The Horizontal Stab. is held in position by a captive bolt that is
prevented from backing out by a spring steel wire that slides through a slot in that bolt. Mine just broke. Does anyone have experiance with that little wire and it's replacement? |
On Jun 25, 9:14 am, wrote:
The Horizontal Stab. is held in position by a captive bolt that is prevented from backing out by a spring steel wire that slides through a slot in that bolt. Mine just broke. Does anyone have experiance with that little wire and it's replacement? I drilled a 1/32" hole in a new location and then shoved a short length of bent music wire in the new hole so that it contacted one of the bolt head slots. Kept it in place with tape over the wire and bolt head. Its just a safety..... a properly tightened bolt isn't going to come loose in one flight. Worked for me, JJ |
length of bent music wire in the new hole... Weren't you supposed to scarf that in at 400:1? ![]() |
| For Sale: 1-34 horizontal stab/elevator | Mitch Deutsch | Soaring | 0 | November 12th 06 04:46 PM |
| DG300 Tail weight | John Schaffer | Soaring | 3 | September 12th 06 10:36 AM |
| Horizontal Stab. rusted on stubs | Michael Horowitz | Restoration | 5 | April 8th 06 04:50 PM |
| Saftey Pilot | Richard Ross | Instrument Flight Rules | 7 | March 23rd 06 12:35 AM |
| Saftey of exposed wheel at 41,000 feet | stephen | Owning | 32 | December 12th 03 02:35 AM |
