#71
John Halliwell wrote:
Mike Marron wrote: Not to mention the Superfort's extra *4,000* total horsepower and four humongous four-blade 17-ft. diameter props! That brings a comparison between the B-29 and Shackleton wings/engines into the equation I guess. Nah, the Shackleton was a frumpy Brit post-war bomber hopelessly outclassed by the sleek and futuristic B-29 which actually saw combat in both WW2 and Korea and later copied by the Soviets. If you want to compare post-war recip bomber aircraft, you'd have to compare the Shackleton to the B-50 in which case the Shackleton becomes even more hopelessly outclassed: Shackleton total HP: 9,600 (B-50: 14,000) Shackleton max speed: 287 mph (B-50: 385 mph) Shackleton service ceiling: 22,000 ft. (B-50: 37,000 ft.) Shackleton range: 2,500 miles (B-50: 4,650 miles) Shackleton bombload: 18,000 lbs. (B-50: 20,000 lbs.) -Mike Marron |
#72
Peter Stickney wrote:
snip "Quest for Performance", L.K. Loftin, NASA History Office, 1985, available online, has a quite good explanation and analysis of the directions that designing high performance airplanes took through the first 80 or so years. The data tables list the following values for the various airplanes. Airplane: Aspect Ratio Wing Loading Cruise Speed L/Dmax B-17G 7.58 38.7 182 12.7 B-24J 11.55 53.4 215 12.9 B-29 11.50 69.1 253 16.8 Altitudes in cases would be 25,000', (Critical Altitude for the turbosupercharged engines, in each case) and all speeds are True Airspeed. Something appears seriously wrong with the B-17G cruise speed. At 25,000 feet, 182 TAS works out to only 124 CAS, and we know the a/c normally cruised at 150-160 IAS (TAS about 215-240 at typical bombing altitudes) and climbed at about 130-140 IAS, vs. 160-180 IAS cruise for the B-24. There's no way the position error is that high, and compressiblity error is just 1-2% at that speed and altitude. Guy |
#73
Mike Marron wrote:
As I mentioned in my response to you (the important part that you snipped), besides just increasing the visibility, the variable incidence wing also enabled the sleek and very fast fighter to maintain the slower speeds required for carrier ops. That doesn't make sense to me Mike...as Peter and John say the higher AoI used for landing allows the fuselage to be more horizontal (better pilot visibility, keeps the tail higher when in landing attitude and allows for shorter (stronger) undercarriage... In other words Gord, the variable incidence wasn't designed to give the F-8 "less drag for high speed operation," I think it was, it gets the fuselage 'more in line with the wing chord' which 'has' to reduce drag. Why do all the engineering to design this complication if it isn't a very important aspect?. I think that the 'only' reason for the 'variable AoI' was to allow for low drag (and high speed) flight yet ~normal fuselage attitude for landing (for pilot vis plus normal u/c config)... I think that it's possible that on an a/c with a very low AoI like this the extreme nose up attitude of the fuselage (to get enough AoA on short final) may not be 'liveable' because of what John mentions (tail strikes) plus very poor pilot visibility plus the requirement for very longlegged u/c as Peter mentioned. it was designed to give the F-8 MORE drag (as the result of more LIFT) for SLOW speed operation in order to land aboard carriers. Why?...you won't get any more 'lift and drag' (you can get all you want with the elevators) BUT you WILL have a much more fuselage 'nose up' attitude if you cannot increase your AoI for landing. -- -Gord. |
#74
In message , Mike Marron
writes If you want to compare post-war recip bomber aircraft, you'd have to compare the Shackleton to the B-50 in which case the Shackleton becomes even more hopelessly outclassed: Compare out-of-service dates before you get too carried away ![]() -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#75
"Gord Beaman" ) wrote:
Mike Marron wrote: As I mentioned in my response to you (the important part that you snipped), besides just increasing the visibility, the variable incidence wing also enabled the sleek and very fast fighter to maintain the slower speeds required for carrier ops. That doesn't make sense to me Mike...as Peter and John say the higher AoI used for landing allows the fuselage to be more horizontal (better pilot visibility, keeps the tail higher when in landing attitude and allows for shorter (stronger) undercarriage... With regards to the the improved visibility aspect, Peter and John didn't just say it, everybody (including you and me) said it. Regarding the part that you don't seem to get (increasing the angle of incidence so as to help the jet maintain slower speeds for carrier ops), well, I've tried explaining it to you numerous differerent ways now and you still don't/won't get it. Therefore, I'm done. Maybe someone else can try explaining it to you Gord. -Mike Marron |
#76
Mike Marron wrote:
"Gord Beaman" ) wrote: Mike Marron wrote: As I mentioned in my response to you (the important part that you snipped), besides just increasing the visibility, the variable incidence wing also enabled the sleek and very fast fighter to maintain the slower speeds required for carrier ops. That doesn't make sense to me Mike...as Peter and John say the higher AoI used for landing allows the fuselage to be more horizontal (better pilot visibility, keeps the tail higher when in landing attitude and allows for shorter (stronger) undercarriage... With regards to the the improved visibility aspect, Peter and John didn't just say it, everybody (including you and me) said it. Regarding the part that you don't seem to get (increasing the angle of incidence so as to help the jet maintain slower speeds for carrier ops), well, I've tried explaining it to you numerous differerent ways now and you still don't/won't get it. Therefore, I'm done. Maybe someone else can try explaining it to you Gord. -Mike Marron Ok Mike...thanks for your efforts anyway, I appreciate it. -- -Gord. |
#77
"Paul J. Adam" wrote:
Mike Marron writes If you want to compare post-war recip bomber aircraft, you'd have to compare the Shackleton to the B-50 in which case the Shackleton becomes even more hopelessly outclassed: Compare out-of-service dates before you get too carried away ![]() I once knew a barber who had been cutting hair for 40 years... -Mike ( never was capable of giving a decent haircut Marron |
#78
writes "Paul J. Adam" wrote: Mike Marron writes If you want to compare post-war recip bomber aircraft, you'd have to compare the Shackleton to the B-50 in which case the Shackleton becomes even more hopelessly outclassed: Compare out-of-service dates before you get too carried away ![]() I once knew a barber who had been cutting hair for 40 years... -Mike ( never was capable of giving a decent haircut MarronYeah, but the B-50 was completely outclassed by the B-36 and look how long _that_ lasted... Meanwhile the Shackleton flew on until the 1980s, and the almost equally ancient Canberra flies on still. When a design finds the right niche, it can be very long-lived. (Look at the C-130 and the B-52) -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#79
Meanwhile the Shackleton flew on until the 1980s, and the almost equally ancient Canberra flies on still. When a design finds the right niche, it can be very long-lived. Thank gawd the Brits managed to find a niche for the Shackleton other than as a post-war strategic bomber! -Mike (Shackleton = easy pickins) Marron |
#80
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
