One, big sh*t-eating grin...!
Old June 25th 07, 08:00 AM posted to rec.aviation.piloting
Thomas Borchert
Default One, big sh*t-eating grin...!
John,
The second answer is, the instructor was referring to controlling the
aircraft in flight. In a taildragger, you lead a turn with rudder before
adding the aileron.
You still don't get Bob's point, I'm afraid. The point is: How would the
air and the plane "know" that it's a taildragger, once the plane is flying?
And thusly, how would the plane "know" to behave differently in the air
because it has a different wheel (!) configuration?
Thomas Borchert (EDDH)
  #32
Old June 25th 07, 04:48 PM posted to rec.aviation.piloting
RST Engineering
The first answer is, in a taildragger your don't use the brakes to turn.
If you do use the brakes, you are going too fast.
If your instructor didn't teach you how to do a one-wingspan turn in a
taildragger, your education is not complete. One of the great things about
a taildragger is the ability to turn in tight spaces. I'd go get some
tailwheel time from a real taildragger instructor.
adding the aileron.
I'll not argue with you for the same reason I don't mudwrestle with pigs.
However, just for our amusement why don't you give us the aerodynamics of
the differences in inflight turns between taildraggers and trainingwheel
aircraft.
  #33
Old June 25th 07, 07:01 PM posted to rec.aviation.piloting
john smith[_2_]
It's the way the airplanes were designed then and now.
Alot of it has to do with adverse yaw and how the ailerons were hinged
then compared to how they are hinged now.
Find an old Champ and see how much of the forward portion of the aileron
extends above/below the wing surface when the aileron is deflected down
on the upgoing wing/down on the down going wing.
  #34
Old June 25th 07, 08:35 PM posted to rec.aviation.piloting
RST Engineering
I don't think so. Find a C-170 and set it next to a C-172 and compare the
two. Besides, adverse yaw is not WHEN you apply rudder to compensate for it
but HOW MUCH. Again, get yourself some decent taildragger instruction.
"john smith" wrote in message
flying?
  #35
Old June 25th 07, 09:47 PM posted to rec.aviation.piloting
Newps
adding the aileron.
Really, so this applies with a 180 versus a 182?
  #36
Old June 26th 07, 12:46 AM posted to rec.aviation.piloting
john smith
adding the aileron.
I don't know. I learned in a taildragger, I always lead with rudder
regardless of what I am flying.
  #37
Old June 26th 07, 01:17 AM posted to rec.aviation.piloting
Morgans[_2_]
"RST Engineering" wrote in message
it but HOW MUCH. Again, get yourself some decent taildragger instruction.
Are there any certified planes (or even experimental) that need zero rudder
input to do a coordinated turn?
Jim in NC
  #38
Old June 26th 07, 01:35 AM posted to rec.aviation.piloting
RST Engineering
Rudder pedalless Ercouples come quickly to mind.
"Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and wine in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
"Morgans" wrote in message
rudder input to do a coordinated turn?
Jim in NC
  #39
Old June 26th 07, 01:37 AM posted to rec.aviation.piloting
RST Engineering
Your passengers must enjoy the barf-inducing yaw that this provides to them.
I learned in a taildragger too, and I've rarely come across such puppycock.
--Unknown
  #40
Old June 26th 07, 02:03 AM posted to rec.aviation.piloting
john smith[_2_]
Okay, how about this answer...
I apply whatever control inputs are required to keep the ball centered
throughout the turn. I don't think about it, I just do it. :-)
Eating in New Jersey G.R. Patterson III Piloting 15 September 30th 04 01:58 PM
Getting rid of turbines. (grin) ArtKramr Military Aviation 15 December 6th 03 05:25 AM
