Protecting fiberglass from fuel & oil
Old September 18th 03, 04:13 AM
Paul Lee
Default Protecting fiberglass from fuel & oil
I have a composite cowling. There are some places where fuel or oil
might drip - for example below carb if overprimed. I would like to
simply paint that area inside or cover it with fuel resistant stuff
with a drain hole. Would any common paint do? Do I have to use the
tank sealer stuff - I don't need that much.
Paul Lee
SQ2000 canard project: www.abri.com/sq2000
Old September 18th 03, 04:38 AM
Fitzair4
Sand the area where you want it coated.
Brush on a film of epoxy, Like the West Systems epoxy.
It seals the fibers.
Larry Fitzgerald
Old September 18th 03, 07:14 AM
Richard Lamb
I'm at the same point on my cowling.
I have about decided to shoot the inside bottom with Epibond.
White in fact.
Holds up well agains laquer thinner, mek, acetone, etc.
Easier to clean too.
Richard
http://www.flash.net/~lamb01
Paul Lee
Richard Lamb
http://www.flash.net/~lamb01/
Auto Fuel STC Jeff Home Built 62 September 24th 03 03:41 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 09:25 PM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 01:08 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 07:10 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 10:47 PM
