Sigmatek Aeon Vacuum pump?
Old June 14th 07, 05:09 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Doug Palmer
Default Sigmatek Aeon Vacuum pump?
Does anybody have any real world data on this piston version of a vacuum
pump?
http://www.sigmatek.com/1U478-003/1U...troduction.htm
I do not have an installation that readily allows a wet pump, and most of
the folks on our field believe that dry pumps are the worst idea that have
been propogated on GA in a long time
Reliability?
Does it provide good vacuum comparable to rotary vane types?
How many hours do you have on it?
Thanks in advance
Doug
Old June 14th 07, 12:20 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Denny
pump?
Reliability?
Thanks in advance
Doug
Change your dry pump every 500 hours and be happy...
denny
Old June 14th 07, 01:03 PM posted to rec.aviation.owning
Joyce
On Thu, 14 Jun 2007 04:09:30 GMT, "Doug Palmer"
pump?
Reliability?
Thanks in advance
Doug
I put one in a cheroke archer and it failed within 30
hours. Got another one from the factory, put it in and that
one failed within 40 hours. Both failures was seizure of
the piston and breakage of the plastic drive coupling.
Talking with one of the employees at the factory indicated
that they were having a problem with this sort of thing
happening and they were working on a solution. They offered
to replace the second one with another unit. I said no
thanks, just give me my money back. I went back to a Rapco
vane type pump. Had to eat the shipping costs and labor for
all the installs. That is my experience with these
pumps.......
Sigmatek Aeon Vacuum pump? Doug Palmer Piloting 1 June 14th 07 12:20 PM
Vacuum pump STC gt Instrument Flight Rules 3 August 16th 06 01:42 AM
Wet vs Dry Vacuum Pump Fastglasair Owning 7 December 17th 04 11:46 PM
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 07:03 PM
