Hidden costs of ethenol
Old June 29th 07, 01:46 AM posted to rec.aviation.homebuilt
Bill Daniels
Default Hidden costs of ethenol
"Blueskies" wrote in message
et...
"Bill Daniels" bildan@comcast-dot-net wrote in message
5 hour glider flight off a $5 winch launch? Where are you and how long
is the winch line?
A winch will launch a glider to about half the length of the winch line.
The winch launch gets you high enough to catch thermals. Then, in the
western US, you soar to 18,000. 5 hours can be conservative. Some
flights last over 10 hours.
In Germany, they are winch launching gliders almost a mile straight up so
they can practice aerobatics.
Beside being cheap, winch launches are a hoot. Think zero to sixty in
less than 3 seconds and then a 45 degree climb at 3000 - 5000 FPM.
If you want video, http://www.youtube.com/watch?v=wbRBiPuTjYQ (Somewhat
nervious passerger.)
Girlfriend gets a ride: http://www.youtube.com/watch?v=wttC39IZ9P4
and: http://www.youtube.com/watch?v=wttC39IZ9P4
I'm not German nor do I speak it - they just make the best videos.
Bill Daniels
I know Torry Pines will (or used to) launch you right over the cliffs so
you could ridge soar, but I am now in MI, and it would take a pretty long
winch to get high enough to fly around for 5 hours...
Torrey Pines still operates a few weekends in the Spring.
Michigan would be tough. However, I'm told there are thermals there -
sometimes good ones. Today, most winch operations soar with thermals and
not ridge lift although nobody would turn down ridge lift. Once you contact
thermal lift, you can usually count on several hours of flight.
From looking at several aero tow operations, most tows are to less then 2500
feet AGL. Winches can easilly match that at much lower cost.
Bill Daniels
  #32
Old June 29th 07, 04:19 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 29 Jun 2007 00:18:07 GMT, "Blueskies"
"Bill Daniels" bildan@comcast-dot-net wrote in message . ..
5 hour glider flight off a $5 winch launch? Where are you and how long is the winch line?
A winch will launch a glider to about half the length of the winch line. The winch launch gets you high enough to
catch thermals. Then, in the western US, you soar to 18,000. 5 hours can be conservative. Some flights last over 10
hours.
In Germany, they are winch launching gliders almost a mile straight up so they can practice aerobatics.
Beside being cheap, winch launches are a hoot. Think zero to sixty in less than 3 seconds and then a 45 degree climb
at 3000 - 5000 FPM.
If you want video, http://www.youtube.com/watch?v=wbRBiPuTjYQ (Somewhat nervious passerger.)
Bill Daniels
I know Torry Pines will (or used to) launch you right over the cliffs so you could ridge soar, but I am now in MI, and
it would take a pretty long winch to get high enough to fly around for 5 hours...
You just need the proper day.
Go take a look at the land around MPL. It's flat for miles. They used
a truck tow to launch two hand gliders that stayed alonft for
something like 10 hours and as I recall they landed some where over in
central Ontario. A week ago at 3BS we launched a sail plane (tow to
1000 feet, but 500 would have been suficient) he was up for about 45
minutes, but could have stayed up all afternoon.
  #33
Old June 29th 07, 05:15 AM posted to rec.aviation.homebuilt
Roger (K8RI)
Default Hidden costs of ethanol - big business - big profits
On Thu, 28 Jun 2007 18:56:46 GMT, cavelamb himself
snip
“Just as the events of 9-11 changed how we guard our cities and protect
ourselves, a new generation of ethanol may soon change the way we gas up
our cars and protect the earth.” - Dateline NBC
"Our plan to expand into ethanol production has the potential to
generate significant profits and increased shareholder values," JT
Cloud, CEO of Gulf Ethanol.
That it does.
snip
Factors Driving Alternative Energy Investments
* FREEDOM FROM FOREIGN OIL: Ethanol could free America from its
reluctant dependence on foreign oil. This is not a pipedream, conjured
it's doubtful we could make enough alcohol from corn to make more than
a small dent.However using all sources we probably could and becoming
independent of foreign oil is very important. It's also going to be
expensive.
up by some pro-U.S. idealists. Not at all. Brazil has turned that vision
into reality, where 70% of the vehicles in that country are sustained on
They are missing something very important here. Not all alcohol is
created equal, or rather at the same cost. The Key is Brazil does not
make alcohol from corn. They make it from sugar cane with has a much
higher yield than corn and costs far less to produce. Even with the
most optimistic approach providing alcohol from corn in the best
possible light at the lowest possible price, Brazilian alcohol would
still cost only a fraction of what it would cost us to produce corn
alcohol.
ethanol. Brazil's ethanol plan has successfully replaced imported oil
worth an estimated $120 billion. To put it into perspective, this would
translate to a savings of about $2 trillion for an economy equivalent in
size to the U.S.
