New trainer from SZD Bielsko
Old June 27th 07, 05:09 PM posted to rec.aviation.soaring
Sandro Rodriguez
Default New trainer from SZD Bielsko
Mike Lindsay schrieb:
That's why the BGA has every ab initio in the UK religiously
checking the flaps on a K13 every time they launch.
I don't think I've ever seen a K13 with flaps.
That was exactly his point.
  #102
Old June 27th 07, 06:49 PM posted to rec.aviation.soaring
Chris Reed[_1_]
Ian,
Looks like we both recall correctly but incompletely. The AAIB report of
the 1996 accident, at
http://www.aaib.dft.gov.uk/cms_resou...pdf_502118.pdf states:
"Several witnesses formed the opinion that this launch was faster and
less steep than normal, the launches already being considered, by
several witnesses, as being fast that day. One witness reported the
presence of a strong wind gradient, the surface wind being 5/10 kt. At a
height variously estimated by witnesses of between 600 and 700 feet the
glider was seen to 'speed- up' and its climb angle reduce. At about this
time, and whilst still in a nose high attitude and connected to the
cable, several relatively rapid oscillations in pitch occurred. One
witness estimated these to be as much as 15°, with the wings being seen
to 'flex' correspondingly an abnormal amount. At about this point,
the airbrakes were seen to briefly deploy. Almost immediately, they
deployed again, this time coincident with the right wing failing in an
upwards and rearwards direction, pivoting about its root end and
releasing a cloud of debris."
A doubled weak link was used, which could have allowed excessive loads
on the airframe in previous launches and in this one. Part of the
conclusion was:
"In view of the fact that the corrosion had developed over a long period
of time, during which the glider had been launched and flown without
incident, and that the aircraft had been launched by winch earlier on
the same day in similar conditions by the same pilot, it is considered
probable that excessive loads were induced on this occasion. This, in
turn, exploited the degraded strength of the wing spar, resulting in the
upper spar boom collapse in the right wing."
I read this as saying that continued overstressing on a weakened
structure led to the failure, with that days's overstress being the
final straw. The report says that other gliders flying from the same
airfield had probably been overloaded. Only this one failed
structurally, because of the corrosion.
As I wrote before, flying outside the envelope takes one into uncharted
territory. However, overspeeding on its own does not necessarily do so -
it depends on how the pilot flies the launch and when the launch is
abandoned.
To summarise how I understand the UK training:
1. If overspeed is clearly excessive from the outset, release and land
ahead if possible. If not possible to land ahead, see (3).
2. If moderately excessive in the lower 1/3 of the launch, give a chance
for it to settle down and if not, signal too fast.
3. If it doesn't settle down, reduce the load on the airframe through a
shallow rate of climb and release once a safe height is achieved.
4. Overspeed in the top 1/3 of the launch is potentially dangerous as
the glider is under its highest load at that point, and cumulative
overstress can lead to failure particularly if the structure is already
weakened.
5. Too slow is more dangerous than too fast, provided you fly the fast
launch so as not to overstress the airframe.
I'd add that all suspicions of corrosion, overstress through excessive
g, etc. need to be checked out by a qualified person.
  #103
Old June 28th 07, 08:37 AM posted to rec.aviation.soaring
Sally W
At 15:54 27 June 2007, Bruce wrote:
Mike Lindsay wrote:
In article , Ian
wri
My God! (that's the religious bit)
True, but they check them just in case...
And they are checked in a K21...
  #104
Old June 28th 07, 09:23 PM posted to rec.aviation.soaring
Dan G
On Jun 27, 6:49 pm, Chris Reed wrote:
Ian,
the 1996 accident, athttp://www.aaib.dft.gov.uk/cms_resources/dft_avsafety_pdf_502118.pd fstates...
Sorry folks, I've just repeated some of what Chris posted, didn't
notice that the conversation had "gone over the page".
However, Chris does seem to be intimating that it's possible to
structurally damage a glider during a winch launch from overspeeding.
Providing the correct weak is used, that is not possible. Old myths
die hard though.
Dan
  #105
Old June 29th 07, 09:49 AM posted to rec.aviation.soaring
Chris Reed[_1_]
die hard though.
Apologies - didn't mean to intimate that.
All I was trying to say is that overspeeding is not dangerous per se,
but might become so depending on the condition of your glider, where you
are in the launch and how you fly it. So far as structural damage is
concerned, the only example we have is from an already damaged glider,
so you may well be right that with the correct weak link you're
protected from structural damage.
However, I still refuse to accept overspeeding in the top 1/3 of the
launch because (a) the glider is not designed for it, even if it won't
fall apart, (b) I don't know whether my glider's structure has been
invisibly weakened by past overspeeding, groundloops, etc, and (c) I can
safely do something about it (bye bye cable).
Below that, I'm prepared to try to sort out the situation unless it's
clearly irredeemable.
Of course, much depends on what you mean by overspeeding. 2kt over max
winch is within the margin of error. 20kt over is far too much to live
with all the way to the top.
  #106
Old June 29th 07, 12:31 PM posted to rec.aviation.soaring
Colin Field[_2_]
2kt over max
too much to live
Debatable safety considerations aside, there's no benefit
in fast winch launches anyway- there's just increased
drag and therefore reduced final height, along with
the possible distraction and discomfort of excessive
acceleration at the beginning.
  #107
Old June 29th 07, 03:35 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Mike Lindsay wrote:
In article , Ian
wri
....and in an SZD Junior, Discus and Pegasus at my club, at least
by me - and in my Standard Libelle.
I see no reason to deviate from the standard CBSIFTCBE checklist,
so "Flaps: not fitted" accompanied by a glance to see that there
is indeed no flap handle is part of my checklist for a non-flapped
glider.
This has the benefit of keeping instructors happy on check rides
without straining my brain to remember what checklist is expected as
compared with what I might do or say when no instructor is present.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #108
Old June 29th 07, 07:55 PM posted to rec.aviation.soaring
Ian
die hard though.
Why, then, is the winch launch maximum speed not Vne?
Ian
  #109
Old June 29th 07, 08:20 PM posted to rec.aviation.soaring
brtlmj
die hard though.
If I understand it correctly, flying at maximum winch speed or below
ensures that you won't lose your wings even if you use a wrong weak
link or no weak link at all.
Bartek
  #110
Old June 29th 07, 11:26 PM posted to rec.aviation.soaring
Vaughn Simon
"Martin Gregorie" wrote in message
glider.
without straining my brain to remember what checklist is expected as compared
Perhaps it is just the way that my mind works, but I have to respectfully
disagree.
If you fly something with fixed gear for your first 1000 flights, each time
dutifully reciting something unnecessary like "UNDERCARRIAGE" and each time
DOING NOTHING but just skipping on to the next item, then when you finally get
in something with retractable gear, you are liable to do the same thing you have
always done and land gear up as a result. I believe that checklists should be
ideally posted in the cockpit and should be made specific to each aircraft so
that each step on the list has real meaning each and every time.
Vaughn
the Oz 3 surface trainer patrick mitchel Home Built 2 May 15th 07 03:19 AM
WTB Trainer Roy Bourgeois Soaring 0 June 25th 06 04:50 PM
***XC-Trainer Offer*** [email protected] Soaring 0 August 24th 05 05:21 PM
AMD Alarus IFR Trainer    H.P. Owning 0 August 5th 04 07:10 PM
AMD Alarus IFR Trainer    H.P. Piloting 0 August 5th 04 07:10 PM
