Compressed air as fuel?
Old June 26th 07, 10:28 PM posted to rec.aviation.homebuilt
Dancing Fingers
Default Compressed air as fuel?
Hi Guys,
I remember years ago Kitplanes did a series on the potential for
batterry-powered aircraft. Recently, I watCHED Future Cars on the
Discovery channel and this guy had developed a car that ran on
compressed air. This seems like a more viable fuel for aircraft then
batteries. Has anybody looked into it?
just curious.
Chris
Old June 26th 07, 11:01 PM posted to rec.aviation.homebuilt
Bill Daniels
I remember flying model airplanes powered by a tiny single cylinder CO2
engine. The engine had "warming" fins on the cylinder to help the CO2
expand. The "fuel supply" was a CO2 cartridge. Compared to glo-plug
2-strokes, it was heavy and expensive to run.
Compressed air makes a lot of sense for a 'city car' or taxi. Unlike
battery/electrics, a recharge takes only minutes and the exhaust is just
air. Compressed air vehicles have a long history in underground mining
where the lack of polutants is a plus. .
Would it work for a man carrying airplane? Maybe, if you didn't want much
range or payload - or to fly in cold weather. You want hot weather to make
the gas expand. The trick would be ultra high pressure tanks made of carbon
fiber and a very efficient air engine.
Bill Daniels
"Dancing Fingers" wrote in message
Hi Guys,
just curious.
Chris
Old June 27th 07, 02:15 AM posted to rec.aviation.homebuilt
Vaughn Simon
Hi Guys,
Air power has been looked into for commuter vehicles. There is a company
that has been promising to make something called the "Aircar" for several years
now. They always claim to be constructing a factory, have plenty of orders in
hand, and full production is always going to start "next year". Sound like
anyone we know?
The fact is that compressed air is a very thermally inefficient way to
store energy. The reasons are buried in basic, fundamental physics. The
problem is that when you compress air, it gets hot. That heat must be thrown
away. But that is not the only problem! When you go to expand the air to
produce energy, it gets cold! This reduction in temperature greatly limits
expansion and reduces an engine's output.
Making an efficient air engine is not a trivial exercise. To be efficient,
you must find some way of allowing the air to expand to many times its
compressed volume. This may be done several ways, but all of them increase the
complexity and/or the size of the engine.
Vaughn
Old June 27th 07, 03:16 AM posted to rec.aviation.homebuilt
Harry K
On Jun 26, 6:15 pm, "Vaughn Simon"
Hi Guys,
anyone we know?
Vaughn
The heat/cool bit is the big drawback. That heat being thrown away on
both ends is not free. The air vehicles seen in service are always in
special use applications, all are short haul type and all rely on a
HUGE store of precompressed air to retank from. In general, the cost
of the air, due to the heat loss alone, makes it a very expensive way
to fuel an engine.
Harry K
Old June 27th 07, 03:23 AM posted to rec.aviation.homebuilt
Orval Fairbairn
In article .com,
Dancing Fingers wrote:
Hi Guys,
just curious.
Chris
You ned either:
1. a very long hose attached to a compressor or
2. a filament-wound balonium/unobtanium air tank filled with air
compressed to 100,000,000 psi.
Otherwise, you just can't carry enough compressed air around to make a
practical vehicle.
The "Future Car" ranks right there along with Moller's "Skycar," in that
it is all vaporware.
Old July 12th 07, 05:23 PM posted to rec.aviation.homebuilt
Dancing Fingers
On Jun 26, 10:23 pm, Orval Fairbairn
In article .com,
Hi Guys,
just curious.
Chris
You ned either:
practical vehicle.
I certainly don't think that compressed air would power a airliner but
it might be viable for small commutter flights. It seems like the
heat issue would only be an issue on the ground, during refueling,
although cabin heat would be a challenge. I was really wondering if
anyone had ever calculated the energy per cubic foot compressed air
can hold, relative to gasoline, diesel and hydrogen. There's a new
engine being developed, the Quasiturbine, that would be perfect for
this application.
For what it's worth.
Chris
Old July 12th 07, 06:02 PM posted to rec.aviation.homebuilt
cavelamb himself
this application.
Chris
The straight answer?
Not on this, or any other planet in this solar system...
Richard
Old July 12th 07, 11:21 PM posted to rec.aviation.homebuilt
Vaughn Simon
In article .com,
Hi Guys,
just curious.
Chris
You ned either:
practical vehicle.
Kindly compare energy densities for yourself.
Jet fuel 11,694 Wh/kg
Gasoline 12,200 Wh/kg
Compressed air 34 Wh/kg
For a given weight of fuel, your air-powered "commutter" aircraft would have to
somehow get by with less than 1% of the range that it would have with
conventional fuel.
Source: http://xtronics.com/reference/energy_density.htm
Of course, that is gravimetric density and you asked about volumetric density.
Volumetric density would probably be an even worse comparison, but would depend
greatly on the air storage pressure you wish to assume. Naturally, you must
design your "fuel tank" heavier and heavier as storage pressure increases.
Exotic materials would help, but not enough. Also, high pressure air tanks must
be round, but the space available to contain the tank will not be round, so much
potential storage capacity would be lost.
There's a new engine being developed, the Quasiturbine, that would be perfect
for
this application.
The type of engine would not matter. You just can't carry enough stored energy
to be practical.
It is worth nothing
Vaughn
Old July 12th 07, 11:33 PM posted to rec.aviation.homebuilt
On Jun 26, 7:15 pm, "Vaughn Simon"
Hi Guys,
anyone we know?
Vaughn
Yes, but just think of all the ice cream you could make as you ran
your engine!!
Old July 13th 07, 03:45 AM posted to rec.aviation.homebuilt
Harry K
In article .com,
Hi Guys,
just curious.
Chris
You ned either:
practical vehicle.
this application.
Chris- Hide quoted text -
- Show quoted text -
You can put the "quasiturbine" right in the same category as the 'air
car" and "Moller's flying car" all of them are vapor ware. To
address the 'quasitubine' specifically, It has been "under
developement for at least 10 years and I think longer with no
progress. It is an extremely complicated design for a rotary engine
with little or no improvement over the original Mazda (IIRC) rotary
engine.
The heat problem is not in getting rid of it. The problem is that
that heat was produced while compressing the air and is then thrown
away. Right there should be a clue as one of the major reasons why
and "air engine" is not an economicaly viable design. That heat costs
money and represents energy that cannot be recovered.
Harry K
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? Gil G. Rotorcraft 9 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? nuke Rotorcraft 0 July 28th 03 12:52 AM
