Myth: 1 G barrel rolls are impossible.
Old June 13th 07, 06:38 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Myth: 1 G barrel rolls are impossible.
Mxsmanic wrote in
Robert M. Gary writes:
Do you believe that a pilot at the top of a loop can experience
possitive G's?
Absolutely.
You'll never ever do a loop fjukkwit.
Bertie
  #112
Old June 13th 07, 12:15 PM posted to rec.aviation.piloting,rec.aviation.student
Viperdoc[_4_]
That's the point you idiot- there is no change in direction during a
vertical roll.
"Mxsmanic" wrote in message
Viperdoc writes:
Think about it- a roll on the vertical does not apply any g to the
airplane.
Any change in direction accelerates the airplane, and thus applies Gs to
it.
During a vertical roll there is no acceleration in the z or y axes.
Any change in direction accelerates the airplane.
  #113
Old June 13th 07, 05:09 PM posted to rec.aviation.piloting,rec.aviation.student
Got it. What happens to the g force acting on me as a pilot if I start
in straight and level, unaccelerated flight, and then I use down
elevator and enter a descent?
On Jun 13, 12:56 am, Mxsmanic wrote:
writes:
What happens to the g force acting on me as a pilot if I start in
straight and level, unaccelerated flight, and then I initiate a
coordinated turn?
The net force increases, as it results from both that induced by gravity
(which is constant) and that induced by your acceleration torwards the center
of the turn. In a coordinated, level turn, the force vector will be normal to
the airframe, and so you will have the impression that you are climbing
initially; when you finish the turn you'll have the impression that you are
descending briefly. This assumes that you keep your head level with the
wings.
  #114
Old June 13th 07, 05:14 PM posted to rec.aviation.piloting,rec.aviation.student
Jon
vertical roll.
Kinda like trying to run underwater, isn't it?
Making the point, that is
  #116
Old June 13th 07, 07:32 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Viperdoc writes:
vertical roll.
You cannot change the attitude, direction, altitude, etc., of the aircraft
without changing its direction in some plane, and that requires acceleration.
  #117
Old June 13th 07, 08:03 PM posted to rec.aviation.piloting,rec.aviation.student
Interesting. So if I enter a coordinated turn, the G force increases.
If I enter a descent, the G force decreases.
What happens if I do both of these things simultaneously?
On Jun 13, 2:31 pm, Mxsmanic wrote:
writes:
As you descend, you are accelerated downward. This acceleration is subtracted
from the constant acceleration imposed by gravity. If your acceleration
downward is less than 1.0 G, you experience a diminished G force, unchanged in
direction. If it is equal to 1.0 G (which would be quite a feat), you will
experience no G force at all. If it is greater than 1.0 G (unlikely indeed),
you'll feel a negative G force tending to lift you out of your seat. These
changes persist only for as long as you are accelerating downward; once you
are descending at a steady rate, you will again experience exactly 1.0 G.
writes:
coordinated turn?
gravity
center
normal to
climbing
you are
wings.
  #118
Old June 13th 07, 08:08 PM posted to rec.aviation.piloting,rec.aviation.student
El Maximo
Blue Screen of Death?
  #119
Old June 13th 07, 09:38 PM posted to rec.aviation.piloting,rec.aviation.student
george
ROTFL
  #120
Old June 13th 07, 10:43 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Why?
mike
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
