Another 302 question...
Old June 21st 07, 12:22 AM posted to rec.aviation.soaring
Bernie[_4_]
Default Another 302 question...
Dave,
we had the exact same problem on two of our club aircraft just a few
weeks ago, and Garry at CAI gave the same answer.
We found that the default pilot profile ('Club Pilot') had been
altered to 'Netto' by someone who's not owning up to it, and it was an
easy matter to change the profile back to 'Super Netto' and all was
well. You can of course change this via the CAI Utility program which
has the same effect I guess.
Regards, Bernie.
Old June 21st 07, 03:49 AM posted to rec.aviation.soaring
No, the instrument panel stays down.
Turns out it is in netto mode. So the needle position is right where
it's supposed to be.
Thanks everyone.
On Jun 20, 9:44 pm, Tony Verhulst wrote:
...... The
strange thing that happens is when the bootup is done and it goes to
screen 2, the needle goes up to around +1 on the dial and pretty much
stays there.
Does the instrument panel come up with the canopy and was the canopy
raised while you made this observation? If so, lower that canopy and
look again.
Tony V.http://home.comcast.net/~verhulst/SOARING
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
