VOR GPS Coordinates
Old June 15th 07, 04:00 AM posted to rec.aviation.piloting
Google Madness
Default VOR GPS Coordinates
Since I use a non-aviation GPS when I fly, I only have airports and not VORs
in the Garmin database of streets and places.
So I put together this .gpx file (GPS eXchange format) which can be imported
into GPS Applications and downloaded into the GPS.
I also included a comma delimited text file of values.
Hope someone else finds this useful too.
Gino
Old June 15th 07, 01:18 PM posted to rec.aviation.piloting
Google Madness
See alt.binaries.multimedia.aviation for the file
"Google Madness" wrote in message
news:Ahnci.8234$pd5.7914@trnddc02...
VORs
imported
Gino
Old June 15th 07, 02:15 PM posted to rec.aviation.piloting
Paul Tomblin
Or they could go to my Aviation Waypoint Generator and generate a GPX file
for themselves.
http://navaid.com/GPX/
Paul Tomblin http://blog.xcski.com/
"The surreality of the universe tends towards a maximum" -- Skud's Law
"Never formulate a law or axiom that you're not prepared to live with
the consequences of." -- Skud's Meta-Law
Old June 15th 07, 05:52 PM posted to rec.aviation.piloting
john smith[_2_]
Paul, what does your site do with the cookies it sets?
Old June 15th 07, 10:14 PM posted to rec.aviation.piloting
Paul Tomblin
It's only one cookie. It remembers what options you choose so that next
time you visit those options are chosen again. This is useful to you if
you want to come back after the next FAA data update, for example.
Beware of bugs in the above code; I have only proved it correct, not tried it.
- Donald Knuth
Old June 15th 07, 10:48 PM posted to rec.aviation.piloting
john smith[_2_]
Thanks.
Old June 16th 07, 12:06 AM posted to rec.aviation.piloting
CDT
Yes indeed! Thanks Paul! I have my GPS V loaded with all
public airports in Texas (about 475 of them). Waypoint names
are airport designators. Works great thanks to you!
-Pilot Charlie
(In Austin)
"Paul Tomblin" wrote in message
VORs
imported
for themselves.
Old June 16th 07, 01:16 AM posted to rec.aviation.piloting
Hilton
Paul,
Your GPX file has:
typeAIRPORT/type
extensions
navaid:nameVANCOUVER INTL/navaid:name
navaid:runway designation="08L/26R" length="9940" width="200"
surface="CONC"
Shouldn't it be airport:name or wpt:name?
I might be able to get these GPX files and the extensions supported in
WingX.
Thanks for a great resource.
Hilton
it.
- Donald Knuth
Old June 16th 07, 02:02 AM posted to rec.aviation.piloting
Andrew Sarangan
In addition to Paul's site, I have a site that you can use to select
navaids and airports based on a variety of geographic choices.
http://www.sarangan.org/aviation/garmin/index.html
Old June 16th 07, 02:45 AM posted to rec.aviation.piloting
Paul Tomblin
In a previous article, "Hilton" said:
Your GPX file has:
typeAIRPORT/type
extensions
surface="CONC"
No, "navaid:" is the namespace, which tells XML that "navaid:name" and
"navaid:runway" are defined in the http://navaid.com/GPX/NAVAID/0/8 schema
definition.
WingX.
That would be cool.
"Go go Gadget kernel compile!" - Chris "Saundo" Saunderson
Share your coordinates? Was: D'oh! A new first... Jim Logajan Piloting 0 May 10th 06 06:41 PM
Modern Sailplane Airfoil Coordinates superficial intelligence Soaring 5 March 13th 04 11:39 PM
Curve fitting to airfoil coordinates Larry Goddard Soaring 13 January 21st 04 04:21 PM
coordinates system F. Dobruszkes General Aviation 1 November 12th 03 06:52 PM
Airspace coordinates for moving map Alan Dempster Soaring 0 September 8th 03 06:55 AM
