Woodstock spars
Old June 22nd 07, 03:12 AM posted to rec.aviation.soaring
MartyH
Default Woodstock spars
On Jun 21, 12:34 pm, Frank Whiteley wrote:
On Jun 21, 10:25 am, Bob Kuykendall wrote:
On Jun 21, 4:41 am, MartyH wrote:
Does anyone know where I might find enough Douglas Fir suitable for
use for spars for the Woodstock 12 meter wing? I need pieces in the
12ft range. Does anyone know where I can have these spars made if I
dont want to do them myself? This project doesnt go very far without
spars!
A few things to try:
See if the plans include a notation about substituting spruce for doug
fir. The spruce is a bit lighter and a bit weaker by volume, but I've
seen several plans sets that show spar cap sizes for both spruce and
doug fir so you can choose based on what's available in your area. The
spruce is pricey, but you can get it from Aircraft Spruce and
Specialty and Wicks. For a first-time builder, that's a good option
for peace of mind.
Have a look at R.S. Hoover's blog for good tips about getting usable
aircraft-grade wood from (I'm not kidding) big box stores like Home
Despot and Lowes. Note that he's mostly interested in shorter chunks
for cheap puddle-jumping Chugger airplanes, but the same general
principles apply. It could be that you can do that sort of thing with
a few scarf splices:
http://bobhooversblog.blogspot.com/
Try your question on the rec.aviation.homebuilt usenet newsgroup.
There's at least a few folks there plugged into the wood supply
situation. Welcome to the awkward overlap between r.a.h and r.a.s
common to all sailplane homebuilders on the Internet.
Join the HomeSail forum on YahooGroups and ask your question the
http://groups.yahoo.com/group/HomeSail
See where builders of Dan Rihn's One Design and DR109 aerobatic
airplanes get their doug fir.
As for having the spars made by someone else, I would try to dissuade
you from that. It's not rocket science, and if you build the tail
surfaces first you will have all the skills and tools you need by the
time you get to the spars. If someone else builds them, you're just
paying someone else to have your fun for you.
Further, my recommendation are to stick with the 12m wings, build fast
and light, and don't worry too much about the aesthetics of the stuff
on the inside.
Good luck!
Thanks, and best regards
Bob K.http://www.hpaircraft.com/hp-24
A few years ago, someone was looking at using the pultruded carbon
rods for the spar caps on the Woodstock. I wonder if that went
anywhere. It would seem an interesting adaption, especially with
spruce.
Frank Whiteley- Hide quoted text -
- Show quoted text -
Thanks Frank but I have no desire to deviate from the plans. The spars
will be Douglas Fir. They may be laminated but they will be Doug Fir
and then load tested.
Old June 22nd 07, 03:13 AM posted to rec.aviation.soaring
MartyH
spars!
yes, contact Bill Scheunemann at
that's Bill at woodwings.com
He has the best Douglas Fir I've ever seen and has plenty of it.
He can also mill the boards per your plans at a very resonable price.
Good luck,
Dan Rihn
Rihn Aircraft Corp.
Thank you Dan! I knew someone was still finding good stuff.
Woodstock Plans [email protected] Soaring 4 August 10th 06 11:11 PM
Query on the Woodstock Stealth Pilot Soaring 3 July 25th 06 08:02 PM
Woodstock Plans F/S [email protected] Soaring 0 May 16th 05 10:06 PM
Titanium spars and composites on F-22 Scott Ferrin Military Aviation 1 December 4th 03 03:21 PM
S-H Spars: Anyone check for voids laterally? Mark Grubb Soaring 1 September 20th 03 04:27 AM
