weather shorthand
Old June 29th 07, 05:02 PM posted to rec.aviation.ifr
pgbnh
Default weather shorthand
There was a time (probably right before I passed my Instrumenr written) when
I was pretty good at being able to read the shorthand used for weather
conditions, FA's, and the like. There was also a time when using shorthand
made sense - days of slow teletypes, limited memory, etc.
But does it still make sense? Would it not make more sense, and possibly
save some lives, if ALL weather was made available in plain English. So I
would not have to guess at the abbreviations, and hope that I had gotten it
right?
There is a certain amount of 'IFR-macho' to being able to interpret this
stuff, but is it time for a change?
Old June 29th 07, 06:05 PM posted to rec.aviation.ifr
El Maximo
"pgbnh" wrote in message
when I was pretty good at being able to read the shorthand used for
weather conditions, FA's, and the like. There was also a time when using
shorthand made sense - days of slow teletypes, limited memory, etc.
it right?
It works well with text messaging.
Old June 30th 07, 01:15 AM posted to rec.aviation.ifr
On Fri, 29 Jun 2007 12:02:39 -0400, "pgbnh"
right?
I thnk ur bng unrsnbl
Old June 30th 07, 01:37 AM posted to rec.aviation.ifr
kevmor
right?
I think maybe if you read them every day, it may be faster if it's
abbreviated... but I totally agree, leave things like TAFs and METARs
abbreviated when there are only a few abbreviations to know, but on
FA's, it'd be nice to have it in plain english. I use this to help:
http://www.nws.noaa.gov/glossary/index.php
Old June 30th 07, 03:55 AM posted to rec.aviation.ifr
Dave Johnson
Doesn't DUATS offer "plane English" (tongue in cheek)? Being an old buzzard
I still read the abbreviated, even when I can get it faster than 134.5 baud
(a fast Teletype years ago).
Dave
it right?
Old June 30th 07, 12:27 PM posted to rec.aviation.ifr
Bonehenge (B A R R Y)
On Sat, 30 Jun 2007 02:55:32 GMT, "Dave Johnson"
I get every briefing this in plain English.
Old June 30th 07, 12:32 PM posted to rec.aviation.ifr
abbreviated...
There's a Mythbusters test! Many variables to create lasting dispute.
G
I would imagine that once you know both sets of words, your brain will
process them at exactly the same speed.
However, abbreviated text is faster to type and transmit
electronically.
Old June 30th 07, 12:41 PM posted to rec.aviation.ifr
On Sat, 30 Jun 2007 11:27:42 GMT, "Bonehenge (B A R R Y)"
That one flew right over my head. G
Old June 30th 07, 03:13 PM posted to rec.aviation.ifr
Andrew Sarangan
right?
To see the benefit of abbreviated format, go to DUATS and get a
briefing for 500 mile trip. Print them on paper using their plain
english translator and the standard format. The plain English format
will take dozens of pages and it will be like reading a book. The
standard format will be a lot shorter and easier to interpret. Now try
reading while you are flying in a bouncing cockpit with dim lighting
and you can see how easy the short hand format is.
It is true that the cryptic form makes it difficult to learn the
codes. Perhaps it might be better if they dropped the French word
origins and used English abbreviations instead.
Old July 2nd 07, 01:18 PM posted to rec.aviation.ifr
B A R R Y[_2_]
I don't see a benefit of carrying hours-old printouts with me, compared
to fresh information obtained via HIWAS, Flight Watch, automated ground
stations, or onboard weather electronics.
To me, the distant weather is simply a sketch of what I might find along
the way. Any important information I want to have later can be noted in
the appropriate area on my knee pad flight plan form. Otherwise, isn't
it better to deal with what is, vs. what DUATS said it might be?
XM weather - anyone using it? Eric Greenwell Soaring 8 March 13th 07 03:18 AM
Ads-B weather John Theune Piloting 8 December 23rd 05 12:45 AM
Thanks for the weather, Jay! George Patterson Piloting 8 February 6th 05 09:49 PM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 04:00 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
