Myth: 1 G barrel rolls are impossible.
Old June 16th 07, 05:44 PM posted to rec.aviation.piloting
Mxsmanic
Default Myth: 1 G barrel rolls are impossible.
Bertie the Bunyip writes:
And if you find everyone so tedious, why stay?
I don't find everyone here tedious. There are lots of stupid people in the
world, but that doesn't mean I should write off the entire species. I have a
lot of patience.
  #204
Old June 16th 07, 06:02 PM posted to rec.aviation.piloting,rec.aviation.student
On Jun 16, 12:46 pm, Mxsmanic wrote:
writes:
The intitial velocity limitation says 'vertical'. I don't care what
size the 'walnut' is, it will be impacted given there was no
horizontal velocity component.
There is always a horizontal component, although one isn't really necessary.
Even if there was, by the way, the Newtonian physics demand the path
will cross the starting point, and the implication to most readers
would be that was on a surface.
If there's a surface in the way, the starting point and ending point will be
different.
Care to write an equation or two to demonstrate that? It's a two body
problem, one massive with respect to the other. The initial conditions
are a vertical impulse from the surface, of a massive sphere. That's
high school physics.
  #205
Old June 16th 07, 08:05 PM posted to rec.aviation.piloting,rec.aviation.student
In rec.aviation.piloting Mxsmanic wrote:
El Maximo writes:
It's called orbital velocity
http://electronics.howstuffworks.com/satellite3.htm
Any object following a ballistic trajectory (disregarding aerodynamic effects)
is in orbit.
Stardate 1369.000001
The starship Redundant has just come out of warp and is approaching
Fjukktard IV.
On the bridge...
Captain: Helmsman, assume a standard orbit around the planet.
Helmsman: Aye, Aye, sir.
(Sounds of engines adjusting)
Captain: Tactical! We're heading straight for the planet!
Have the inhabitants locked on to us with some sort of tractor beam?
Tactical: Negative sir, Helmsman Mxsamanic has put us on a collision
course with the planet.
Captain: Mr Mxsmanic, what the hell is going on?
Helmsman: Well, sir, you said assume an orbit and any object
following a ballistic trajectory (disregarding aerodynamic effects) is
in orbit, so I...
(Anything further from Mr Mxsmanic is unintelligible as the Captain
has both hands firmly around his neck)
Captain: Navigator, take the helm and put us in a real orbit! Security,
throw Mr Mxsmanic out off the nearest airlock!
Jim Pennino
Remove .spam.sux to reply.
  #206
Old June 16th 07, 08:12 PM posted to rec.aviation.piloting,rec.aviation.student
Why would you want to throw Mx from an airlock? If you did it after
adjusting the orbit, he'd contribute to space junk after getting his
black belt in Internet Pest.
The airlock idea for storage is a good idea though. Don't do a bleed
to space, that would mess up the insides of the airlock as badly as
the insides of some microwave ovens.
El Maximo writes:
is in orbit.
Fjukktard IV.
On the bridge...
in orbit, so I...
Jim Pennino
  #207
Old June 16th 07, 08:16 PM posted to rec.aviation.piloting,rec.aviation.student
El Maximo
"Mxsmanic" wrote in message
El Maximo writes:
I'm sure there are enough definitions of orbit for you to choose from
that
you wouldn't bother learning, only arguing.
In other words, I am not in error.
No, in other words, you do not understand.
  #209
Old June 16th 07, 09:17 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
writes:
Helmsman: Well, sir, you said assume an orbit ...
No, the captain said assume a _standard_ orbit, which presumably would not
intersect the planet's surface.
  #210
Old June 16th 07, 09:54 PM posted to rec.aviation.piloting,rec.aviation.student
Read the post -- it specified vertical. It may be your concept of
vertical is different than the one commonly accepted. If your throw
was vertical you had aerodynamic effects, disallowed earlier in your
earlier post.
I would have suspected you did finish high school some time ago. That
you have forgotten what you learned is obvious.
On Jun 16, 4:16 pm, Mxsmanic wrote:
writes:
You need an equation?
I throw a baseball into the air. It lands twenty feet away. The starting
point and ending point are different.
It's a two body
I finished high school a long time ago.
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
