Is there anyone out there using fuel tanks filled with open cell foam? I've
heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com |
"Stuart & Kathryn Fields" wrote: Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Most of the foam is polyurethane foam, which decomposes after exposure to water vapor. It is not an instantaneous process, occurring over several years, but the decomposition product is a black powder, which can clog fuel filters, injectors, etc. It is good for race cars, which have a limited useful life, but may impose problems in aircraft, which operate for years. |
Stuart & Kathryn Fields wrote:
Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Fuel cells (bladders with foam) are pretty common in the auto racing industry. They real purpose of it is to avoid the fuel from spraying out if the tank is ruptured. Other than that I'm not sure what "explosion" resistance you're going to get. I suppose it might mitigate some sloshing. I'd make sure that I was getting the max flow rate for takeoff if I were to use one in an aircraft. The big drawback is that they drastically decrease the fuel carried per unit volume. |
"Stuart & Kathryn Fields" wrote in ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com Aero Tec Laboratories Inc http://www.atlinc.com/US/racing.html http://www.atlinc.com/US/catalogs.html Some ATL Fuel Cells catalogs. http://www.atlinc.com/US/faqs_racing.html Here's some answers concerning the foam replacement etc. JP |
"Ron Natalie" wrote I'd make sure that I was getting the max flow rate for takeoff if I were to use one in an aircraft. That should not be a problem, considering the run NASCAR engines with it, putting out 750+ HP, at constant wide open throttle, for lap after lap, at some tracks. Our biggest engines putting out around 300 HP would not drawn nearly as much. It seems to me that if you were willing to overlook the weight, the extra volume to carry the same amount of fuel, and the extra $$$, the fact that they can wear out and plug up your fuel system is a show stopper. -- Jim in NC |
Richard: I agree the deterioration of the foam is a show stopper for me.
thanks -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com "Richard Riley" wrote in message ... On Mon, 25 Jun 2007 07:35:36 -0400, Ron Natalie wrote: Stuart & Kathryn Fields wrote: Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Fuel cells (bladders with foam) are pretty common in the auto racing industry. They real purpose of it is to avoid the fuel from spraying out if the tank is ruptured. Other than that I'm not sure what "explosion" resistance you're going to get. I suppose it might mitigate some sloshing. I'd make sure that I was getting the max flow rate for takeoff if I were to use one in an aircraft. The big drawback is that they drastically decrease the fuel carried per unit volume. I looked at the foam a few years ago. Google Reticulated Polyurethane Foam Fuel Explosion and you'll find a few technical papers. You take about a 3% hit on fuel volume, and you increase empty weight by about the same. It does break down over time - the racing bladders are only rated for 5 years. The breakdown occurs MUCH more rapidly in the presence of an oxygenating fuel like ethanol. I decided against it, I can't open up my tanks every few years to replace it. |
"Stuart & Kathryn Fields" wrote in message ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Perhaps a few metal baffels would be a better choice. |
I have a couple of baffles already, but having 28 gal 100LL just behind my
head makes my nerves twitch just a bit. Having the foam is supposed to make explosive conflagration less likely in case of a prang. Thanks -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com "Maxwell" wrote in message ... "Stuart & Kathryn Fields" wrote in message ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Perhaps a few metal baffels would be a better choice. |
I wonder how the safety of the foam would compare to a bladder? It would
certainly complicate the slosh issue, but might provide greater safety in case of an incident. I have a couple of baffles already, but having 28 gal 100LL just behind my head makes my nerves twitch just a bit. Having the foam is supposed to make explosive conflagration less likely in case of a prang. |
| Thread Tools | |
| Display Modes | |
| Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 02:33 AM |
| Fuel tank balance | Mxsmanic | Piloting | 101 | October 3rd 06 08:56 AM |
| fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 05:54 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| blue foam, pink foam, yellow foam? | Corrie | Home Built | 26 | September 1st 03 06:01 PM |
