Myth: 1 G barrel rolls are impossible.
Old June 19th 07, 02:33 PM posted to rec.aviation.piloting,rec.aviation.student
Jon
Default Myth: 1 G barrel rolls are impossible.
On Jun 19, 7:57 am, wrote:
Mx
"Does not play well with others" comes to mind as
something that would appear in his record.
He writes well enough, though.
"If you can talk brilliantly enough about a problem, it can
create the consoling illusion that it has been mastered..." Stanley
Kubrick
  #242
Old June 19th 07, 02:39 PM posted to rec.aviation.piloting,rec.aviation.student
Jon
On Jun 18, 8:51 pm, Bertie the Bunyip
On Jun 18, 9:12 pm, it revealed more about itself with:
I'm not sure if that's sufficient to join the treehouse club. You'll have to
ask the little boys who run it.
There's so much for her to work with, in the above two sentences
She can fly. she's approved.
You can't even find tthe lader to theh treehouse, you're not.
Fjukkwit.
Bertie
  #243
Old June 19th 07, 04:30 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
El Maximo writes:
Quite frequently, actually.
No, show me a diagram. Draw the orbit to scale. You'll see.
You'd need a big sheet of paper for that, mmoron
Bertie
  #244
Old June 22nd 07, 03:58 AM posted to rec.aviation.piloting
vincent norris
An aileron roll is actualy not dissimilar to a Barrel roll in flight
path.
You obviously didn't learn to do barrel rolls in the U.S.Navy.
vince norris
  #245
Old June 22nd 07, 04:33 AM posted to rec.aviation.piloting
Dudley Henriques
path.
vince norris
A lot of people mistakenly classify an aileron roll as a narrow offset
barrel roll thinking the natural arc the nose describes as it raises
before roll initiation and then lowers due to drag during the back side
of the roll resembles a barrel roll.
Seen from the ground, especially to a novice, an aileron roll,
especially an aileron roll performed in a low performance airplane with
a slow roll rate can indeed APPEAR to be a narrow offset barrel roll.
For the aileron roll, the nose is raised and set, then aileron applied
with just a touch of inside rudder to nullify the adverse yaw then
released. As the aircraft rolls with aileron, drag begins to pull the
nose down. The result of this, especially if no forward stick is
introduced to "trim out" the roll through inverted, is for the nose to
dish out the bottom of the roll which viewed from the ground can easily
be mistaken for a deliberate maneuver resembling a barrel roll.
Although it's true the nose does raise and lower during a normal
aileron roll,an aileron roll is still basically performed on the
longitudinal axis of the airplane using aileron or spoiler (can even
be aided by differential tails in some fighters) as the prime roll
control and doesn't meet the 3 dimensional rule through space that
defines the helical arc of a barrel roll.
Even this should not be mistaken for the 90 degree offset at inverted
barrel roll as taught by the Navy. The Navy version, and indeed
anyoneperforming a helical 90 degree heading offset through inverted is
doing the classical version of a barrel roll; the version most often
taught as a precision training maneuver.
So you are as I'm sure you already know, perfectly correct.
This explanation I hope might help others to understand this a bit better.
Dudley Henriques
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
