Blueskies wrote:
Saw this posted to the Lycoming group, and it sounds like a pretty good idea. Anybody heard of it? "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. I believe he purchased the system from Wag a few years ago. As I recall it was for experimentals only. They do not currently list such a system in their catalog. I have not found one at ACS&S or Chief either." Ok.. here's how it was explained to me, including stuff in the past few days.. I am not speaking authoritatively, only repeating from a collage of sources i've come across in the past 3 years. The oxygen sensor is automotive. The indicator is automotive. You will not find it in aviation catalogs. Go to your local auto parts store or to a speed shop, or an online auto parts place like Summit Racing. They sell sensors, indicators, and combination units. A one wire sensor is a narrow band sensor and has a very narrow detection range. It has a steep curve that corresponds to a range that is immediately around stoichiometric air/fuel ratio (which corresponds with peak EGT). The sensor only senses properly when its heated to at least 800 degrees, so engine has to be operating for a bit to achieve this. The bandwidth of the sensor may be inclusive of "best power" which is slightly rich of peak. It is NOT inclusive of the optimal lean of peak point, and this indication will be off scale - low. A 3 wire sensor incorporates a heating element, to allow greater responsiveness during initial starting and warmup. This is not necessary for a mixture monitor observed by the pilot, but finds use in emissions control for closed loop EFI's. A 5 wire sensor incorporates a nonconsumable oxgyen generator of some type, in addition to the heating elemet. I do not know how its generated, but a mixture monitor or EFI that is able to offset the oxygen reading with the oxygen generation value can be used as a wide band oxygen sensor and can give a wide range of air fuel mixture indications. This can reportedly be used to indicate optimum mixture for lean of peak ops. An EGT being used in a closed loop EFI situation must respond nearly instantaneously.. in milliseconds. Being used in leaded fuel will quickly render the sensor unuseable in this setting, for this cause. However, even when the sensor degrades to perhaps 1/2 a second lag time, this is still quicker than you can adjust the mixture manually, so even in a leaded fuel situation, you can get a lot of life out of an oxygen sensor. One of the folks in the Rotary engine crowd has reported getting 85 hours out of an ordinary 1 wire oxy sensor with nothin but 100ll. Running auto gas can sometimes undo the lead fouling to the point the sensor remains viable over its normal service life. 1 wire oxy sensors are cheap as far as aviation prices go. Changing it every 50 hours with your oil filter wouldnt be out of reason. In my opinion the problem that would emerge here is the fairly common circumstance of 4 different cylinders operating semi independently. Until or unless you get them balanced (Gami?) so that they peak and/or stumble together, an oxygen sensor on one pipe will indicate that one pipe. If its after a collector it will present an average, and you could still have a cylinder in the "danger zone". Under 75% power this likely isnt going to be a problem. You can use it to find ideal mixture, then manually lean from there. |
Great if he's running autogas.
The first tank of 100LL he puts in it is going to kill that sensor. |
![]() "Ron Natalie" wrote in message m... Great if he's running autogas. The first tank of 100LL he puts in it is going to kill that sensor. Apparently not... |
![]() "Dave S" wrote in message ink.net... Ok.. here's how it was explained to me, including stuff in the past few days.. I am not speaking authoritatively, only repeating from a collage of sources i've come across in the past 3 years. ................snip A 5 wire sensor incorporates a nonconsumable oxgyen generator of some type, in addition to the heating elemet. I do not know how its generated, but a mixture monitor or EFI that is able to offset the oxygen reading with the oxygen generation value can be used as a wide band oxygen sensor and can give a wide range of air fuel mixture indications. This can reportedly be used to indicate optimum mixture for lean of peak ops. An EGT being used in a closed loop EFI situation must respond nearly instantaneously.. in milliseconds. Being used in leaded fuel will quickly render the sensor unuseable in this setting, for this cause. However, even when the sensor degrades to perhaps 1/2 a second lag time, this is still quicker than you can adjust the mixture manually, so even in a leaded fuel situation, you can get a lot of life out of an oxygen sensor. One of the folks in the Rotary engine crowd has reported getting 85 hours out of an ordinary 1 wire oxy sensor with nothin but 100ll. Running auto gas can sometimes undo the lead fouling to the point the sensor remains viable over its normal service life. 1 wire oxy sensors are cheap as far as aviation prices go. Changing it every 50 hours with your oil filter wouldnt be out of reason. Interesting post...thanks... |
"Blueskies" wrote in message
.. . Saw this posted to the Lycoming group, and it sounds like a pretty good idea. Anybody heard of it? "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. I believe he purchased the system from Wag a few years ago. As I recall it was for experimentals only. They do not currently list such a system in their catalog. I have not found one at ACS&S or Chief either." Interesting. That's how the carbs in late 80s and early 90s worked in Jeeps (probably others too). They took a prefectly good carb and attached 'metering pins' to it to adjust the mixture based on the output of the O2 sensor. It runs much better when you disable it. |
You have it backwards. When the car first starts it is in open loop ignoring
the O2 sensor. Once in closed loop the O2 sensor is used to control mixture and prevent pollution. Bad O2 sensor will burn out the Catalytic converter because of too much fuel in exhaust. "Morgans" wrote in message ... "Montblack" wrote My reading of his post suggests it's a "monitor only" O2 sensor. With the data from the O2 sensor, the pilot then controls the mixture manually. I understood that to be the case also. My point is that in auto systems, the oxy sensor information must not be very valuable, since the computer ignores it at high power, which is where this system is attempting to function. Would the sensor/monitor have very much positive benefit, is my question. -- Jim in NC |
One thing I haven't seen yet in this string.
The point at which the o2 sensor shows as optimum is called the stoicheometric point. Exactly enough fuel to combine with every molecule of oxygen, and no more. that's an air fuel mixture of 14.7 to 1. In Electronic Fuel Injection, the computer's job is to find this point, and stick to it like a bulldog. Unfortunately, that is not the point that air cooled aviation engines need to be run. The exhaust gasses are hot enough to burn the valves at stoich (in an air cooled engine), When you peak the tach, then go a little rich, you wind up at about 10:1. A normal O2 sensor, like the cheap ones used for auto purposes, is not a nice readout of mixture, it's just a step function - "yes there is oxygen in the exhaust", or "no there isn't." Wide range sensors are available, but not cheap. If this mixture readout has an expensive "wide range" O2 sensor, that you propose to kill twice a year or so, the cost becomes a bit steeper. |
Knock sensor circuit? | Jerry Wass | Home Built | 0 | May 17th 07 05:18 AM |
carburator temp sensor | Philippe Vessaire | Home Built | 0 | May 14th 06 04:35 PM |
New Thermal sensor | [email protected] | Soaring | 4 | February 1st 05 02:07 PM |
Westach 720-4a sensor | Ira Rampil | Home Built | 1 | June 21st 04 03:41 AM |
temperature sensor | Philippe Vessaire | Home Built | 2 | March 3rd 04 03:37 AM |