How would it save anything for the consumer? The only thing it would
affect is the balance of payments or trade deficit IOW. Made from corn
the alcohol and gas containing it will cost more than straight gas
made from crude. Rephrased, moving to E85 or straight alcohol is going
to cost more, not less.Given that we are replacing something with
something else that costs more there is a problem with some one's
math.
The bottom line is the true cost of E85 and straight alcohol is more
expensive than the most expensive gas we've seen so far. Add to that
it only has 60% of the energy available of straight gas. So it costs
more and it takes more of it.
* INCREASED INCOME TO U.S. FARMERS: In terms of economics, there is
no clearer choice for the American public. It would mean higher farm
Yes it would mean higher farm income and that is something the smaller
farmers really do need.
incomes and we would see a steep increase in rural employment.
Depends on what they mean by rural employment. It certainly would not
translate to much of an increase in the number of farm workers. It
would mean more workers in the alcohol industry and fewer in the
petroleum industry. I don't see any where it would bring a steep
increase in "rural" employment. Switching land from another crop to
corn isn't going to require more labor either.
* THE TECHNOLOGY’S IN PLACE NOW: The technology to run cars on
ethanol already exists. General Motors alone has built more than 1.5
million ethanol-compliant vehicles.
The technology to produce the alcohol is in place, but the ability to
do so is not, at least as far as alcohol produced by corn in
quantities large enough to make much of a difference. Alcohol from
corn will have to be supplemented by alcohol from other sources which
will probably be capable of producing more alcohol at less cost than
that from corn, or at least eventually will be capable of doing so.
That means the use of corn for alcohol would not be nearly so
attractive unless artificially supported.
According to a recent AP story most of those "flex fuel" vehicles are
not designed to run long term on E85 or straight alcohol.
* IT’S RIDING THE “GREEN WAVE”: And let’s not ignore the fact that
ethanol is believed to be much more environmentally friendly than our
That is true.
current petroleum. Many experts agree that a switch from gasoline to
ethanol could significantly reduce our carbon dioxide emissions, some
say by as much as 80%. Ethanol’s appeal extends throughout interest
It wouldn't really reduce the emissions from the cars, but what it
would do is be releasing CO2 than had been taken from the atmosphere
during the growing of the crop so it would not be adding *any* new
CO2. They are confusing emissions with "additional CO2 to the
atmosphere" and that is much more than just semantics.
Ethanol is (as far as we currently know) more environmentally friendly
to burn than gas. There are some outstanding questions, but in general
it is thought to be far better for the environment than gas.
groups. The U.S. government, American car manufacturers,
environmentalists and the agriculture industry are all strong supporters
of this alternative fuel.
  #34
Old June 29th 07, 05:16 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Thu, 28 Jun 2007 04:56:04 -0700, Denny wrote:
It is hopeless alright...
Not to worry! The coming market correction will render large segments
of the population incapable of buying gasohol... That alone will
reduce our energy imbalance there is always a silver lining...
Man, you're about as pessimistic as my doctor! :-)) You must be
related.
denny
  #35
Old June 29th 07, 05:23 AM posted to rec.aviation.homebuilt
RST Engineering
Not only that, but you get Black's Beach at no additional cost.
"Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and wine in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
et...
  #36
Old June 29th 07, 12:28 PM posted to rec.aviation.homebuilt
Denny
Roger, an unsolved issue with alcohol is that smog is produced... I
have not done the reading to see what the solution to that is likely
some form of catalytic convertor so I'm not going to claim it is a
deal breaker, but it is significant...
For the ethanol lovers, I am not against ethanol just against muddy
thinking...
TO get ethanol for vehicles you:
*haul seed and supplies
*plow
*spray pesticides and herbicides
*fertilize
*plant
grow awhile
*knife in nitrogen
grow a bit more
*herbicides / pesticides again
grow awhile more
*harvest
*haul
ferment
*distill
*haul it again
mix with gasoline, or whatever hybrid fuel you make
*haul it again
and finally pump it onto your vehicle
Every step that has an asterisk uses fuel or chemicals or fertilizer
dependent upon petroleum...
