Myth: 1 G barrel rolls are impossible.
Old June 16th 07, 04:10 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Myth: 1 G barrel rolls are impossible.
El Maximo writes:
I'm sure there are enough definitions of orbit for you to choose from that
you wouldn't bother learning, only arguing.
In other words, I am not in error.
  #192
Old June 16th 07, 04:17 PM posted to rec.aviation.piloting,rec.aviation.student
Well, MX, consider the case of a ballistic track that starts off with
an initial vertical velocity that is less than escape velocity.
Up, then down, until it hits what someone so nicely described as 'the
hard edge of the sky". Is your assertion that is orbital?
  #193
Old June 16th 07, 04:30 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
Suppose that, as the rock was passing through the soft part of the sky
(we neglect air friction because this is powered freefall flight), the
earth shrunk to the size of a walnut. The flight path would stay the
same, and orbit the walnut.
Escape velocity is the velocity required to escape the earth's
gravitational field (go up and not come down at all). What we call
"orbital velocity" is the velocity required to remain in a circular
orbit around the earth, at an altitude of about four thousand miles
above the earth's center. At the apogee of a sufficiently elliptical
orbit, the actual velocity can be arbitrarily small.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
  #195
Old June 16th 07, 04:48 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jose writes:
Exactly. At least someone here is capable of abstract thinking.
  #196
Old June 16th 07, 05:12 PM posted to rec.aviation.piloting,rec.aviation.student
I used the escape velocity limitation to disallow the obvious
argument.
The intitial velocity limitation says 'vertical'. I don't care what
size the 'walnut' is, it will be impacted given there was no
horizontal velocity component.
Even if there was, by the way, the Newtonian physics demand the path
will cross the starting point, and the implication to most readers
would be that was on a surface.
Jose, I don't think from an initial impluse, which is the model I
described, you can avoid impact unless the mass of the projectile is
such that conservation of momentum would demand the launching surface
move enough out of the way of the way to avoid the impact.
You really can't go orbital with a initial impulse launch from a
realizable surface unless the object gets redirected as it gains
altitude. I did not allow that redirection in my model.
As for abstract thinking mentioned in another post? I might use a word
other than abstract.
  #197
Old June 16th 07, 05:33 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Rip writes:
Anthony, that statement makes a road-kill 'possum smarter than you.
Try again, and get back to us when you've figured out your error.
Get back to me when you're ready to explain the alleged error.
I'll tel you what the error is for $400.
Bertie
I'll tell you what it is for
  #198
Old June 16th 07, 05:33 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
I haven't really been following the thread, so I don't know what the
initial thing is (except, by the thread title, that it's a
miscommunication about whether the 1g force one feels standing still is
to be "counted" or not, and whether a degenerate case of the barrel roll
"counts".
I don't care what size the 'walnut' is,
True. But if there is =no= horizontal component, you don't have a very
interesting maneuver.
btw, is a satellite "in orbit" if it blows up before it completes a
complete revolution (even though it would have completed it just like
any other orbiting satellite?)
True (fsvo starting point)
Depends on the situation. Rockets start from the surface, but don't
"enter orbit" until they are far from that surface (yes, this involves
acceleration).
If by "impulse" you mean "instantaneous change in velocity" then you
would need the launching surface (if there be one) to move out of the
way. But you don't need a launching surface. You can jump into the air
(vertically) and then apply a (huge) impulse horizontally while you are
still airborne, and you will be in orbit. (IF we are talking about
instantaneous impluses, why not extend the fantasy)
If by impluse you merely mean "very fast change in veolocity", then
there will be some value of "very" for which you can avoid impact.
Jose
  #199
Old June 16th 07, 05:34 PM posted to rec.aviation.piloting
Mxsmanic wrote in
El Maximo writes:
that you wouldn't bother learning, only arguing.
Yes, you are. You are always in error.
Bertie
  #200
Old June 16th 07, 05:35 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Jose writes:
sky
Nope. Worng again fjukkktard.
And if you find everyone so tedious, why stay?
I know why, don't I fjukktard?
Bertie
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
