Braking in new breaks
Old June 29th 07, 01:13 AM posted to rec.aviation.owning
karl gruber[_1_]
Default Braking in new breaks
I just installed new break pads and am wondering if there is a procedure to
brake them in?
Best,
Karl
Old June 29th 07, 01:24 AM posted to rec.aviation.owning
Paul Tomblin
brake them in?
You've heard of a V1 cut? :-)
Paul Tomblin http://blog.xcski.com/
You can lead an idiot to knowledge but you cannot make him think. You can,
however, rectally insert the information, printed on stone tablets, using a
sharpened poker. -- Nicolai
Old June 29th 07, 01:54 AM posted to rec.aviation.owning
karl gruber[_1_]
"Paul Tomblin" wrote in message
to
brake them in?
They sure are fun in the sim!
KG
Old June 29th 07, 02:21 AM posted to rec.aviation.owning
Orval Fairbairn
brake them in?
Best,
Karl
Just petal the rudder peddles. You might find that somebody pedaled you
the wrong set! ;)
Old June 29th 07, 02:40 AM posted to rec.aviation.owning
David Lesher
"karl gruber" writes:
brake them in?
As opposed to installing new brake pads and breaking them in, I suppose...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old June 29th 07, 01:49 PM posted to rec.aviation.owning
Jim Burns[_2_]
Both Rapco and Kelly Aerospace have break-in procedures on their websites.
"karl gruber" wrote in message
to
brake them in?
Best,
Karl
Old June 30th 07, 12:48 AM posted to rec.aviation.owning
Ron Rosenfeld
On Thu, 28 Jun 2007 17:13:38 -0700, "karl gruber"
brake them in?
Best,
Karl
There are different methods of breaking in brake pads, depending on the
type of pad.
--ron
Old June 30th 07, 05:21 AM posted to rec.aviation.owning
Roger (K8RI)
brake them in?
I just put 'em on and use 'em. Never had any problems yet.
They're broke in by the time I get to the end of the taxiway.
Best,
Karl
Old July 2nd 07, 12:23 AM posted to rec.aviation.owning
Roger (K8RI)
On Fri, 29 Jun 2007 07:49:26 -0500, "Jim Burns"
If they are hydraulically operated disk brakes what reason could there
be for a break in? Even highly polished disks will roughen within a
day or two from moisture in the air and the pads should seat fully on
the disks with no special effort even if the disks are grooved.
to
brake them in?
Best,
Karl
Old July 2nd 07, 02:02 PM posted to rec.aviation.owning
Jim Burns[_2_]
The purpose is to wear off any high spots and create a light glaze on the
pads which will remain with normal use. Lack of proper glazing will wear
the pads pre-maturely.
http://www.parker.com/ag/wbd/cleveland/pdf/Wbtech.PDF has procedures for
both metallic and organic pads. Rapco's procedure is below.
Rapco, Inc:
Our normal break-in procedure for brake discs using the Rapco, Inc. RA164-
discs, is to get the friction material
hot (Approx. 850 Deg. F.) by performing the following:
a.. Use proper maintenance techniques by insuring that the friction
material is completely clean and dry of all
solvents and hydraulic fluid
b.. Perform a moderate-speed taxi (10-15Kts ground speed), insuring that
you have proper braking
(There will be very little brake action at first).
c.. Allow the brake to cool by taxiing across the airport or down field,
without using brakes. If you are not
going to fly the aircraft during the break-in procedure, then allow the
brakes to cool
for 45 min. until the next high-speed taxi stop.
d.. Once you've established positive brake action, you can proceed to a
full-stop landing using significant braking.
(Short field landing procedure). At this time the pilot should notice the
brakes starting to grab more.
If this is sufficient braking action, there is no need for another stop
cycle.
e.. Perform another short field landing, leaving the landing gear extended
throughout the landing pattern.
This allows the brakes to cool properly before the next heat cycle. After
this landing you should have
significant brake action
Paker:
"Roger (K8RI)" wrote in message
websites.
procedure
to
brake them in?
Best,
Karl
Preparing for a XC : Bathroom Breaks TF Piloting 98 February 7th 07 07:19 AM
C-152 Breaks Up In Air Mortimer Schnerd, RN Piloting 23 September 7th 06 10:00 AM
Britain breaks with the US over Iran John Dallman Naval Aviation 5 March 23rd 06 02:36 AM
Parajumper breaks legs??? jerry wass Home Built 32 April 29th 05 06:59 AM
An elementary landing / braking doubt Ramapriya Piloting 14 December 26th 04 10:45 PM