The fuel of your grandchildren will be a hydrocarbon product made from
coal, not corn...
denny
  #37
Old June 29th 07, 05:37 PM posted to rec.aviation.homebuilt
Roger (K8RI)
My understanding is it is a great Ozone producer. I'm not sure how
that works our chemically...chem 111 and 112 were a long way back.
So as with the new energy efficient light bulbs which contain mercury
we are exchanging one pollution problem for another.
thinking...
*plow
Don't forget, disk, pack, and drag
*fertilize
*plant
grow awhile
*knife in nitrogen
Don't forget cultivating.
grow a bit more
grow awhile more
Corn takes a lot out of the land. or rephrased, it's depletes the soil
and its success depends on a very narrow range of growing conditions.
*harvest
*haul
ferment
Several handling/separation/pumping steps
*distill
*haul it again
*haul it again
coal, not corn...
For the optimistic, the current "net energy gain" for corn alcohol
_in-a-*good*_growing_year is about 33%. that means for the equivalent
of every two gallons invested we get 2.66 gallons out. Or IOW we
gained a whole 2/3 of a gallon. So we have a 33% gain, but that
doesn't take into account labor. When labor is added in the true price
of that corn alcohol is astronomical whether we pay for it directly at
the pump, or through subsidies to the grower and processor.
denny
  #38
Old June 29th 07, 07:14 PM posted to rec.aviation.homebuilt
cavelamb himself
Big Grin
You got that right, Jim!
  #39
Old June 29th 07, 09:01 PM posted to rec.aviation.homebuilt
william
Roger,
Most of the corn grown today is no-til. Some areas still plow due to soil
type or continuous corn crops, maybe you live in one of those areas. Under
no-til, it's fertilize, spray, plant, maybe apply more nitrogen, and
harvest. Plowing is very expensive and most farmers avoid it. No-til usually
does better anyway. The main fertilizer corn uses is nitrogen and most of
that production has shifted to areas where they have natural gas as a
by-product of oil production, but no pipe line or LNG to ship it. Otherwise
it would have been burned off or in some cases pumped back in the oil well
to help maintain pressure. I'm not sure all of that should be counted in the
energy equation. As for the labor part, I don't understand your point. The
farmer will still be around if he stops producing corn. He could idle his
equipment and land, get a desk job saving energy and other energy inputs,
but he is still going to use energy to live. I also don't think the farmer's
personal energy consumption should be counted in the conversion. One other
big energy input you did miss is irrigation, but very little corn is grown
under irrigation.
news
thinking...
*plow
*fertilize
*plant
grow awhile
*knife in nitrogen
grow a bit more
grow awhile more
*harvest
*haul
ferment
*distill
*haul it again
*haul it again
coal, not corn...
denny
  #40
Old June 30th 07, 01:08 AM posted to rec.aviation.homebuilt
Blueskies
"Roger (K8RI)" wrote in message ...
snip
"Just as the events of 9-11 changed how we guard our cities and protect
our cars and protect the earth." - Dateline NBC
That it does.
snip
expensive.
Here is a reply I received back from our Senator here in Michigan:
"Thank you . . .
. . for contacting me about your opposition to the use of ethanol as fuel. I appreciate hearing your views.
I understand your concern that the increased use of corn fuel could contribute to higher corn prices. Corn ethanol is a
first step as we transition into cellulosic ethanol technology, which does not use corn, only agricultural waste
products, and converts them into fuel.
Ethanol is an important piece of the energy puzzle to improve national security; however I recognize that it will not
single-handedly replace gasoline. Congress will tackle these energy questions when it works on the new farm bill this
year, as well as other energy legislation. I will keep your views in mind when the Senate takes up legislation related
to alternative fuels.
Again, thank you for contacting me. Please do not hesitate to do so again if I can be of assistance to you or your
family.
Sincerely,
Debbie Stabenow
United States Senator
DS: il "
Unlock Your Hidden Power, Today... John Products 0 August 1st 06 11:13 AM
Maintenance Costs/Hangar Costs aml Piloting 5 May 23rd 06 07:55 PM
Hidden costs of owning a Glider Doug Snyder Soaring 17 March 16th 05 08:46 PM
Hidden Antennas Dick Goff Home Built 2 August 20th 03 05:23 PM
