bob's tea trick is simply his smoothness through the roll
as much as keeping positive g on the tea. It's really this smoothness
that makes this stunt possible, as although positive g will keep the
tea inside the glass. (You can actually POUR tea as you're rolling the
airplane but ONLY if you're as smooth as Hoover :-)
The reason smoothness is so necessary for the tea trick is that even
though you might have positive g on the airplane and in effect doing a
barrel roll, if you are not perfectly coordinated through the roll (any
excessive yaw for example) your tea will slide off the glare shield
laterally and you don't want that......not if you're Bob Hoover anyway
So it's positive g for the roll, and smoothness and perfect
coordination for the tea stunt.
Hope this helps a bit.
Dudley Henriques
  #94
Old June 11th 07, 06:23 AM posted to soc.culture.turkish,rec.aviation.piloting,alt.usenet.kooks,alt.fan.karl-malden.nose,soc.culture.british
Mxsmanic
Maxwell writes:
A 1g barrel roll can be done, but the required trajectory of the aircraft is
not going to be one that is necessarily eye pleasing for ground
Any maneuver that involves a change in altitude will involve forces exceeding
1 G at some point.
  #95
Old June 11th 07, 06:25 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
writes:
Parsing these sentences, your "training" wasn't in an actual aircraft,
ever.
Aircraft are not used for motorcycle training.
Q.E.D. You must think we're stupid.
See above. What do you think?
  #98
Old June 11th 07, 06:37 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
JB writes:
Actually, Anthony, ALL of your questions remain unanswered because you
refuse to accept the answers when given.
Not true. I do get useful answers occasionally. And acceptance or rejection
is not an issue.
I do occasionally ask questions to which I have the answers (albeit not this
one). If a "pilot" answers them correctly, I have reason to believe that he
knows what he is talking about, in which case he may be a useful source of
answers to questions for which I don't have the answers. It surprises me how
few "pilots" can answer the test questions correctly, and so I've had to write
off quite a few people in this newsgroup as blowhards.
And ALL pilots know
infinitely more about aviation than you do because they took the time
to learn how to fly in a real plane and usually have years of
experience flying.
That is a manifestly false assumption; it amazes me that so many pilots cling
to it. Since when does 40 hours of experience, mostly trial and error, make
anyone an expert at anything? I'm surprised by how many extremely-low-time
pilots there are around, too.
  #99
Old June 11th 07, 07:18 AM posted to rec.aviation.student,rec.aviation.piloting
Montblack
("Viperdoc" wrote)
Now, please proceed to impress us with your knowledge about the vestibular
system.
Me. Me. Call on me. I know. I know.
I should know the answer - after all, I was an alter boy.
P-Mont
  #100
Old June 11th 07, 09:10 AM posted to rec.aviation.student,rec.aviation.piloting
Thomas Borchert
Mxsmanic,
Tilt his head 60 or 90 degrees, which most people can do without difficulty.
Things are getting better and better.
Thomas Borchert (EDDH)
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
