Myth: 1 G barrel rolls are impossible.
Old June 14th 07, 10:04 PM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
Default Myth: 1 G barrel rolls are impossible.
Hang on, let's keep things simple:
1. If I enter a coordinated turn, I experience an increase in Gs.
2. If I enter a descent, I experience a decrease in Gs.
If I do these two things at the same time, it is possible to enter a
descending turn without any change in Gs. Just as long as I
continously feed in enough down elevator to offset the increasing Gs
from the turn, the force on the airframe and me, the pilot, will stay
at 1 G.
Of course, all combinations are indeed possible. But this interesting
special case of the situation exists, doesn't it, in which there is no
change in the force felt by the pilot?
On Jun 14, 3:36 pm, Mxsmanic wrote:
writes:
'Some combination', 'several possibilities.' I'm confused by this -
can you be more precise? What are the possibilities?
You can move and accelerate in any combination of three dimensions, with any
combination of acceleration rates, almost. You have to calculate the
direction and magnitude of the net acceleration vector to determine exactly
how much force is acting upon the pilot, and in which direction.
Some of it is (or should be) intuitive. For example, if you turn the aircraft
to the right, you'll be accelerated to the right.
There is a special case where you can unload the airplane in roll to
increase the roll rate. It's done in fighters all the time in ACM. You
can experience it in your everyday light aerobatic airplane by doing an
aileron roll from a nose high roll set position, then as the airplane
goes past the first knife edge position, go forward on the pole to
unload the wings but not enough to go negative. Keeping the aileron in
hard while you do this increases the roll rate and as a side effect
flattens the roll in pitch at the same time making it prettier :-)
Dudley Henriques
  #143
Old June 15th 07, 12:19 AM posted to rec.aviation.piloting,rec.aviation.student
Jim, you don't have to do the physics for a 1 g roll. click on
stanford.edu/~sigman/one_g_roll.html for a really neat analysis.
Page down toward the end of sigman's article to see the actual flight
paths that it takes. It's a neat read.
Oh, for the nonbelievers in Newton and vector analysis and such (Mx
whatever comes to mind) don't bother.
  #144
Old June 15th 07, 12:21 AM posted to rec.aviation.piloting,rec.aviation.student
OPPS, It's www.stanford.edu/~siegman/one_g_roll.html
  #145
Old June 15th 07, 12:46 AM posted to rec.aviation.piloting,rec.aviation.student
george
at 1 G.
Isn't there some sinister name for this
when it happens to a non-IFR pilot in a cloud?
Graveyard spiral dive
  #146
Old June 15th 07, 01:47 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
OPPS, It's
Fascinating - thanks for finding that! Amusing to note that a physicist of
that caliber was motivated to explore the situation due to an older thread
on the same subject on the same Usenet newsgroup! I considered setting up
the same situation using Mathcad 2000 (it can generate animations, so I
think I could have set up appropriate parametric equations and created a 3D
movie). But I just don't have the time at the moment to do that.
At least I feel better that my physical intuition didn't fail me.
The nit pickers may (reasonably) argue that the trajectories don't yield
the "barrel roll" spiral they might insist on, but such is life. I should
have titled this thread "Myth: 1 G rolls are impossible," and dispensed
with the word "barrel."
  #147
Old June 15th 07, 02:02 AM posted to rec.aviation.piloting,rec.aviation.student
Wasn't the demonstration of the ignorance of physics by some of the
posters fun?
I don't think a GA airplane has the control authority to do one of
these 'rolls' but maybe.
But you could start the thing with a coordinated turn and forward
yoke, and maybe get to 45 degrees bank and a lot of downward pitch
maintaining 1 G before getting back to straight and level,
His first model with 10 seconds total time means 320 fps downward
velocity, about 200 kts down at its end. He pointed out the total
altitude loss from start to finish was 1600 feet or so, but then
comes pull out from lots of vertical speed. Moral: start high and
pull out smoothly or turn the airplane into a kit.
OPPS, It'swww.stanford.edu/~siegman/one_g_roll.html
  #148
Old June 15th 07, 02:46 AM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
Why does this work?
Matt
  #150
Old June 15th 07, 02:57 AM posted to rec.aviation.piloting,rec.aviation.student
Ash Wyllie
tbaker27705 opined
It's http://www.stanford.edu/~siegman/one_g_roll.html
-ash
Cthulhu in 2007!
Why wait for nature?
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
